Question about LG Dishwashers
Lg dishwasher ld2120w is displaying an error code E1 what does this mean
  • 3 Answers
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. I resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first. I think the origin of the problem might be too much food on the plates and too strong of a dishwasher gel detergent so the food is turned into gunk which coats the channels of the plastic assemblies.
Add a comment
Posted on Nov 07, 2010
  • 2 more comments
  • supro7 Nov 25, 2010
    OH...and by vice grips I meant Needle nose pliers.
  • frank mohr Nov 25, 2010
    MINE IS A LG 3850DD3006A AND YES THE GARBAGE DISPOSER GETS STRAWS AND JUNK IN IT. OR THE SCREEN ON THE TOP IS COVERED WITH MACARONI AND CHEESE. OR TWICE IN 4 YEARS THE MOTOR RING SPLIT AND THE MOTOR STARTED TO GRIND THAT RING TILL IT STOPPED ALLTOGETHER.
    WHAT A PEACE OF JUNK!!
    I ADMIT THE STRAWS ARE THE USERS FALT!
  • Chris3977 Jun 27, 2011
    Didn't work for me. Maybe e1 error means more than 1 thing. I had the same problem with groaning pump but after following instructions and cleaning it out my problem isn't fixed :(
  • d_redden Sep 07, 2011
    did you eventually find out what the problem was. My dishwasher is displaying e1 error this morning
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    My LG dishwasher when I turn it on it drains the water, then it fills it up with water, about 1 min. later gives me the code E1 and drains the water again...
    LG Dishwasher Displaying Fault Code E1 LDF7810BB/01 LEAKAGE ERROR // Excessive pump motor RPM due to water leakage
    The manufacturer has assigned this error or fault code to indicate that when the drain pump is running it is not experiencing the back pressure it expects. This is usually an indication that there is a water leak in the drain system. Check all hoses and connections. Check under the dishwasher for any major leak. If all checks out, be certain there is a proper loop in the drain hose to prevent siphoning. Finally, if the problem persists, the drain pump itself might be defective.
    Sep 25, 2015 | LG Dishwashers
    E1 error code on omega dishwasher
    E1 error on LG Dishwasher - YouTube
    ? 2:40
    www.youtube.com/watch?v=2qcwAyHI9ik
    Aug 24, 2012 - Uploaded by 62spindrift My fix for E1 error on LF Dishwasher. ... Maytag Maxima steam Washer has F8 & E1 error code - Pressure sensor & no water detected ...
    Aug 28, 2015 | Dishwashers
    Displays E1 code. water is on
    Hi there Dolly, error code E1 relates to water leaking. Its the code the machine displays when the flood switch in the bottom of the machine activates. The flood switch activates when the bottom of the machine gets filled with water from a leak. I surgest you have a look underneth the machine for signs of water. I hope this helps regards Gary.
    May 04, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
    I have a LG dishwasher, model LDF7920ST, it has been displaying error E1 , what does this mean
    E1 means leakage error. You need to check around the unit, and under the sink where the drain hose connects plumbing underneath.
    It's possible the dishwasher may need to be uninstalled and checked for leaks. Please post back.
    Mar 07, 2011 | Dishwashers
    Error was E1 could you please let me know what this error means
    Devices with computer display area are expected to display malfunctions usually as an error where a numberical figure may have an idication of condition. Usually the error messages withd evices should least require ascertaining the syntax symbols. Once experienced, refer to experts to resolve or refer to user guide to resore malfunction. Disregard the syntax messages since is a computer code least humanly perceivable.
    Feb 14, 2011 | LG Dishwashers
    LG Model 67LDO210 Error E1
    Hi, the "E1" error code means the dishwasher has developed a leak. Meaning your outlet hose is too low or too far down the drain, it is losing water while it is washing making it think there is a leak...
    Jan 16, 2011 | Dishwashers
    E1 code comes up on the display, but how do you solve this? ...
    E1 Leakage error. Cause : water leakage in hose connections. Water is leaked by damages.
    Feb 18, 2010 | LG 24 in. LD-12BW5 Free-standing...
    AE displayed on LG dishwasher
    Please look one more time. The LG LDS 5811 dishwasher error codes are:
    IE Error
    OE Error
    FE Error
    E1 Error
    HE Error
    tE Error
    It would also be helpful to know what happens when this error code displays. Please post back here, OK?
    Thanks.
    Apr 16, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
    Lg dishwasher lds 5811st E1 error code
    Hi Chaz,
    The impeller breaks on the motor shaft. The motor still turns, but the impeller doesn't, so it doesn't pump water. Because the machine senses there is no water pressure from the pump, it shuts down & displays E1 (it thinks there's a water leak, due to no pressure)
    Unfortunately the motor/impeller is only available as a complete assembly
    Hope this helps
    Col
    Dec 11, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
    Dishwashers Logo
    624 people viewed this question
    Top LG Dishwashers Experts
    Mike
    Are you a LG Dishwasher Expert? Answer questions, earn points and help others
