Question about Dryers
My dryer motor is running but the drum is not tumbling and i have a burning smell coming from the dryer when i turn it on
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 07, 2010
My Maytag Performa Dryer model PDET920AYW will heat but drum will not turn. Belt is not broken. Can you help?
It is possible that the motor start/run capacitor has failed, rendering the motor unable to get going. The capacitor will look something like this
http://como-reparar.com/guides/tumble-dryer-turning-find-fault-replace-motor-capacitor/
Jun 16, 2015 | Maytag Dryers
NO DRUM ACTION ON MY TDC30 BUT DO GET HEAT
When you start the dryer does it sound as if it is running but it does not tumble? Or does it make a humming noise?
If it sounds like it's running I'd check the belt first,
Humming noise and burning smell Dan indicate a bad motor or something stuck in blower wheel.
Oct 18, 2014 | Hotpoint Dryers
Kenmore 11062612101
From your description, the dryer belt could be in need of replacement. The burning smell could come from the motor pulley spinning and trying get a grip to turn the drum.
Dec 20, 2013 | Kenmore series 70 80 90 Dryer Motor...
Lg condensor tumble dryer c740045E, stopped turning, belt is fine, but a burning smell is coming from the motor, and smoke.
heatman101
Aug 18, 2011 | LG Dryers
Crosley dryer..it squeeked we oiled the pullys
Did it smell like burnt rubber or maybe plastic burning? After you try to run it for about 10 seconds (and it won't run) then you touch the motor (with the dryer unplugged) it is hot?
It sounds like the brushes could be dirty due to the lag you placed on the dryer when it was installed incorrectly possibly.
OR
While it is plugged in, are the lights coming on in the dryer when you open it?
It could be a fuse if it has no electric going to it (the light does not turn on)
OR
Will the drum spin if you attempt to turn it manually?
THe pulley or another item on the belt system could have burned (ruined) when it was installed incorrectly.
Try to walk through each piece of the system that was affected by teh incorrect installation and see if there may be an item that is not working correctly; this could be an easy fix.
Hope this helps
Sep 06, 2009 | Crosley CDE6000 Electric Dryer
DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Whirlpool Ultimate care ii Dryer wont tumble
If your dryer doesn't tumble, check these:
Belt,
Motor,
Door switch.
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
Remove the belt,
Check for obstructions in the blower fan housing,
Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Dryer does not tumble, but heats up
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
if this helps please vote me a fix ya
Jul 15, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Feb 16, 2008 | Dryers
Dryers Logo
142 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
