Question about Desert Spring DS3200 Humidifier
Need a replacement motor for a humidifier model # mot-ds00091
I need a fan motor for the 758 144140 Sears Kenmore Humidifier
I have a Kenmore Quiet Comfort Electronic humidifier, model 758.144140. Is missing filter holders, and float switch, so is inoperable. Motor works fine. Contact me if you want the motor - mnwilli@hotmail.com. No charge if you pay for shipping. I will include 2 filters, can include any other parts you want. Why the offer? Space in my house worth more than an inoperative appliance.
Dec 16, 2015 | Kenmore Humidifiers
Humdifier doesnt work. New solenoid valve two months ago. Water is not coming out of solenoid. Is it the transformer? Honeywell Humidifier.Model:
Check to see if there is 24 volts at the transformer when the blower motor kicks on, if not the transformer will need to be replaced. If you do have 24 volts then work you way from the transformer toward the solenoid and see where the voltage stops, could be the humidistat.
Dec 14, 2012 | Honeywell HE365 Humidifier
I NEED A REPLACEMENT FAN MOTOR. ANY INFO ON SPECIFIC CONTACTS TO PURCHASE MOTOR/
In the model number... I'm not sure of the fx and ms, but the 80 and 25 is a standard 80mm case fan that is 25mm thick. I tried a standard .2amp case fan that I had on hand and the circuit board did not like that..it got hot. I got on ebay and looked at dozens of 12v 80mm fans until I found one that was 0.09amps. That was as close as I was able to find without much more looking. The fan works very well although not quite as much airflow as the new crane humidifier that I put next to it but it doesn't overheat and does the job for about 7 bucks.
Mar 06, 2012 | Crane Frog EE-3191 1 Gallon Humidifier
Have two Hunter humidifiers - model 34357-about 5 years old #1, fan just quit running. All else seems normal. #2, Unit starts running and then stops with the humidity reading at max. Since the...
This is the manual for your de-humidifier. It lists the part number for the power and fan control switch and it states they have a 5 year warranty.
http://www.hunter-humidifiers.com/manuals/34357.pdf
This is their link for support:
http://www.hunterair.com/suppo.95rt
They have a msrp on the unit at 84.95. What I wuld do is definately check into the warranty ting with them and I'm sure you could probably salvage one ot of the two units. Replacement parts may not be cost effective. You can test the motor from #1 in #2 and, if it runs, you know it has to be a switch or a start capacitor, etc. I guess it all depends on how much tinkering you want to do. I would think there is a good chance there is a wiring diagram for the motor somewhere inside the case or on the motor. Good luck.
Dave
Jun 05, 2011 | Hunter 34357 Humidifier
I just installed a Honeywell HE 360 Humidifier I purchased at Home depot. I replaced a Aprilaire model 110 . I have a 120v power duplex that is hot with the furnace blower motor, on so I assumed the sail...
Hello, in order to turn your humidifier on with the furnace the 120 volts coming from your humidifer you must hook it up to a step down transformer, then the transformer will provide 24 volts to you humidistat and solenoid valve. So you need a wire from the HUM on your control board to transformer primary side and a wire from neutral on the board to primary side of transformer. Then you need low voltage wire from secondary side of transformer to humidistat from humidistat to humidifier.
Feb 20, 2011 | Honeywell HE360A1027 Whole House...
I have a carrier humidifier model BG49. When the furnace turns off due to reaching room temp. The water still continues to flow into the reservoir of the humidifier. Is this the correct operating...
Hello, The humidifier should turn on and off with the furnace's blower motor, If the humidifier keeps continously running than the solenoid valve is stuck open and should be replaced.
Jan 30, 2011 | Carrier LFP Humidifier
Need blower motor schematics and / or schematics for a york Controller #031-01267-001
you will need the model of the furnace not the part # of the board. is the schematic not in the unit?
Sep 25, 2009 | Honeywell Power Humidifier: Furnace...
MOTOR IS NOISE
Sounds like your motor bearings are going bad. If at all possible lubricate the motor bearings using a few drops of a NON detergent oil. If the motor has sealed bearings with no oil ports then you should replace the blower motor.
Good luck
Mar 29, 2009 | Essick Air 447 302 Console Whole House...
NEED MOTOR, EATON 416 025 20 FOR SEARS FURNACE HUMIDIFIER
It`s pretty expensive but Appliance Factory Parts has the same motor except at 24 volt and you have to use the gear from your old unit and a step down transformer..as yours is 115 volt..
Around $80 as they will combine the shipping if you call them..
Local electric motor shop repaired my 1994 motor for $35 after I explained to them I could not find a replacement..
I talked to Sears repair service man, he said our units are too expensive to produce today but are better than these new high flow models they use allot of water that just goes down your drain..
Mar 17, 2009 | Humidifiers
Humidifiers Logo
499 people viewed this question
Top Desert Spring Humidifiers Experts
Mack Baxter
Dennis
Are you a Desert Spring Humidifier Expert? Answer questions, earn points and help others
