Question about Radio Communications
Cobra 29ltd cb radio
My cb really transmit good.but it don't receive very well.i have a wilson 5000 antenna new coax cable.i have it hooked up to the battery
    Problem Solver:
  • 13 Answers
The above suggestions are great I just wanted to add that if you can check the impedance or the ""match of the antenna to the radio. All CB antennas have roughly 50 Ohm impedance to match the output of the CB radio. The impedance is not critical as 25 Ohms to 100 Ohms is acceptable. Best signal transfer occurs at 50 Ohms, so every design is optimized very close to 50 Ohms. You can do this with an SWR meter. Anything from 1 to 2.5 is good, 1 being the best. You can get these meters for pretty cheap. I've seen them on ebay for $10 and you can get a new one for around $25. This isn't really going to help you with receiving but it can keep you from burning up the radio when you transmit and will help you get out better. While this isn't exactly waht you were asking about, I just wanted to let you know since you are setting up an antenna. You can adjust the match by loosening the screw on the coil and moving the antenna up or down. Check the SWR at both ch 1 and ch 40. Ideally you want the same at both ch's. If Channel 1 has a higher SWR, loosen the screw and lengthen the whip. If Channel 40 has a higher SWR, loosen the screw and shorten the whip. When the SWR at both is as close as you can get it, tighten the screw all the way.
Posted on Jun 15, 2008
    Brigadier General:
  • 6,966 Answers
A couple of suggestions:
1. verify that the RF Gain is maximum clockwise;
2. verify that the ANL or noise limiter is OFF;
3. pls add a ground strap from the body of the Cobra 29LTD to the chassis/GND of the vehicle or to your house GND connection;
4. Verify that your Wilson 5000 has a sufficient ground plane such as roof or metal objects.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
What kind of coaxe and antenna should I get and should I mount it on my pick-up . have a used 29LX.
I have a wilson 5000 on a 4 mag setup.18ft of coax and a 1 to 2 match on all channels. I also have a 29 lx radio .
Jul 03, 2014 | Cobra 29 LTD CB Radio
Bought a new cobra Every time mike is keyed it reads antenna warning Radio will transmit short distance and will on receive short distance Very short Cobra 29 L X B T LCD CB radio
The antenna warning is the key, the swr on the antenna/feedline is very high. check antenna connections, coax and connectors for damage
Apr 10, 2014 | Radio Communications
I have a Cobra 29ltd CB with no sound coming from the internal or external speakers. So I went out and bought another Cobra 29ltd thinking that the old one was shot. Hooked up the new one and the same...
are you using the antennas that are installed thru the mirrors or the ones on the side of the truck. If you are using them you should make sure that they are connected to the coax. some just get thrown together ,antenna to mount then one end of coax to ??? so take a multi meter and set it on x1.Touch bottom of the antenna and the connector that come out of the dash. If you are connected you should get a reading. If you are not ,then you will have a problem hearing anyone because you are not connected to the antenna but the coax. If the connection is good to go then I would try running a ground wire to the chassie and maybe even a ground strap.
Mar 09, 2013 | Radio Communications
Cb antenna warning
If your readings are below 0.5 with a dipole that is a excellent swr reading, most fall in the area of 2.0 or higher, you will not harm your RF output transistor, if you are getting antenna warnings see if you can recalibrate it.
May 04, 2012 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
-wilson antenna installation diagrams for, Wilson Trucker2000 - display pictures of exactly, how antennas appear when being attached with coax cable, using stud mount between coax & antenna mount... -...
I have a wilson 5000 mirror mount. I mount it on the drivers side mirror on the upper cross arm that goes to the mirror. It is mounted on this arm with a bracket and a so 239 connector so I can undo it if I have to ,leaving the antenna connected.I can change coax and not have to worry about undoing the antenna. Remember one thing. The antenna has to be checked for SWR.each time you move it to a different spot or to a different truck.
Oct 11, 2011 | Cobra 29 LTD CB Radio
Cb radio
As for me ,the Wilson 1000 or Wilson 2000 are the best mobile antenna for a mobile. I have out talked a lot of base antennas with them, just put it on the top of car in the center or trunk, or middle of cab of truck, with a good SWR and you are talking and receiving. great antenna. ...hope this helps..
Jun 01, 2010 | Cobra 29 LTD CB Radio
I have acobra classic 29ltd key mike ant lights up replaced stud
First thing, you need to check your SWR, you must have a SWR meter to do this. If you are a trucker, you can get it checked at any CB shack, radio shack, etc, they will check it for free. Next, make sure the antenna driven element is clear of any metal blockage, and that it is getting a good ground at the base, don't know what kind of antenna you using, but the Wilson 1000 is a good one to use, install in midle of cab.........hope this was helpful.....
May 28, 2010 | Cobra 29 LTD CB Radio
Cobra 29 LTD Classic not transmitting or receiving
ant. light should only come on if you have a high vswr a bad thing did you check that cb/pa switch is set to cb check your swr this is not a good place to mount ant. as it is close to metal of back of cab
Dec 20, 2008 | Cobra 29 LTD CB Radio
New Cobra 29 ltd
Appreciate the direct "Ask Me". If I may clear up your concern:
  • you have two CB radios, one is a Cobra 29LTD and the other?
  • both have received and both do not transmit;
  • you have two trucks, one with a Firecracker 1000 antenna, and the other?
In any case and initially, TX (transmit problems) could be caused by:
  • defective PTT/mic;
  • defective finals/drivers;
  • defective PL-259 connector/RG58 Cable;
  • antenna grounding/SWR;
  • other electronics internally
Please check the above. You may need an SWR meter, a watt meter and a DVM/VOM to perform the tests.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Cobra 29 LTD CB Radio
Cobra 29GTL Won't Transmit
if the red ant light comes on this means that you have antenna trouble either in the antenna itself or the coax but this should not have anything to do with the radio not transmitting. it sounds to me that you have a bad audio chip or a bad power output transistor. in either case you should really take it to a cb shop and let the professionals solve your problem, good luck!!
Aug 16, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
185 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
