Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
GE PRofile Artica cabinet depth side by side. So many problems - the water line in the door freezes solid, making it impossible to get ice or water -any items in the refrigerator bins freeze solid. I have thrown away tons of ruined vegetables! -every morning I have what amou8nts to an orange joice slurpee thanks to that almost freeziong too ( on the top shelf of the fridge). Help- had it "fixed" 3 times by GE repair people back in 2006. Never were the problems solved then, and am getting tired of living this way!
  • 23 Answers
SOURCE: ice maker not working
check your owners manual for a water filter, make sure trip arm isn't stuck closed and not letting water in to freeze.
Posted on Dec 08, 2007
  • 85 Answers
SOURCE: Water spout to ice maker frozen
defrost ice maker fill tube and replace duel water valve valve for i/m is sepping water
Posted on Dec 15, 2008
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
jumptrout51
  • 3361 Answers
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Posted on Feb 21, 2009
SOURCE: No ice or water from GE Profile side by side refrigerator freeze
I had this problem and did 3 things to correct it:
1st: I changed out the Main Circuit Board in the back of the fridge.... very easy to do, but that wasn't the problem.
2nd: I changed out the Dispenser Circuit board, which is behind the touch panel. Also very easy to do, just snaps out. but that also wasn't the problem
3rd: I checked the wire harness connection point located behind the grill at the bottom front of the fridge underneath the freezer side. This is also very easy to do, and son of a ..... that is what is was. Moister from mopping the floor had started to corrode the connections. So I purchases a cheap 3 wire plug and cut out the old and spliced in the new. You don’t actually need the plug, you can hard wire direct but if you ever have to take the door off you will have to cut the wires.
So now I’m the proud owner of an extra functioning Main Circuit Board and Dispenser Circuit board if anyone is in need.
Nick
Posted on Aug 07, 2009
GE Artica no water, no ice, Checked water supply to solenoid OK
did u check water line after solenoids. could be a vaccum or u could have bad solenoids, not opening to allow water to go into box, try ok.
Feb 12, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Temperature in refrigerator will not stay set. It keeps getting colder. I have a GE Artica model PSS27SGMD. It is a side by side with ice through the door. It is +- 9 years old
GE Artica had problems with the "Motherboards" originally installed. They have since switched manufacturers so my educated guess that is the problem.
Jan 08, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE profile Artica, MDL# psc23mgnabb, ice maker won't make ice, plus refrigerator side is freezing the contents
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 27, 2010 | GE Profile PFS22 33" Artica French Door...
I have a GE Profile refrigerator Model # PSC23MGTC it has an Artica Water & Ice dispenser on the freezer door, the ice will not come out, and noew the water works only when it wants to, I think I need...
Cut and paste this Factory Service manual for your refrigerator.
The troubleshooting guide will help locate the bad part.
http://appliancejunk.com/ge/refrigerator/31-9072.pdf
Aug 08, 2010 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
I have a GE Profile ARtica side by side. Ice maker is acting up
The dispensor door not closing completely . Replace the flap solenoid and plunger behind the dispensor controls .
Aug 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE PFS22SISBSS Refrig compatment freezing
There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
Dec 21, 2008 | GE Profile PFS22 33" Artica French Door...
Ice maker not working
Dec 08, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
