Question about Brother CE5000 Computerized Sewing Machine
The needle is hiting bobin caseing i think,timeing is off.
    Genius:
  • 1,456 Answers
Hello
Make sure the needle is fitted properly and that the needle clamp is not loose. Bent or blunt needles will also cause needle breakage. If everything else is OK, make sure you have the right size needle for the thickness of the fabric. Using the wrong presser foot for different types of stitches will also cause needle breakage. Check the owner's manual or the computer screen readout to make sure you have the proper presser foot for the stitch you have programmed in.
Other causes include scratches around the hole in the needle plate, pulling the fabric too tight, a scratched bobbin case and the wrong bobbin type for the machine.
Choose the correct sized thread and needle for the fabric in question. Re-thread the machine by passing the thread through the needle bar. Hold the thread with both hands and fully pass it through the hook.
Posted on Nov 06, 2010
In my Janome Memory Craft 3000 my material got pulled into the area where my bobin thread comes from. I pulled it out. Now my needle is dragging but not breaking on the white piece underneath where you...
I would suggest replacing the needle, make sure the needle is correct for the fabric and thread being sewed.
sometimes when the fabric gets caught in the feed dog area, there are different reasons, I'll list some below
fabric is too thin--needs stabilizer
top thread has some off the thread take up lever
bobbin is turned the wrong way in the bobbin case
needle is damaged--replace needle with correct size for fabric being sewed--and insert the needle correctly into the needle holder.
if these suggestions don't help, I also suggest having the machine checked to see if there is some other problem like timing.
May 03, 2014 | Sewing Machines
My sewing machine needles keep breaking
Could be a timing issue. Is your machine a top load rotary , or a front load oscillating system, (ie. metal bobin case you put bobbin into then insert to machine, or black plastic bobbin case you "drop" your bobbin into...?
Sewing Tech
Oct 24, 2013 | Sewing Machines
Pfaff creative 2134.....needle is hitting the bobbin casing
There is two possible solutions. either the machine has been knocked out of time by a thread jam or the needle rod has been bent. Good Luck!
Apr 19, 2011 | PfaFF Sewing Machines
Needle not picking up bobbin thread. Seems threaded properly. lsd-1 (classic) Problem occurred after needle hit something perhaps the the cap spring which had some marks on it but no real damage. ...
change the needle, if bent it may skip, use top thread while holding to pull thru, turn bobin around to turn in oposite dirrection, bobins usually turn in 1 correct dirrection
Sep 28, 2009 | Sailrite Sewing Machines
Needle is hitting the bottom of the bobin hausing
It sounds for sure like the needle is not in all the way. Try inserting the needle again, it ,may have slipped when it jammed.
Mar 17, 2009 | Sewing Machines
Needle jaming and thread gathering under bobin case
when this happens to me (the needle breaking) I make it a thing to do and that is to use a qtip with a bit of oil and clean the bobbin holder and then use canned air and blow out the lint from area and this may help you. You may have a tiny tiny piece of needle left in the holder and this will play havoc with any kind of sewing machine. I have suffered through it many times before I made this a practice when needle breaks
Mar 03, 2009 | Janome Memory Craft 3000
Bobbin gets tangled up
Try taking the covers off again. Now check under and around the bobin case, thats the black plastic bit that holds the bobin. Look for any fuzz or stray bits of thread inside the machine and and around the feed dogs and under the needle too. I use compressed canned air to get in and really blow everything clean. For some reason if the machine is not totally clean, inside the bobin gets tangled up. If you have had even one knot, odds are parts of it are still floating around inside there somewhere and stopping some little lever from moving and jamming your whole machine. Clean under the bobin case too since lint can left it up and keep the bobin from being perfectly level. Also inspect your bobbin case to make sure it isn't scratched along the edge that rotates back and forth. Even a a tiny scratch will cause it jump its tracks and your bobin will lift up and become jamed. In that case you just have to buy a new bobin case. But most of the time your culprit will be some stray bits of thread or lint.
Sep 30, 2008 | Brother SE-270D Computerized Sewing...
Needle Sticks - Huskystar E10
When it feels like the needle is jammed, open the bobbin cover and release the two black retaining levers, one on either side of the bobbin case. The hook cover that is visible will be released. If the machine turns by hand smoothly, you may have a piece of the broken needle, or just a piece of thread stuck behind the hook or hook cover causing the bind. This problem will sometime make you swear that the needle is stuck in something because it will usually bind while the needle is down in the fabric.
Apr 04, 2008 | Husqvarna Viking 1
Brother CE5000 Computerized Sewing Machine Logo
56 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
