Question about Toshiba Satellite L455S5980 Notebook
How to fix broken spring in left touchpad key
  • robesontom Nov 09, 2010
    Thank you! I will try this tonight and let you know how it goes.
    Tom
    Brigadier General:
  • 8,909 Answers
Remove all of the screws from the base of the laptop.
Place your fingernails from your index fingers behind the plastic cover next to the on button and lift the plastic strip up and out.
Remove the two screws holding the keyboard down and remove carefully, disconnecting the flat cable.
Remove the plastic top, complete with touchpad and disconnect cables as you go.
Examine the underside of the top with the touchpad and remove the touchpad.
use a soldering iron and melt the plastic over the broken plastic hinge to fuse the plastic back together.
Check and reassemble as required.
I trust that will fix your problem.
Posted on Nov 06, 2010
Testimonial: "Thank you very much, very clear instructions, I was able to fix my button as you described."
    Thanks! I will try this tonight and let you know how it goes.
    Tom
  • specialistel Nov 09, 2010
    Pleased to be of assistance.
My niece clicked random buttons on my keyboard and now my left-click does not work. What can I do to fix this issue?
If all other touchpad functions work, then my guess is that the left click key is broken. The only thing that "random key pressing" might do on a laptop is to activate the touchpad disable in which case NONE of the touchpad functions would work.
Dec 31, 2014 | Toshiba Satellite L855D-S5220 Laptop
How to fix touchpad
What's wrong with the touchpad? Rather than fix it if it is broken just replace it. In fact you can replace the whole palmrest which includes the touchpad that does not cost a lot.
Maybe you turned the touch pad off.
Click Start/Control Panel and look for the Mouse and open it to check the mouse properties. Make sure you don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on the button that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upper left hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press and Hold the ALT or FN function key located at the lower left portion of the keyboard, then hit the key that toggles the touchpad. The correct key to hit will have the icon of a finger pointing at a square that represents the touchpad.
Maybe you just need to reinstall the touchpad drivers.
Get online and got to www.google.com In the google search box type: "Acer Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Touchpad drivers.
May 13, 2012 | Computers & Internet
Touchpad won't work
May 13, 2012 | Toshiba Satellite M65-S9092 PC Notebook
I need a left touchpad key. the plastic tab underneath is broken off. It is a hp dv5. can you help me?
Just try to fix the broken one their by any drop of solution or take your notebook to the hp service center wont cost you much..
Jul 16, 2010 | HP Compaq 6820s Business Notebook
My 99 Explorer Sport driver side door lock will not unlock using remote, key, outside touchpad or inside control. The plunger goes about halfway up then relocks. There is a broken spring inside the lock...
yes you do have to take the panel off and i wouldnt go for the spring just yet- the door lock actuator itself coluld be bad... if the spring is broke it is part of the latch, serviced as an assembly. hope this helps and good luck
Jul 14, 2009 | 1999 Ford Explorer
Dv6000 touchpad left mouse clicker
I WORKED FOR HP LOOK ON EBAY YOU WILL FIND IT LOOK FOR HP TOUCHPAD PARTS
Apr 14, 2009 | HP Pavilion dv6000z PC Notebook
Left key on mouse of dell laptop does not spring back as should
I have a Dell L400 with a similar problem plus it does not function when pressed . I removed the top cover and removed the tiny flat circuit board w the touchpad ( careful as the plastic is quite thin)
and gave the left key contact a good spray of non-petroleum base switch cleaner. it works fine after assembling but still sits lower. the spring tension is gone so I stuck a tiny piece of soft felt between the plastic key and switch and it looks almost like new. hope that helps you
Mar 20, 2009 | Dell Computers & Internet
Dell Inspiron 640M E1405 Touchpad Issue
OK, it's not THAT difficult to replace the mouse button. I didn't have the ambition to follow Frumper's suggestion of replacing the little rubber dome with a spring, but there are a number of these available on ebay for under $30. If you're lucky, you'll find the whole top plate with the touchpad and mouse buttons - that saves a little time. But the disassembly/reassembly isn't too bad - there's a pdf of the disassembly process out on the web somewhere; if a google doesn't find it I can send it along. Basically, there are a LOT of little steps, and of course, everything is tiny and fragile. But what it entails is removing all the screws from the bottom of the machine - except for the two under the battery, they're identical. Don't forget the ones under the modem and CPU covers. Remove the 4 screws holding down the heatsink to the cpu. Pop out the hard drive. On the top side, pry off the plate with the power button, GENTLY remove the LCD plug and the 2 backlight connections. Then you can remove the 4 screws that hold the LCD assembly in place - put it somewhere safe! The keyboard will pop right up - be careful with the keyboard connection, the connector hinges, whereas most of the others have a locking key. With the keyboard out of the way, there are a final 4 screws holding the palmrest in place. When they're removed, disconnect the ribbon wires and just pry gently around the edge - starting at the back - and the whole palmrest will come off. If you've got a new palmrest assembly, you're ready to reassemble. If you've just got the mouse buttons, you'll have to remove the (4?) screws holding the front subframe to the palmrest, and a couple more ribbon connectors. Be VERY gentle with all the ribbon wires, and it goes back together very simply. I've done this a few times now; the first one took about 2 hours as I tried real hard not to break anything. Now they go in well under an hour. Like Frumpy said, not for the faint of heart, but not exactly rocket science either. Good luck!
Dec 03, 2008 | Dell F3534 Touchpad
Dell Inspiron 640M left touchpad key on palmrest has lost its action
You can check the manual at support.dell.com. Click on 'Product support' on the left and click manuals. Choose your model and click 'view html'. click Palmrest. and it will show you how to reinstall it or get underneath the keys. If it seems defective, you can get the palmrest (which includes the keys and touchpad) from dell's spare parts sales at 877372335.
Jul 21, 2008 | Dell F3534 Touchpad
Touchpad button loose
I shouldnt think that opening it up is necessary. The button should click back in with a gentle nudge. Else it is broken and needs to be replaced. If you can take it out completely and examine it you will know if it is broken.
Sep 30, 2007 | Acer Aspire 5100-5033 Notebook
Toshiba Satellite L455S5980 Notebook Logo
298 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
