Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
It won't automatically oil the chain. I've put very thin oil in and it sitll doesn't oil. I've taken the breather tube out and cleaned it. Not sure what else to do.
    Brigadier General:
  • 4,088 Answers
Release the chain brake, then remove the bar and chain. Clean the engine where the bar fits up to, start the engine, and look for oil oozing out of a small port in the engine side. Make sure to replace the thin oil with regular bar oil. If the oil does ooze out, then clean the small oil passages in the drive end of the bar--they run from the large holes out to the chain groove on each edge of the bar. If no oil oozes out, check the oil filter inside the tank. If ok, then the oil pump requires service--it is located just behind the clutch drum on the crankshaft. The clutch has left-hand threads and can be difficult to remove--you might wish to farm the oil pump repair out to a service shop that has the proper tools and procedures. Hope this helps!
Posted on Nov 06, 2010
How does the Echo 280e oil the chain
automatically to test hold over a clean white paper and run the saw bit . oil should splatter on the paper . if it doesn't remove chain and clean out all the dirty oily sawdust with brake cleaner , and test again the tube may be plugged
May 18, 2016 | Cars & Trucks
Help! carburetor pulse oiler on homelite xl chainsaw ut-10694-a
there is a breather hole somewhere you need to clean it up so you can find it probly on the cap
Mar 29, 2014 | Garden
For some reason i can not get the cover for my timing chain to come off. all the bolts were taken off, there is however a little pipe looking thing also connected to the timing chain cover that i cant get...
its a breather pipe im not positive but usually u twist and turn pulling on it to remove, its a interference fit the timing chaine cover is just stuck there is a gasket some times people put sealant on it u will need to use a very thin screwdriver and pries it open once u break seal it will b easy ,..u must re seal after u have finished fitting it or there will b oil every were leaking
Oct 25, 2013 | Cars & Trucks
My Woolf 900 generator starts fine initially. When put on load (600w) it is reluctant to get up to speed (45secs) but eventually gets there. When load is taken off it doesn't go back to idle and event
Does it have and automatic idle? If so cut it off and see if engine can run at 3600rpm no load. If still stalls, your jets(brass tube) have something blocking holes and carb needs either a real good clean in a dip, rebuilding, or replacing.
Jul 09, 2013 | Electrical Supplies
My husqvarna automatic chain oiler doesn,t work...235 husqvarna any fixes?.
You may have gotten some saw dust particles inside the oil resevoir that got sucked into the delivery tube, thus clogging up the oiler...you can drain the oil out of resevoir and run some seafoam thru the oil resevoir to see if you can get it unclogged
Jan 23, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a husqvarna 55 rancher oil comes out the oil hole when bar is not on it but i put bar and chain on and it dosent get enough oil on chain just a small amount between teeth, ive cleaned bar and chain,...
The hole in the bar pad is the breather, it is quite normal for it to leak if the bar is removed, it consist of a role pipe and pipe inside the oil tank, there is nothing to worry about
Jan 19, 2011 | Garden
My saw will start with no problem. But when i gas on it, it bogs down and there is smoke coming from the bar cover. i have taken it apart many times and even taken out the brake. i was wondering if my...
If the brake has been entirely removed, then check the lubrication and tension of the chain--you should be able to turn the chain by hand fairly easily. If it looks dry with little or no oil, remove the bar and chain. Clean the side of the engine case where the bar fits to, then start the engine. Oil should ooze out of the side port. If nothing, then the oil pump, oil line, or filter in the tank may need service. If ok, then clean the bar drive-end oil passages--especially the two small holes that feed oil from the large holes out to the chain groove on each edge. When back together, run the bar tip at speed near some cardboard for a couple of moments--it should throw off a thin line of oil. There should be a volume adjustment screw head under the case near the chain return area--turn it CW to decrease volume. Hope this helps!
Dec 22, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain not lubricating on Ryobi 4046c chain saw
Have exactly the same problem as you, think the oil pump is the problem but can't find a supplier for the part yet. I blew done the pipe into the oil tank using an air line and it was OK.
May 09, 2010 | Garden
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
70 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
