Sony Ericsson W850i Cellular Phone Logo
Posted on Jun 15, 2008
Will not connect to the bluetooth
Yes sorry it is the sony ericsson. It will not connect to the bluetooth, have you any idea
Kev
superham55
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 17, 2008
superham55
Contributor
Level 1:
Answers
Questions
0
Helped
173
Points
If it is a Sony Headset, you have to turn the headset on and the bluetooth on the phone on, then, press BOTH volume control buttons simultaneously on the headset until the indicator light alternates green-red. Your phone should be able to detect the headset now, I just went through the same problem and this is how I fixed it.
1helpful
2answers
I have a k800i sony ericsson mobile n my problem is that its bluetooth aint workin.
How did you Set up Bluetooth on the Sony Ericsson K800i ?was it set up properly?Sony Ericsson K800i has Bluetooth technology, which can connect to other Bluetooth devices like handsfree headsets, or let you easily swap files like pictures, ringtones, videos or contacts with other people for free. It works by looking for other Bluetooth devices nearby and then connects to them to wirelessly transfer files. this is the steps to seeting up bluetooth on k800i sony ericsson
  • From the Menu screen, select Settings
  • Scroll across to the Connectivity tab and select Bluetooth
  • Scroll down to Phone Name and press select
  • Enter the new name for your K800i
  • Once you’ve done this, you can turn Bluetooth on to make you visible to other devices by following these steps
  • Select Turn On
To connect your Sony Ericsson K800i to a handsfree device, enter the Bluetooth menu screen and select Handsfree, Your phone will then look for a handsfree device to connect to. When it’s found it, select the device and enter the passcode if required
4helpful
Does the sony ericsson model k300i have bluetooth
Yes, that phone has blue tooth capability..
Heres how to access it from within the phone.
Go to Settings-Connectivity-Bluetooth
3answers
Bluetooth
Sorry but you can not installed blue tooth on the dis device.
Blue tooth is not only a software. I t also requires hardware.
Sorry.
2answers
Bluetooth hansfree connection
hi splash,
sorry to let you know but sony w180 does not suort an A2DP profile,
which is necessary to listen music wirelessly. so u'll have to change ur handset if
u want to listen to music via ur bluetooth headset.!!
good luck!
Net
hello there!
By using your phone as a modem, you can get Internet access via your PC. Before you can use your phone as a modem, your service provider must enable your data line. Once the data line is enabled, you must set up your PC.
You can connect your phone to your laptop via USB cable or bluetooth. then open the PC suite for sure there will be set up for this.
You will need the PC suite to do this.
Set up the Data account in the Sony Ericsson K750i:
  • Go to Menu
  • Select Connectivity > press Yes
  • Select Data Communication > press Yes
  • Select Data Accounts > press Yes
  • Select Add Account > press Yes
  • Select GPRS Data > press Yes
  • Enter Name as :mnet
    • APN : mnet
    • Give User name as: mnet
    • Give Password as: mnet
  • Select Save > press Yes
  • Connect your Sony Ericsson K750i with cable.
  • If you are using the USB cable or DSS-20, then
    • Double click Phone Connection link
    • Uncheck the USB prot.
  • Click Start > Programs
  • Select Sony Ericsson > Mobile networking wizard
  • Select Create new connection > GPRS
  • Select Install Modem > Add (install the modem on the same port of the USB)
  • Select Access point name as :
  • For Primary and Secondary DNS: leave blank
    • Give Password as:
  • To confirm select Done
  • Select Connect > Dial
With the Sony Ericsson PC Suite software installed on your PC, you'll be able to synchronise your phone contacts, calendar appointments, tasks, notes, emails and bookmarks between your phone and your PC at any time. You can synchronise using USB cable, Bluetooth™ or Infrared (IR), depending on phone model.
To be able to use Sony Ericsson PC Suite with your PC, there are some requirements on hard disk space and Windows version that must be met. Please see Software downloads on this site to download and for details on the requirements for your phone.
Bluetooth
no idea about that i have just never tried it. Sorry for the disopinion
1helpful
How to play music though your sony ericsson k800 bluetooth headset
Your bluetooth device will be for one ear, yes! you have to connect the hands free headset to your phone, for the radio it acts as an aerial, the ear pieces for the stereo.
A2DP audio profile
Unfortunately, you can't add that to your phone. This is dependant on the hardware. Sorry...
5helpful
2answers
Sony Ericsson W900i Pairing With HBH-608
turn the bluetooth on wait 10 seconds after the bluetooth has turned on. after it has turned on hold the (+) & (-) volume buttons at the same time for about 5 seconds. the light on the outside will then start to flash green and red, and it is ready to pair to your phone.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
