Question about Kenmore 15208 Mechanical Sewing Machine
My Kenmore sewing machine Model #15208 isn't working properly. The needle won't pull the thread up from the bobbin and the crank is turning hard.
I have Kenmore Mod#15208 machine i want to know how to open shuttle driver is not moving
Posted on Feb 11, 2013
bargainbox
  • 1388 Answers
SOURCE: bobbin threading
You may have put the timing out, however, try this before you despair too much......
Ensure the presser foot is firm enough for the fabric you are using and that it will not just pull through easily by hand with the foot and feeddogs together (as the needle ascends), or things will not proceed, and you will be stitching in the same spot.
Generally a setting of 3 seems to work for general purposes, but if you are using very light or very heavy fabric, a sample is always a good idea before you start in earnest....also match the needle to the work for best results.
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
  • 13 Answers
SOURCE: can't get top thread to pull up bobbin thread on my sewing machine
Try the regular first steps of change the needle make sure the flat side of the needle goes to the back and is all the way in. From there try rethreading the machine from scratch. If none of these work it may be the timing from the needle to the hook of the machine but start easy first.
Posted on Aug 27, 2008
SOURCE: Janome Memory Craft 9500 Troubleshooting
The solution that I found last night was the thread tension. I have never touched the dial, only had it set on 'auto." When I started playing with it, I realized the top thread should be really easy to pull through the machine and it wasn't. I started turning the dial (to 3 or 4) and the thread slid through the machine perfectly. No more birds nest! I really thought it was bobbin initially because of the horrible sound it was making.
Posted on Jun 05, 2008
louislevel_2
  • 374 Answers
SOURCE: Unable to get bobbin to pick up thread from needle.
Check the thread coming out from the bobbins maybe on reverse side,also check the bobbins tension adjust it there is a small adjusting screw.Check also the needle alignment lastly check the upper tension from the tension regulator knob,tension adjustment is depend on the fabrics that you sew.
Posted on Mar 07, 2009
Mongo32
  • 111 Answers
SOURCE: Singer 8280 bobbin thread not taken up by needle
needle in backwards?
Posted on Jul 08, 2009
I need help on how to thread machine model 117-812 kenmore sewing machine
Thread, thread guide, thead guide, tension, take up lever, thread guide, thread guide, needle.
Aug 24, 2013 | Kenmore 15208 Mechanical Sewing Machine
I only want to know if the wheel must be loosened to wind the bobbin and if so with direction, to the front or backwards and press and turn or pull and turn.thanks
Which make and model sewing machine do you have?
None of my sewing machines need the wheel to be loosened for bobbin winding. The Singer Touch & Sew bobbins are filled in place. Use the handwheel to get the needle into the highest position (just turn the wheel). Wrap the top thread around the screw that holds the presser foot; open the slide plate part way and press the bobbin wind button. Hold the top thread and then begin winding by stepping on the foot pedal.. The thread should break after a few winds.
The Kenmore and the Husqvarna Vikings both get wound at the top. Place bobbin on winding pin. With the needle up and metal presser foot in place thread the top thread up to the bobbin (through the guides) and up through the hole in the bobbin. Slide the bobbin winding switch over towards the bobbin. Hold the thread tightly and begin winding (step on the foot control). After a few winds are on the bobbin, cut the thread that you were holding flush with the top of the bobbin. Continue winding the bobbin. (The newest Viking in the group has a computer screen; on that one, do not press OK until done winding the bobbin.)
However, if the handwheel is not turning and the needle is down, first find out why it isn't turning properly. This could indicate a tangle of thread somewhere in the system. (The older Husqvarna sewing machine in my home has a non-functional handwheel. The machine will still sew but you have to use the needle up/down switch that forces the needle to stop in the up position before you run out of bobbin.)
Please add a comment with the specifics of your sewing machine and I'll be glad to add additional information.
I hope this helps.
Feb 28, 2012 | Sewing Machines
I bought my daughter a White sew E-Z so she can have fun on her first sewing machine. However there is no manual and no instructions on how to thread the bobin. the bobin just sits on its flat side to go...
Check the model number of the machine. White sewing machine manuals are available from Singer at http://www.singerco.com/accessories/instruction-manuals . Enter the model number and click Search.
The White Sew E-Z model W338 manual is available here: http://www.singerco.com/uploads/download/705_white-338-x.pdf .
Unlike some machines this one doesn't really need the bobbin threaded. Place the bobbin in the bobbin holder and leave about 5" of thread extended out from the bobbin holder. With the bobbin compartment still open, lower the presser foot and turn the handwheel to move the threaded needle through the stitch cycle. (I find holding the threads helps; normally, you'll feel them pulling under your fingers.) When the needle has returned to the top of the path, lift the presser foot. Then pull both threads around to the front (the bobbin thread should wrap around the top thread). Then move the threads to the back of the presser foot.
If the needle isn't catching the bobbin thread, first try a new needle (bent or dull needles don't always function properly). Next check the bobbin holder for nicks or other damage. There is a small hook on the bobbin holder that should be where the top and bottom threads intertwine. Under rare circumstances, you will find that the bobbin tension of the bobbin holder is misadjusted. This can interfere with the bobbin thread twisting properly. There is a little set screw that allows you can tighten or loosen the bobbin tension as needed. Adjusting the screw is to be avoided when possible and done in small increments (1/8 turn) if needed. It's easy to strip the threads for the set screw and end up needing to replace the bobbin holder.
I hope this helps.
Jul 13, 2011 | White Sewing Sewing Machines
My bobbin thread keeps breaking off
Check that upper thread is correctly threaded and has proper tension.
Check bobbin tension.
Check that bobbin is installed correctly.
If those things don't work we'll go from there.
Aug 23, 2010 | Kenmore 15208 Mechanical Sewing Machine
Top thread gets caught on crescent piece holding in bobbin case
If you have the manual take a better look at how to put the bobbin in the case,
sounds like you are putting it in wrong,
make sure you put the bobbin in with the thread com-ming off the bobbin in the right direction (left or right) if not put in the right way you will get what you are saying
ALSO: bring up the bobbin thread your self by turning the hand wheal and bring the thread a few inches to the back of the needle and hold when starting to sew the first 2-5 stitches.
when you do not hold the thread the machine will pull the thread in the bobbin area and cause problems.
you will get use to holding and it will get easier.
hope this helps
Sep 03, 2009 | Kenmore 15208 Mechanical Sewing Machine
Thread is bunching up around the bobbin casing
On the bobbin case is a small screw if it is to loose the thread won't feed like it should make sure that screw is tight but not so tight you can't get the thread through it. Also check to make sure you have threaded the top right. hope that helps
Oct 14, 2008 | Kenmore 15208 Mechanical Sewing Machine
Needle won't grab bobbin thread
Check the position of the needle. Some machines have to have the needle in a certain way or they won't pick up the thread from the bobbin. Make sure the screw on the bobbin is tight but not to tight you may have to adjust it a few times to get it where it needs to be. Also make sure the bobbin is wound tight
Jun 17, 2008 | Kenmore 15208 Mechanical Sewing Machine
Instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Jun 05, 2008 | Kenmore Sewing Machines
Kenmore Sewing Machine model # c877.15
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Kenmore 15208 Mechanical Sewing Machine Logo
108 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
