Question about Car Audio & Video
Which wire is the memory - Car Audio & Video
    Sniper:
  • 58 Answers
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps.
Posted on Nov 08, 2010
I have a lanzar stearo DVD and GPS and it does not hold it's memory
It has a power wire and a memory wire on the back of radio. Usually yellow for memory wire. The memory wire has to be connected to a constant hot wire 12v
Jul 08, 2014 | Car Audio & Video
2005 Mustang GT radio defaults
You are loosing power to the keep alive memory circuit of the radio. I think you may have a defective ignition starter switch. Also there are two hot wires to the radio, one powers the radio, one holds memory and is called the Keep Alive Memory constant power wire. Here is the wiring colors, pull the radio and check the memory power supply wire.
Radio Constant (keep alive memory) 12V+ Wire: Light Green/Purple wire
Oct 31, 2012 | Ford Cars & Trucks
Car deck memory issue
Is the fuse blown on the memory wire from the decks wiring harness. Also, makes sure memory wire and accessory wire are not flip flop.
May 24, 2012 | JVC Car Audio & Video
The memory isnt woking what color wire is used for memory?
yellow is the memory wire. it needs to go to a constant power source.
Jul 26, 2010 | Kenwood KVT-717DVD Car DVD Player
Which color is the memory wire im tired of resetting time and audio configurations plz help
basically you have a power wire which should be wired to a switched connection and a memory wire which should be wired to a unswiched connection. look on your fuse box under the dash and connect the power wire first to a switched fuse (one that shuts off the radio when you turn off key) then look for a fuse (with same power wire )that when you turn off the key the radio stays on, this is the fuse that you connect the memory to,or you can connect the memory wire directly to the battery but you must use an inline fuse or you burn up your radio,car etc.
Jul 05, 2010 | JVC KD-G120 CD Player
I have a 1999 nissan sentra gxe limited edition and i put a kenwood aftermarket cd player in it and it wont keep memory do you know what the problem is cause the stock cd player kept memory
more than likey u dont have the memory wire wired correctly...chk the memory wire it should b an orange wire make sur eit is hookd to a continus power supply...if not then everytime u turn off the car it will reset..i have my memory wire wired with my red power wire
Feb 13, 2010 | Car Audio & Video
Do the jvs have a memory wire. I tryin to put this in a 2001 nissan altima. I need to know if the car have a memory wire for this redio.
You need to hook up the yellow wire from JVC to the yellow/green wire in car(12+ constant memory) and the red wire from JVC to purple from car(switched 12+ volt accessory)
Hope this gets you tuned in!
Oct 23, 2009 | JVC AM FM CD DET FACE CAR STEREO
What is the color of the memory wire to a jensen vm9312?
Yellow wire in main wire harness is constant 12v positive. That is your memory wire.
Jan 21, 2009 | Jensen's VM9312 Car DVD Player
Memory wire color
assume the memory wire for teh radio ??? use a test meter to find a permanant 12v feed or run one from the fuse panel for radio memory
Dec 15, 2008 | 2000 Dodge Caravan
Radio problem... need a memory set to the radio
Use a 12 volt DC test light, or a DC voltmeter & probe until you find one wire/terminal that has power constantly, whether key is on or off. That's the one to join it to, for your memory. Your radio power wire will go to the other unless you want to be able to have your radio working all the time when you turn it on, regardless of whether key is on,or accessory position, and if that's your preference, join it to same.
Nov 23, 2008 | 2004 Jeep Liberty
Car Audio & Video Logo
47 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
