Question about Kitchen Ranges
I have had my Crosley freezer a little over a year and it needs defrosted. Some how I lost the booklet that came with it and I do not know how to defrost it.
  • 10,865 Answers
Hello. No problem. Here is a link to the step by step method to do this necessary task. Joe
http://www.ehow.com/how_93_defrost-freezer.html
4 thumbs up please. ty.
Posted on Nov 06, 2010
My crosley CFUFH17LW0 upright freezer display shows OF and I can't get it to come on
Good Afternoon Sherry, thank you for your post!
I understand that your Crosley freezer is displaying an "OF" and will not come on. An "OF" error code means that the freezer is off. In order to turn the freezer on you need to press the up arrow three times within five seconds. It should start up and you should be able to change the temperature on the front panel. If your freezer does not start you may need to perform a reset on your freezer and you can do that by unplugging the power cord for at least ten minutes. I hope this information is helpful for you. -Matt
Jun 07, 2015 | Crosley CFUM17LW 17.1 cu. ft. Upright...
I had just submitted a question in regards to my Amana Freezer not keeping the food frozen and the coils freezing up to the point that we have had to defrost the freezer twice in the past 3 months.
Non defrosting units are a thing of the past, almost all fridges made in the last 20 years are self-defrosting. If the coils are freezing up, what kind of ice is it? Clear ice near the bottom indicates your defrost drain is clogged. Snowy, fluffy ice indicates the defrost system is the problem. Make sure the fan in the freezer is blowing freely. Then check the continuity of the defrost heating element. If its OK, the limit switch is bad. If its not replace the defrost heater. Also don't overlook the possibility the door gasket is leaking, allowing warm moist air in that condenses on the coils! To check a gasket, insert a dollar bill between the door and the gasket, close door on bill, pull bill out, if good resistance gasket is good, if little or no resistance gasket is bad or needs adjusting.Do this teas all the way around each door.
Aug 10, 2014 | Amana Refrigerators
Our Crosley CS20 refrigerator/freezer has been dripping water on the floor and the bottom of the freezer has been full of ice. We defrosted the freezer, taking everything out of it, and saw there was ice...
Defrost drain is frozen. Poor hot water around it until it is clear. You will most likely have to take inside back wall of freezer off to access defrost drain. While you have it off, inspect metal pan to be sure holes aren't rusted in it. Some are aluminum, but some are steel.
Sep 05, 2017 | Crosley Refrigerators
My freezer keeps freezing frost and causing my fridge not to work. dont know what to do. nothing is staying cold.
let me help.(^..^} u
1 defrost thermostat bad
2 defrost timer bad.
3 i need u tell me what brand name and model #
4 good luck.
Jan 12, 2011 | Crosley Refrigerators
Defrosted a Crosley freezer, have water draining from door
ITS RARE BUT NOT UNUSUAL,its only condensate from the surrounding room collecting inside a cold door frame,if you dont defrost it at least twice a year,you will loose efficiency.
Jul 05, 2010 | Freezers
Have lost instruction booklet and do not know how to defrost.
Easiest solution is to get an ice chest and put all your frozen items in it and turn the unit off or unplug it and leave the door open and let it defrost itself. If you really want to speed it along use a hair dryer to speed up the process. Or put a circulating fan in front of it and put it on high facing the inside of the freezer.
Remember folks KISS, "Keep it simple stupid"
And No I'm not saying anyone is stupid.
Mar 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
We purchased an upright freezer on Friday. It has not stopped running since. The store manager told me it was supposed to do that. They also said they do not have a booklet for it and that it was in good...
yes this unit will run a lot of the time it has no defrost so you will need to defrost every 6 /12 months do not use knifes or scraper... just unplug and open door untill all frost is gone... hope it helps
Sep 01, 2008 | GE Refrigerators
Fridge not cold
ice build-up on the back wall indicates a defrost issue, check the defrost items. check the defrost timer, the defrost heater and the defrost thermostat, if you need more details let me know.
Apr 02, 2008 | Haier HTE18WAA Top Freezer Refrigerator
Hotpoint future RFA60 Fidge Freezer
I have lost the instruction booklet for my Fridge Freezer RFA60. How do I defrost the freezer?
Nov 04, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Sides of freezer extremely hot
if there is air getting into the freezer because the door is not sealing properly the unit will run because it is sensing it is not cold enough inside. your unit releses the heat from the refrigerant through copper tubing that runs through the cabinet, and thats why it is hot. you need to level the unit make sure the door is sealing on the top bottom and both sides ansd then the freezer will work properly and be able to shut off after it has come down to the proper temp.
Aug 05, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
