Question about Refrigerators
Freezer okay, fridge warm
Dear Sirs:
My freezer teperature is fine, well below zero as I have the temperature control to maximum, but the fridge temp is at about 55-60 degrees. I started by cleaning the coils, which were filthy, but no difference after a couple of days. The refrigerator seal seems to be in fine shape with no leaks (about 4 years old), and even when taping the door tightly shut overnight there is no difference. The compressor seems to be running continuously.
I am not well-versed in refrigerator operation, but there may be a fan behind the vent holes in the back of the freezer, perhaps designed to flow air into the fridge, that may have quit. I am not positive. Even if that is true, the parts list names two fan motors, and I do not know which is which (the one at the bottom of the fridge next to the compressor is still operating fine.
There are also two holes in the top of the fridge compartment that I assume should have air flowing through them but there is not. Though I can feel some ice inside the holes when checking it out, I would not say they are completely clogged. Any help would be greatly appreciated. Thank you. hello,
we have a haier top freezer model HFF518W - the freezer is still working fine, but the fridge keeps getting warm. we have also noticed water dripping/running from what appear to be vents between the freezer and the fridge compartment. we have defrosted several times and it seems to work for a few days and the go back to warming up. do you have any suggestions.
    Scholar:
  • 149 Answers
I suspect a faulty defrost heater/thermostat or defrost timer. any other questions you can e-mail me @ hvac.tech7872pr@gmail.com
Posted on Jun 15, 2008
Hiw di I set the temp to the correct temp
turn freezer to mid point and try fridge on 3.5 as a starting point.
Keep the refrigerator temperature at or below 40° F (4° C). Thefreezer temperature should be 0° F (-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these temperatures and are generally inexpensive.
press the helpful button and check link below
Fridge temperature guide Kitchen
Jan 29, 2016 | Refrigerators
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
The refrigerator ignores temperature setting.
Hello, This problem is going to be the cold control/thermostat, this part can be located in the control console inside the fridge bhind the freezer temp control knob (can also be found sometimes in the freezer depending on type/model) The reason your food in the fridge is freezing is because the thermostat controling the freezer temp is not shutting down and the air being blown into the fridge is too cold. Replace this cold control/thermostat and you should be fixed. If you have any other questions or concerns please feel free to comment again and give me some time to respond. Good luck! Mike
Sep 08, 2009 | Kenmore Refrigerators
My freezer teperature is fine, well below zero as I have the temperature control to maximum, but the fridge temp is at about 55-60 degrees. I started by cleaning the coils, which were filthy, but no...
You have already dianosed the problem. Now take that cover off in the freezer and see if you can get that fan to work, it is your problem and you can replace it IF it is bad or lube it's bushings and see if it will work a few more years. (use 3 in 1 oil) Gook luck!
Sep 08, 2009 | Haier HTE18WAA Top Freezer Refrigerator
What is the purpose of two temperature control nobs when there is a single compressor in my samsung 280 lts fridge
1.If this is only a fridge the one knob will be for the min and the other for the max.
max. : As soon as you switch the fridge on it will cool down the fridge to max cool down temp. example -2deg.
min. : As soon as the fridge reaches the max cool down temp and it had switch the compressor off, the fridge will start to warm up slowly, by the time it reaches the min allowed warming up temp, it will switch the compressor back on and do the cycle all over again.
2. If it is a fridge/freezer setup, the one knob will be for the fidge and the other for the freezer. If the temp in the freezer is fine a fan is activated and blows all the cool air to the fridge and controls the temp. by activating the fan.
Sep 06, 2009 | Refrigerators
Side by side: freezer temperature fine, fridge too warm
sounds like your auto defrost isn't working. my maytag does same thing. the cooling core in the freezer is probably iced up. when it becomes solid ice no air(or very little) can pass by, leading to too little cold air reaching the fridge. you can try to cycle the temp levers(usually doesn't work) you can manually defrost the freezer. pull the cover off the back(inside freezer) and use a blow dryer. not sure how much parts are for whirlpool. hopefully this is just a one time thing. there are tests you can find to check some of the parts.like the heat element for the defroster, just search for the tests.
Jul 30, 2009 | Whirlpool Refrigerators
The temperature controls for the refrigerator are not responding. The freezer controls respond just fine. My fridge is set to 34 and I need to get it back to 37 but it won't change the numbers.
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerator have the blower problem because for this reason only, the problem arrises ....... please visit your service authority...........have a nice day:-)
May 14, 2009 | Sub-Zero 650 / O Bottom Freezer...
Freezer will not work due to out side teperature being low
Sorry, not doable. Temp in garage below 50 degrees will cause problems with any domestic fridge or freezer. The soda machines you see outside actually have heaters in them so they can work in the winter. Hope this helps!
Jan 06, 2009 | Hoover HCA351K Bottom Freezer Refrigerator
May need defrosting, so do that, and also unplug the unit for 9 minutes, as this should reset anything that might have affected the problem. Check with Kenmore customer service department on how long the unit takes to get to a set temperature after resetting and consult your manual on your warranty options.
Mar 01, 2008 | Refrigerators
any time the compressor is running the fan in the freezer should be running now you need to empty the freezer do you see a lot of frost on the back wall of the freezer you either have a defrost problem and frost has built up so much its stalling the fan or the fan its self is bad pull the back cover off the freezer wall and tell me what you see please also give me your model number off the serial plate which should be in the fridge section put your freezer stuff in the fridge while we check it out
Jan 30, 2008 | Haier HTE18WAA Top Freezer Refrigerator
Refrigerators Logo
486 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
