Question about Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity Gas Dryer - White
Dryer not drying. Unplugged it and plugged back in. Filter is clean.
  • Samsung Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 07, 2010
LG dryer DLE2140 error CL clean filter which I have done and even used vaccum dryer still wont come on
the clean filter just blinks at start of a cycle to remind you to clean it. there is no lint filter sensor or anything like that. it goes out after you program your cycle and hit start. if dryer is not coming on, there is another issue. any fault/error codes?
Mar 10, 2015 | LG Dryers
Maytag quiet series 300 manual
pf is power failure because you unplugged it,is it gas or electric,that could be anything,you need to open the door,look around the opening and find the model number and send it,if it is gas you could have bad gas coils located on the gas valve,they will work for the first 15 to 20 minutes and when they heat up they will fail only if they're going bad so the clothes will feel warm but not dry,also you still could have a block in the vent line or in the duct where the lint filter slides into,there's a blower wheel in there that blows the air around,remember all a dryer does is move hot air around to dry the clothes,the easiest way to check the line is to remove it from the back and run it,but first clean out where the lint filter slides into
Oct 01, 2017 | Dryers
Cooling light stays on during dry cycle. no heat is to dry clothes. I've switched the circut breaker numerous times and unplugged the unit many times also to "reset" . What's next..
Try a timed dry cycle instead of an automatic cycle. If that works, then you will need to clean off the moisture detection bars inside the dryer to get the auto cycle to work again. Look for two curved metal bars, about 3/16 inch wide and 4 inches long, about an inch apart, located just inside the front of the dryer, near the right side of the lint filter. (you'll have to stick your head in the dryer drum to see them) Often times, use of dryer sheets will result in a waxy coating forming on these bars, preventing the dryer from detecting the moisture in the clothes. The dryer sees no moisture, it goes into the cool down mode and then stops. Clean the bars off, and you should be back in the laundry business.
Feb 05, 2011 | LG DLE7177 Dryer
Dryer keeps saying check filter - lint screen is clean-dryer won't run
Had the same problem. Filter was clean. Vacuumed out the area under the filter. Still had problem. Unplugged the dryer. Removed the hose vent (back of dryer) and checked the exhaust -- all clean. Plugged the dryer back in and was fine. Still going to check the vent to the outside for lint buildup.
Jan 17, 2011 | LG DLG2524 Gas Dryer
LG TROMM DLE7177RM Dryer: when I turn power on it says Clean Filter, filter is clean. when I select settings and turn dryer on it says simultaneously ''DRY'' flashing and ''COOLING'' on -- it ends up...
Ah you unhooked it from the wall, but did you go outside and see if air flow was adequate outside. Quite often flexable hoses and duct work get plugged with lint. If that is the case be glad your dryer had pleanty of safetys. If you start it briefly with the hose disconnected, do you get the dry light flashings? Metal duct work all the way outside is best.
Jul 11, 2010 | LG Dryers
Dried a load of clothes and put another load in and now it's not working. Timer is clicking, but when I push the start button it does not kick on. Tried different settings and still nothing. It's been...
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Sep 11, 2009 | Dryers
Lg dle3777w dryer filter light remains on and dryer is not working even after cleaning the filter.
I'm sure you solved the problem but as i had the same problem on my electric LG front loader and saw no response i figured I would leave one for anybody else in the future. My girlfriend told me the dryer would not start and as i looke i saw the panel would not power up, I unplugged the power cord for 5 minutes and the LG reset and the panel was on and reading clean filter after checking the filter which appeared clean I tried to restart the dryer at which time it powered off. I again unplugged the dryer and replugged it and again the display read clean filter. I then gtabbed a phillips #2 and unscrewed the filter lint sceen which had a total of 4 scews in the interior of the dryer holding the filter housing unit. Youll see a piece of the housing unit remains screwed into the washer hooked up to two electrical plugs. Seperate both plugs from the unit and unscrew it and remove the unit youll notice two silver strips on the unit and I'm guessing will be covered with a small amount of lint. Clean the unit with a brush and damp cloth inside and out reattach the unit screw first and housing unit and turn on. If the dryer again turns off unplug and youll see the clean filter light. Simply push the custom program light or anything similar and the panel should start working again. I hope this helps someone.
Aug 08, 2009 | LG DLE3777 Electric Dryer
So embarassing, and a nightmare...
Most certainly you did miss something. That stuff can be a real mess as I'm sure you already know. Since you used the dryer and saturated the detergent, its probably in places you can't even see..and expanded where you can't see. The most important thing to do is strip the dryer and totally clean off any residue you see.
You could probably could get away with missing certain places..but anywhere wires and connections are could short out....and any surface that gets hot during use will cook off that detergent and smell.
Strip it and clean it...there's not a whole bunch to a Dryer...but pay attention to detail if you do it yourself.
May 02, 2009 | Whirlpool Dryers
Dryer does not heat... clothes only air fluff, not dry
sound like the heat coil is broken or burnt out..you can get one at an appliance parts supply store...but the only way to get it in is to take apart the dryer it is the back of the dryer that containt the heat coil...
Feb 16, 2009 | Maytag Dryers
Dryer keeps stopping - check filter light on
For Sgt 48 - You are not reading the original message very well - The original help question didn't say they saw check filter at the beginning or end of a dry cycle they indicated that the dryer STOPS MID DRY and says check filter - this is not a friendly reminder, it is indicating something is wrong and the filter needs to be completely cleaned out (and past the filter down in the interior of the dryer) and if that does not work then you need to also check the dryer hose for kinks, lint build up, etc. Lastly, reset the dryer by unplugging it (or flipping the breaker) for a minute or so and hold down on the start/pause button for 8 seconds while it is unplugged (this will reset the error code for check filter, among other things).
May 13, 2008 | LG DLG2525S Electric Dryer
Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity Gas Dryer - White Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
