Question about E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply
I have a T5026 EMachine won't power up. Green light on motherboard is on , could it be the switch , tried putting a new power supply box in it.
    Genius:
  • 1,066 Answers
To see if the power swithc is the problem-
first, try to isolate the wire that connects the power switch to the motherboard. once you have deternined where the power switch plugs, then remove the wires from the motherboard leads and try to short the leads by connecting them with a metal device like a screwdriver tip. if the switch is broken, it will boot when shorted with the screwdriver. if it still will not boot, then you probably need either a new motherboard or a new cpu.
Posted on Nov 06, 2010
How do i take the top cover off a emachines t5026?
Hello cw robin, hi, you need to remove the power supply out of the casing. loosen the side cover screw at the back left side. side of, reveals the power supply box, Now remove the 4 screw on the Fan exhaust side. There is a release lever on the bottom of the power supply like a ball shape lock, press it and it releases the power supply box. remove the connections on the motherboards and drives. Power supply out, there are small screw on the power supply box, remove it. open and you have now access to the power supply board.
Dec 06, 2010 | E-Machines Emachine T5026 power supply **...
I have an emachine t5026 that won't turn on. It
There can be two problems with your PC. either the power supply is faulty which is highly probable, and the other is that your Motherboard maybe faulty or both things are faulty. Try replacing the Power supply first. It should solve your problem.
May 15, 2010 | E-Machines Emachine T5026 power supply **...
Emachine wont start
I just had the same problem. Try replacing the battery on the motherboard, that seems to have fixed mine. The number on the battery is CR 2032.
May 11, 2010 | E-Machines Emachine T5026 power supply **...
I have an emachine t5026 that won't turn on. It sounds like a car tying to start and the lights on the front flash as does the light on the mouse, but it won't start.
Mar 29, 2010 | E-Machines Emachine T5026 power supply **...
Computer worked fine, unhooked it to hook up a new one, decided to hook the emachine back up to play games on, got it hooked up but it won't come on now. everything is hooked up right, i opened it up and...
make sure you hook everything with a little force especially the memory until it snaps back into place. same goes for all the cards. care should be give to the cpu, nice and easy. make sure your power supply is potential enough or has not gone bad. The MB can give a green light but there could be too little energy for the whole system.
Mar 27, 2009 | E-Machines Emachine T5026 power supply **...
Emachine won't turn on
With an Emachine it can be the power supply or the motherboard.
My guess it is the capacitors on the motherboard. Check to see if the round cylinders on the motherboard are bulging on the ends, and possibly rusty looking. Esp around the Main CPU/Fan.
They are notorious for bad capacitors.
If the caps look good, it still could be the motherboard, or maybe the power supply. Switcing out the power supply is pretty easy.
Unplug
disconnect all the power connectors
unscrew the 4 screws on the back of the computer
remove and replace the power supply.
Make sure you get a power supply with as much power, or more is much better. 350 watt or higher.
For more on the capacitor plaugue, check here
http://paulrepair.blogspot.com/2009/03/blown-capacitors-it-is-plague.html
Mar 25, 2009 | E-Machines Emachine T5026 power supply **...
EMachine T5026 no boot
This just happened to my t5026. I had to replace the power supply to fix.
Mar 08, 2009 | E-Machines Emachine T5026 power supply **...
Computer will not turn on
Best way to check is to open your case. Near the power supply plug to the motherboard should be a little led light. If it is getting power to the board this light should be green. If it's unlit then most likely your power supply has gone bad. Hope this helps.
Dec 21, 2008 | E-Machines Emachine T5026 power supply **...
E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply Logo
476 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
