Question about RCA Lyra Slider SL5016 Digital Media Player
Lyra slider has a white screen and i can hardly see it
When I try to sync my old LYRA slider SL5008-B on my new computer running windows 8.1, the computer asks me to enter a passcode for the device? where is the passcode?
if you are using bluetooth, you need to sync the devices. One device should search for the other (make the other one visible to searches), select the device to link to and it should prompt you to enter a code that the other device generates on the spot.
Feb 02, 2014 | RCA Lyra Slider SL5008 MP3 Player
Hi, the scren is white. i can't see nothing
My screen is white with a black spot in the middle. I cant see anything
Sep 06, 2011 | RCA Lyra Slider SL5008 MP3 Player
I can not get videos onto my lyra slider. The videos are on the computer but I can not get them to take to the mp3
Have you converted them to mp4 format? Most mp3/mp4 players require converting of the video files in order to play.
Feb 04, 2010 | RCA Lyra Slider SL5008 MP3 Player
Where is the software to install on computer
The software installer is located on the device. Go to My Computer and find the drive letter associated with your player (Lyra Slider). Open the drive and find the file called "rcaeasyRip_setup.exe". Run this file to launch the easyRip installer.
Can't find the installer?
Visit this URL to download the installer file (Note: You will need the device connected to your PC while installing easyRip)
http://voxrightnow.custhelp.com/app/answers/detail/a_id/2253
Jan 26, 2010 | RCA Lyra Slider SL5008 MP3 Player
Need help with lyra slider mp3
There are a couple options:
Option 1: There should have been a file on the player that you can access through Windows Explorer (My Computer, click on the dirve that is your player) that should be named: RCAeasyRip_setup.exe
If you do not have this file, it can be downloaded from the RCA site here:
Run this file to install the RCA easyRip software that allows you to manage your media (both on your PC and your device). Use the Player Library module in easyRip to view the contents of your device and you can select files for deletion.
Option 2: Go to My Computer, find the drive letter associated with your device (Lyra Slider) and simply find media on there that you want to remove, and delete it.
Jan 13, 2010 | RCA Lyra Slider SL5008 MP3 Player
Not working at all
The clicking noise is a symptom of a damaged hard drive.
This mean that the only solution is to replace the hard drive.
Your best option is to buy a partially working X3000 media player and use its hard drive to fix the one you have, or have somebody in finding the specific 1.8" 20GB hard drive your mp3 player has, but also such person will need the booting and firmware files to put them in the new hard drive, otherwise it won't work.
Best regards,
Aug 11, 2008 | RCA Lyra X3000 MP3 Player
White Screen
Hi,I am Bidzoni and i think i now whats hapend whit your Lyra(THINK).My problem is not same bat,my display got some strange line. I just watch inside (of course i opened it}my Lyra and when removed hdd and  touch broad wire on the moment the screen is normal.So I THINK you must change the BRAD WIRE. I dont now where you will bye it and i dont now are you brave to do it yourself. Sorry my english is bad and i tired to translate .bidzoni@gmail.com  Let me now what happend after.Good luck
Aug 14, 2007 | Thomson Lyra PDP2860 Digital Media Player
RCA Lyra Slider SL5016  Digital Media Player Logo
44 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
