Question about NEC DTU 8D-2 Corded Phone
Hello i have NEC KMP7N2D2-1A haw code reset sim please
Hi i found my old nec 616 but cant remember my npin and ive blocked it now, need the PUK please thanks. louie
The PUK lock code is enabled on your SIM when you guess the SIM password
incorrectly too many times. You carrier can provide you with the unlock code.
Just call them and give them your SIM number.
CommCentral
Oct 18, 2010 | NEC E132 Cellular Phone
I have forgot my password for myphone lock! haw do i find my password?
Hi you can buy a Smart Universal Turbo Sim Card Unlock Card 4 GSM Phone from ebay it cost less than $3
Thank you
Jul 19, 2010 | Cell Phones
Haw to reset gestetner2722ztd error E1
press dot ( . ) on the left side of 0 so we could know whats the second defree number is. to reset press energy saver once then 107 press stop button until 1 blinks then 5 # 810 # turn off copier then on.
Jan 10, 2010 | Gestetner Copier
I need puk code for my nokia
You will need to call your service provider (not the phone maker)and tell them you need the code and red the # off the sim card when ask to do so.
May 02, 2009 | NEC MobilePro 900 Handheld
Sharp AR-5127 H2-00 code reset
it is a heater code. The thermostat has blown and resetting the code could cause a fire, but it probably won't do anything, the part will need to be replaced
Jan 16, 2009 | Toshiba e-Studio162D Copier
Please copuld you help me?
you have entered the pin code wrong 3 times now you are required to enter a puk code to reset the pin code.
The puk code is sim card spesific it comes with the sim card when you get it or you can get it by calling your phone service provider of the sim card to get the puk code.
if you have entered the puk code wrong too many times you will make the sim card useless and you will have to contact your phone service provider for a new sim card, it will probably cost.
Sep 28, 2008 | NEC MobilePro 770
Please help me
ok do one thing put one expired sim card in your cell then it surely works it will not freeze i think ...
after that give restore factory settings(reset) as you access menu ...
(if you were able to access the menu previously then no need of this expired sim card ...)
after giving restore factory settings then all your firmware problems will be solved & the phone will not freeze like previously so just insert the sim card whose network must be unlocked & insert that code ....
in case if you couldnt do the restore factory settings then just
insert this codes with out sim(any one of them will surely reset your cell)
*2767*637#
*2767*3855#
*2767*2878#
in this one of them will reset your phone after that insert that sim & insert the previously told unlocking code...
that s it ....
thank you
bye
please rate my solution
Jul 04, 2008 | Cell Phones
Preylahong NEC MT830+need help to reset new lamp
After replacing lamp in MT-830(NEC) press and hold "on" button for 10 seconds to reset lamp hours. If projector has beyond 2100 hours press the "off" button for 10 second.
May 01, 2008 | Office Equipment & Supplies
Samsung D820
Here are some codes for your phone....try the first one
*2767*688# = Unlocking Code *#8999*8378# = All in one Code (EDIT) *#4777*8665# = GPSR Tool (EDIT) *#8999*523# = LCD Brightness (EDIT) *#8999*3825523# = External Display (DOES NOT WORK) *#8999*377# = Errors (EDIT) *#2255# = Call List (DOES NOT WORK) #7263867# RAM DUMP ON/OFF (DISPLAY) #*5737425# JAVA SERIAL (DISPLAY) *#8999*5282 JAVA TRACE (EDIT) *#87667# DEBUG MODE (EDIT) *#87927# WAP BROWSER PROFILE (EDIT) DON'T CHANGE UNLESS YOU KNOW WHAT YOUR ARE DOING #*3888# BLUETOOTH TEST (DISPLAY) *#232337# BLUETOOTH MAC ADDRESS (DISPLAY) *#8999*636# = Have no clue what it is, i see 20 lines *#9999# = Software version *#8999*8376263# = HW ver, SW ver and Build Date *#8888# = HW version *#8377466# = Same HW/SW version thing *#7465625# = Check the locks *7465625*638*Code# = Enables Network lock *7465625*782*Code# = Enables Subset lock *7465625*77*Code# = Enables SP lock *7465625*27*Code# = Enables CP lock *7465625*746*Code# = Enables SIM lock *7465625*228# = Activa lock ON *7465625*28638# = Auto Network lock ON *7465625*28782# = Auto subset lock ON *7465625*2877# = Auto SP lock ON *7465625*2827# = Auto CP lock ON *7465625*28746# = Auto SIM lock ON *2767*3855# = E2P Full Reset *2767*2878# = E2P Custom Reset ^also one time unlock put the non t-mobile sim in the turn it on and type this code to unlock till the phone turns off *2767*927# = E2P Wap Reset *2767*226372# = E2P Camera Reset
Dec 06, 2007 | Cell Phones
NEC DTU 8D-2 Corded Phone Logo
211 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
