Question about GE Microwave Ovens
I have a GE microwave modle JVM1460WA 001. My problem is the lights over the range are no longer working. All other functions are fine the display will say what setting the lights are at Nite light or Bright or low but the lights stay off regaurdless of setting. I had to replace diode and magnetron 6 to 8 months ago and now this is going on with the lights. Is their a fuse or do I need to replace the control board to resolve this problem. If I have to replace/repair the board please include part number or how to go about getting the board fixed if possible. Thank You!
rickzilla
  • 706 Answers
SOURCE: GE Spacemaker Model No. JVM1650AB 003
Hello Diana,
Here is a link to the GE User manual for your microwave oven.. Once you download it.. You will find a section on light bulb replacement that details how to install and which particular bulbs to use..Hope this helps you..
http://genet.geappliances.com/DocSearch/pdf/49400821.PDF
Good Luck !
Posted on Sep 14, 2008
AlmostBob
  • 550 Answers
SOURCE: fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Posted on Oct 14, 2008
SOURCE: New GE Magnetron. Where does this new HV diode go?
Fixed it. There was a back capacitor fuse (I believe that's what it's called) on the old magnetron. I removed it and put it on the new magnetron. The HV diode is on the big silver capacitor and very easy to replace. I just didn't see it. It was definitely the magnetron and I hope that this new one comes with a warranty for 5 more years.
Posted on Dec 01, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: My GE XL1800 does not heat. We didn't have any odd
I gather that GE would replace the part under warranty but you need to pay labor? $200 to replace a magnetron seems way out of line just for labor.
The magnetron is the most likely part to cause your symptom. Capacitors and diodes usually fail by shorting, and cause the oven to make loud humming noises or blow the fuse. But the trouble might also be due to the control circuit board, either bad parts or solder connections.
Unless you have the proper tools and experience, trying to diagnose where the trouble is can be very hazardous. There are lethal voltages present with the cover off and the oven operating. You should leave the repair to a professional. An independent shop might be able to diagnose the problem and give you an estimate for a lower charge, and then you could decide whether to repair or replace.
Posted on Mar 27, 2010
Testimonial: "Thank you so much for your help. A+"
SOURCE: Magnetron will not run. I
You have replaced all those and still no go, well, In that case the main controller board is most likely faulty too. This is common, for the controller board and or power supply has been spiked.
Posted on Feb 01, 2011
Microwave will not heat
The problem is the magnetron, "heart of the microwave oven" or the inverter board if 7 years old or less.
Apr 19, 2012 | GE Spacemaker Over-the-Range Microwave
Need exact dimensions of GE JVM1460
If this link does not work paste it into a search window and then click the link:
JVM1460WA-GE Profileā„¢ SpacemakerXL 1.4 Cu. Ft. Microwave Oven
GO to this link: http://www.geappliances.com/service_and_support/literature
Then type in the model JVM1460SA001
15 & 3/4" high 16 & 1/2" hole required for vent connection in rear
15" deep
Needs a 30 inch wide hole for installation
Thanks for choosing FixYa,
Kelly
Aug 14, 2011 | Microwave Ovens
Ge spacemaker jvm1653 sho1 display disappears while cooking and shutsdown microwave.Reset display and would function fine for a while. Started to happen once in while now so frequent that oven no longer...
See this FixYa solution. even if your model number is different.
Sep 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
l'l'l'l'l'l'l'l'l'l'l'l'
Aug 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My JVM1460WA just stopped working. No display at all. What could be the problem?
Check the fuse ...
Dont tough the silver can inside. Remove the cover, find the fuse on the floor. Check it for contunity.
Oct 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Microwave Ovens Logo
110 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
