Question about Muratec MFX-1200P All-In-One Led Printer
Network i can see ip on the printer . what is easy way to net work it.
  • Anonymous Jan 24, 2009
    how can i run scanner on muratec 1200. OP 150 card is already installed
    Problem Solver:
  • 5 Answers
You need the installation CD. When the network install is run from CD the Muratec software creates it's own printer port. Standard tcp/ip ports will not work
Posted on Feb 01, 2009
    Sergeant:
  • 369 Answers
GO to the controll pannal and printers and say add printer choose network printer if u know the ip just put your ip address and say next it should detect it if not try to go to command promt and ping the ip with the ping command
if it gets the repply frmtheip so its comunicating
Posted on Jun 15, 2008
Amber light is flashing on network card
Switch off the printer, re connect the net work cable, switch on the machine & wait till ready mode comes.. Go to administration on control panel, select configure device,select configuration page, print,, total three print out will come, in that see the IP address.. If any IP address showing, ping that IP from system, if its pings, reload the drivers once again.. check for the print. If no IP adress showing in configuration page, try with another net work cable & try above said exercise.. Even no luck, remove formatter from the slot & re-fix once again & try... Even no luck.. it might be network port faulty. If its warranty contact HP support for free replacement.. If no warranty purchase HP620n or higher version of zetdirect card(net work card) install it... But take service engineers suggestion before replacing the network card..
Aug 01, 2012 | HP LaserJet M4345 MultiFunction Printer
Hp laserjet P2055dn - print config report indicates IPv6 Address, will not network print. How can I clear this?
IPv6 is upgraded from IPv4 (Internet protocol).. Its implemented in 1994 this adres is stored in DNS, it is no way connection with the printer, when the printer is connected through lan net work, auto IP adress will assign by the DNS server depend up on the settings.. you can change the desire IP adress with the family range. If the printer is not showing IPv6 adress, system administrator can help you in this regards depens upon their permissions. Selected printer IP adress ahould be with in the family range and no IP conflict definately printer will work..
Nov 19, 2011 | HP Office Equipment & Supplies
How do I connect a Kodak ESP 5200 Printer to a Local Area Network? To begin with, the LAN Hub uses Ethernet connectors, and the Printer has only a USB2
I had major problems initially. Connecting the printer to the Router was easy but after dificulties I found the answer on the Net as printed below:
1. Determine the IP address of the printer - usually you can print a configuration page and find it there.
2. Start the Add Printer wizard. Do not select Network Printer - select Local Printer and clear any check boxes for auto detection.
3. Select Create new port - select Standard TCP/IP port and configure it
with the IP address of the HP.
Doug Sherman
MCSE, MCSA, MCP+I, MVP
Regards
Jeff Davies
Wales
Feb 09, 2011 | Office Equipment & Supplies
The printer can not be ping from the network PCs
try assigning a different IP to it and see if it can be ping afterwards. If the same thing happens even with different IP, chances are, its NIC is defective and needs to be replaced.
Feb 17, 2009 | HP LaserJet 4350 Printer
My net don't see the printer
1st of all you'll have to check if the DHCP is activated.
But for your normall operation try a static ip, that will keep the machine allways connected to the specified network class.
Dec 08, 2008 | Canon imageRUNNER C3220 Printer
Printer in net work connection
Hey nagaraja,
Installing the printer on a network can be a pain just so you know. It varies in method depending if its a wired or wireless printer. First ting you need to do is get the software of the printer installed. If its for a single pc you simply change the port of the printer to the ip address of the printer. You can get the ip of the printer by printing the network configuration page from the printer. Now this is as much i can tell you without sounding condescending and assuming that you are a moron.
I hope this will help you- you being a printer service eng and all. if you are stuck in a perticular situation provide the details coz your question and the scope of answering it is vast.
Hit me again if you need specific assistance. Else look for tutorials on the net.
Nov 24, 2008 | HP Office Equipment & Supplies
Unable to reach the device for a statics IP address fro this Zebra TLP 2844-Z printer
I work for zebra. you should user zebra net bridge, its the current network tool and the best to use
Aug 01, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Infoprint 1120 printer
If you are doing it as a local printer ( parralel cable or USB it can be done through Start, Settings, Printers and faxes, Add a printer.
Network is different.
You have to assign or let it get an IP address from the network.
You can enter it manually in the printer
Hit the left arrow to
Network menu
hit select
Standard net setup
hit select
Print ( to print out the network settings)
scroll to TCP/IP
select
enter IP manually by scrolling to each number and hitting select
Sep 18, 2007 | IBM Infoprint 1120 Laser Printer
4600n
Can't come to VA but will the printer print a test page from the pannel?? Check the net card setup. Is it a shared local printer and set to work ofline?
Aug 23, 2007 | HP LaserJet 4600dn Color Printer
Not printing continously
Try a different network cable.
Feb 11, 2007 | HP LaserJet 2420 Printer
Muratec MFX-1200P All-In-One Led Printer Logo
89 people viewed this question
Top Muratec Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Scott Yeoman
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
