Question about Sharp Audio Players & Recorders
When I turn on the player...the "PROTECT" message comes up... I would like to know how to start this player...or how to bypass this message so it pplays. Hope somebody out there knows the answer...thank you.
    Genius:
  • 1,066 Answers
Protect means that the speakers are improperly hooked up or just not compatible with the amp.
ensure that the speakers are 8-16 ohms, that no wires are crossed, and no wire strands are loose, which could touch and short. a 4 ohm speaker or a short in the wiring is almost always the cause of a protect error.
if all of this is checked, and it still says "protect" then it is fried.
Posted on Nov 06, 2010
WINDOWS VISTA 64 bit not reading CD Rom/ DVD player after services pack download. Driver is best. Error message "problen in registry (code 19)
If it truly needs a driver then install patin-couffin It will bypass all that windows uses now and accurately talk between drives and the dvd-rom. But it sounds to me that your dvd-rom just failed. You never know when they are going to go
Apr 17, 2013 | Microsoft Windows 7 Home Premium Operating...
Kenwood cd player keeps flashing "protect" when i turn it on. How do i fix this?
The "Protect" message indicates that the unit has detected a short or surge in the wiring to the unit. Check your ground and make sure that the speaker wires are not the problem. (Any broken wires or speaker wires that touch the case of the CD player could cause the issue.)
If there are no obvious wiring problems, then the unit has an internal short. That should be resolved by sending the unit for service if it is under warranty.
Please add a comment with the model number of the CD player for additional information. I hope this helps.
Feb 18, 2013 | Audio Players & Recorders
My stereo sysytem is a mini stereo: serial number 10200055. It currently says "protect", what is this and how do we return our system to normal operations?
When the word PROTECT appears on this display, this means the unit has detected a critical fault which could potentially cause harm to your stereo system.
The most common cause is a short circuit somewhere - something even as simple as loose speaker wiring could cause a short, triggering the Protect message.
You will need to determine if there is a possible short somewhere, so I recommend you start by firstly turning power OFF, disconnecting all speaker wires, then turn unit back ON.
Operate the stereo (without speakers) and turn volume up:
  • If Protect message appears when turning volume up, then stereo unit itself has an internal fault
  • If no Protect message appears, then suspect the speakers may be causing the issue.
  • Reduce volume and turn unit OFF
Re-connect speakers (ensure the connections are secure), turn unit ON:
  • If turning volume up triggers the Protect message again, there is an issue with the speakers or connections
Hope this helps.....
Sep 04, 2011 | Kenwood Audio Players & Recorders
There is a display message that comes up when you press the job status button that is flashing "Check the direction or the size of the paper on the bypass tray and press start", we are not trying...
try to format its HDD :
turn it off..
hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again or enter . Wait for it to say "please reboot the machine", turn it off and back on. Hopefully this will work..
Jul 05, 2011 | Toshiba e-studio 455 Copier
Purchased the pink Disney Princess DVD player from KMart. When you turn it on and insert a DVD to play, screen comes up saying the Parental Controls have been set (Universal Studios picture in upper left...
lots of electrical items will use a default security code of 0000 or 1234.
if there is nothing in the manual and these codes do not work, then your best option would be to return it to the store for them to find the codes or refund/refpace the item
Feb 28, 2011 | Disney Princess MCP DVD2050P DVD Player
What does "This memory card is write-protected
On the SD card itself is a write protect switch - it's on the side. Check the switch to see if it's in the protect position.
Jan 25, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
My stereo won't work. Whenever I try to turn it on, it always turns off saying "protect." How can I fix this?
The protect has come on because it senses an output load problem, Turn the unit off, unhook the speakers and wires from the stereo, now turn the unit on and turn the volume down as far as it will go, this should reset the processor ic, if the word protect stays off you have a short in the wiring or bad speaker. If the protect comes back on with everything unhooked the problem is in the audio output ic pack in the stereo and will require a technician to remedy.
Jan 17, 2011 | JVC MX-KC58 Shelf System
I have an 06 Chevy Cobalt and I went to turn it on yesterday and all it did was click and flash the lights on the dashboard. The radio will play but the car will not start. The message board says...
boost the vehicle .carefull that the other vehicle is off when boosting.this to protect both vehicles from voltage spikes.if you have a boost pack to keep the engine running.thats the best.way to boost the car.question.is the battery over 5yrs old if so replace it first.
Jan 10, 2011 | 2006 Chevrolet Cobalt
Protect message
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Jan 11, 2009 | Samsung HTZ-510 Theater System
PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
How do i fix that i get the message on my cd play (JVC HX-D7) and it says PROTECT and shuts off by its self what do i do to fix the problem ?
Sep 27, 2008 | JVC HX-C6 Shelf System
100 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
