Most auto parts stores have a solution for this problem. Explain the situation to them, they will sell you a self-tapping drain plug that cuts new threads. This will replace your OEM drain plug. I have used them several times, they work if directions are followed. These drain plug replacements usually come in 1, 2, and 3 "oversize" sizes. Not difficult to install, not expensive. Good luck.
The dealer would replace the oil pan instead of fixing the threads.
I remove the oil pan,and silver braze a nut,the same thead as the OE Drain Plug, inside.
You could get a used oil pan
Maybe tap to a larger size,drain plug
Mine always break the spot welds,leaving you with no threads
