Question about Polaroid LCD-2050 20 in. Television
My polaroid tv turns and picture comes on but is snowy. you can see the stuff on tv but is multi colored snow. sound plays fine. i have already replaced the 2 caps on power board about a year ago. when i took the power board off this time 1 other cap was swollen so i replaced that but did not fix the problem.
cbinny1
  • 64 Answers
SOURCE: Polaroid LCD TV FLM-3232 turns on, then turns off
It sounds like you have tried everything I have been able to find on the web......Have you Registered your TV with Polaroid yet? Because if you haven?t you can make up the few months your past on the warrantee.....I would go and Register and then call on the warrantee.....it?s a bit fishy but it works...In my opinion they should just warrantee it for you. (being so close to the end an all) ....I have had great success when I have call the manufactory directly to see what they can do for me......don?t talk to just any one ask for the manager of customer service or the manager in the warrantee department...in the very begging of your call.... here is there information if you didn?t have it already Regional Headquarters: Polaroid Corporation Corporate Headquarters 300 Baker Avenue Concord, MA 01742-2131 Phone: +1 781-386-2000 Good Luck and be assertive but not an *** on the phone.......I find that when I?m just strait up honest with them it all works out....If it doesn?t try the Registration thing?Let me know if this helped cbinny1
Posted on Oct 22, 2008
SOURCE: 37" polaroid lcd tv won't turn on
Here's the fix:
http://www.fixya.com/support/t293971-37_polaroid_lcd_tv_turn
I had the same problem with mine. Replaced the capacitors and now it works. When you open the back of the tv up, the problem is with the 2 capacitors on the upper left of the top card. Mine didn't look damaged except for a very, very slight bulge on the top. If you've never soldered anything, you might want to take it to someone who has, otherwise, it's a pretty simple fix. I was surprised I could do it so easily.
If the warranty is still good, make Polaroid replace it. They make shoddy products and should pay for it. And never buy another Polaroid again.
Posted on Oct 30, 2008
  • 7 Answers
SOURCE: Polaroid Bad Caps
Same thing that made the Power Supply go in the first place. something is shorted most likely
Also, make sure that you replace the protective cover or parts will short and cause this
Or, you have a bad processor board which is very common in these sets
Jonathan
Posted on Nov 04, 2008
SOURCE: No Power to LCD Tv
I have the same problem Polaroid 37" flm 323b, I did change the cap on my tv and they did look ok, I still went and change it. I got two Polaroid working, take the extra step and change those two cap.
Posted on Apr 07, 2009
SOURCE: POLAROID FLM-2601 - PLEASE READ !
display circuit board
Posted on Aug 13, 2009
What is causing snowing reception on all inputs on my LCD TV.
it can be fix, do u know hw to work with a multi meter? if no, take it to a colifield techni
Jun 03, 2015 | Samsung Televison & Video
Picture settings
check your colour stings on tv and if you dont have a dish that is where your snow comes from
May 17, 2013 | RCA 46 46LA45RQ LCD TV
Sony KDL-V32XBR1 Displays only snowy picture
Here are a few more troubleshooting steps you can try when your TV picture is just snow. I see that you have already rebooted your TV, but did you turn your set-top box off and on, too?
1. Does the picture show when you play a DVD?
2. Check all of the connections between the TV, outlet and set-top box and make sure everything is secured.
3. Is your TV set to the correct channel (typically 3, but in some areas 2 or 4)?
4. Press any key on the remote to see if the correct mode lights up. (Ex: if you have cable, the cable button should light up). If it doesn't, press the correct mode's button to regain control and change channels.
5. Call your service provider and make sure it's not an overall service outage.
6. Do you have sound but no picture? If so, it could mean a backlight failure.
For more suggestions, see TV black screen or snowy screen for troubleshooting and solutions. I hope this helps!
Sep 20, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I have auto programmed the television, but it only shows white snow no matter what. I have also fine tuned it as well. The model is shownic lc26ce80r. Can you help
My personal guess would be that there is no signal coming through to your tv or the wrong signal coming through. I have the opposite problem...we get picture (snowy) but no sound except that of snow and the Audio/Sound options are NOT helpful. Wish I could be of better help.
Jan 28, 2011 | JVC AV-20220 TV
Samsung LN-S3241D HDTV LCD snowy display
The main board may cause this problem. If it wass happened when you play DVD, so the main board needs replacing.
Aug 16, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Snowy screen just pops up
Bad tuner in tv....might be possible to solder bad connect in
tuner...........T.
Dec 14, 2007 | Hitachi 43FDX01B TV
Hitachi screen goes snowy and sound is totally distorted
Sounds like bad solder connect in tv tuner....can usually be
repaired or replaced.......................T.
Nov 30, 2007 | Hitachi 43FDX01B TV
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Multi color snow
The most common problems with Panasonic's is the "DG" board. It usually is not the leat expensive module to replace and cannot be repaired it has to be replaced.
May 02, 2007 | Panasonic PT-51HX40 51" Rear Projection...
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
Polaroid LCD-2050 20 in. Television Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
