Question about Cuisinart CBK-200 Bread Maker
Cuisinart breadmaker displays E00 when i press the start/stop
    Genius:
  • Cuisinart Master
  • 1,280 Answers
That means that your ambient temperature is too cold to bake bread (page 17 of your manual). That means you may have been storing it in the garage and brought it inside. Recommend you put some hot tap water about half full and let close the lid and let is sit for for about 20 minutes. Then try pushing the start button and see if the warning is gone. If so pour out the water and bake your bread.
Please rate/vote for this answer or even better leave a testimonial ...thanks!
Posted on Nov 06, 2010
How do i override the delay start function
According to page four of the manual linked below, you can simply hit START after selecting 1. Menu item, 2. Crust colour, 3. Loaf size, 4. Mix-ins, 5. START or Delay Start Timer.
If the bread machine is running, and you wish to overide the Delay Start Timer, NOTE down the other options selected for Bread Type, Crust Colour, Loaf Size and Mix-ins; then press and HOLD the STOP/PAUSE key for 3+ seconds to re-initiate the breadmaking process. Re-enter the options, and re-start the breadmaker using no Delay Start Timer (Hit START in step 5.) or enter a new Delay Start time and then hit start
https://www.cuisinart.com/share/pdf/manuals/cbk-200.pdf
Feb 15, 2015 | Cuisinart CBK-200 Bread Maker
Display
Your breadmaker should be under warranty. If I were you I would call Cuisinart
Dec 05, 2012 | Cuisinart CBK-100 2-lb. Bread Maker with...
Pressed wrong menu option baking french selected basic/white
I gather you need to re-set? If so holding the start button till the display goes blank often helps
Oct 11, 2011 | Cuisinart CBK-200 Bread Maker
I have a convection bread maker. I made one loaf of bread tonight and i unplugged the machine. 30 minutes later, I tried to make a second loaf ant the menu select wouldn't work but the start and mix in...
Cuisinart has many different bread machine models. Next time you ask a question, please include a model number. Thank you.
Here's my generic best advice for you dear:
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on toggle power switch. Turn it to the ON position.
    2. Some models confirm power by making and audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press and hold the Select button down until the unit powers up.
    5. Some models require you press and hold the Start button down until the unit powers up.
    6. Some models require you select a mode first by pressing the Select button.
    7. Some models require you press and hold the Stop button down until the unit powers up.
Were you able to confirm that your breadmaker is receiving power?
No. Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
Yes, Fantastic! Now reboot the breadmaker's electronics by pressing and holding down the Stop button down until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press and hold the Start button. Others require you press and hold the Select button.
Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You'll need to disassemble the breadmaker to visually confirm.
Jun 13, 2011 | Cuisinart Kitchen Appliances - Others
How can I change a setting after I have pressed the Start button? I need to change from 2 lb. to 1 1/2 lb. Thanx
Usually holding the start button down for few seconds will clear the display and enable you to start again.
Feb 14, 2011 | Cuisinart CBK-200 Bread Maker
I pressed the start button, not having chosen the correct menu setting! Now, I don't know how to change the menu setting!
push the stop button until it beeps and then unplug it. .....if this works please leave me a ranking...Thanks!
Oct 11, 2010 | Cuisinart CBK-200 Bread Maker
No display on the screen. Start and Mix in LED's are on. Have tried the 15 min unplug / reset several times. No response from any buttons???
Try holding down the stop button for more than 3 seconds. This may be able to reset the unit. You do not have to unplug it for 15 minutes to reset it, just hold down the stop button.
Nov 25, 2009 | Cuisinart CBK-200 Bread Maker
Cuisinart CBK-200 Turn on flashes 3:15 and won't let me choose another menu I thought it was becuase I pressed start prior to picking another menu option so turned off the poiwer for 15minutes to flush out...
This is normal behavior for this breadmaker to default to 3:15 - just press and release the MENU button a few times to advance through the menu options. If it is "stuck" and won't advance through the menu options, hold in the stop/pause button for almost 15 seconds until the machine resets back to 3:15. THEN, press and release the MENU button a few times to make your selection.
Jul 28, 2009 | Cuisinart CBK-200 Bread Maker
Unable to canceal program if I accidently hit start
The easy way is to press and hold the stop/pause button for about 15 seconds - the fast reset.
Jul 22, 2009 | Cuisinart CBK-200 Bread Maker
How do i remove the bread pan from the machine it is cuisinart bread maker
 Grasp pan handle with a potholder, press down on outrer housing,lift handle sharply releasing pan .Now who can tell me how to stop my CBK200 from burning each& every loaf?        Dave from Succasunna,N.J.
Dec 11, 2008 | Cuisinart CBK-200 Bread Maker
Cuisinart CBK-200 Bread Maker Logo
115 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
