Question about RCA RS2041 Neo-5 CD Changer Audio System Shelf System
The disc compartment doesn't open when press the open/close button. I can hear the changer motor and the trays sliding, When I try to pry the disc compartment open, I can see that disc tray #3's position is much further back than other trays. I have pulled the tray forward, but it returns to the prior position. Whenever I turn the system on or off, I can hear the CD changer moving the trays in and out, but compartment does not open. This happens when the source is set to tuner (default). The changer has always moved the trays when I press the power button. When I moved a few months ago, I neglected to remove several CDs from the changer. Until I set up the system in my new place, the system lay on its back for 2 months. According to the user manual, I should not have left CDs in or stored it on its back. It worked just fine prior to the move. What can be done if anything? Please advise, Susan
    Genius:
  • 1,456 Answers
Hello
Find a blank disc or a disc that you don't use anymore. Insert this disc about an inch deep into the slot where the discs go in.
Now, move the disc gently sideways while pushing the eject button repeatedly until the discs come out. If this doesn't work, move on
Contact the manufacturer if the CD player is still under warranty. Remember, if you try to open the player, you will be voiding its manufacturer's warranty.
If it's not under any warranty. You have to replace the motor that ejects the discs.
Posted on Nov 06, 2010
Cd tray closes quickly without pressing switch on Technics SL-pd688
There is a small switch under the tray that stops the motor at the end of it's travel, also one when the tray goes back in.
These can have wires broke off or can be stuck or open circuit
Jun 19, 2014 | Technics SL-PD8 5-Disc CD Changer
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
Hi - the CD tray cannot open. It is empty - no CDs in there. I hear a buzz, but an "error" message comes on. I tried pushing on the tray while turning on; I unplgged the CD player, I put it on...
The loading tray belt has more than likely stretched or snapped.
The buzzing you hear will be the motor spinning freely.
The 'ERROR' message will show up because the tray isn't opening
and activating the 'tray open' switch, therefore the 'tray closed' switch
is permanently activated after the 'open/close button is pressed.
Aug 20, 2011 | Marantz CC-4300 5-Disc CD Changer
Cd was still player and I found the player with drawer half open and jammed. I can't get it to sync with correct rotation, enough rotation or fully close or fully open. I can force it and hear the gears...
Rea alligning cds is not hard, but not too easy,the best way is to remove the whole cd changer mechanism and allign it to either one point,while totally disconnected, fully open or fully closed. I mean, the rubber or gear mechanism.
The main point of reference is the nearest part driven by the main motor. For example decide to do it when fully open, arrange everything so as to allow the tray to be fully open.If you get everything right, rotate the motor manually and see if it closes the tray without jamming..If it gets fully in keep rotating the motor and see if it loads the disc.if it does, return the assembkly, the sensors and the cd computer will take over from there ...
Apr 12, 2017 | Sony CDP-C445 5-Disc CD Changer
How to open the DVD Player compartment door if the remote does not work?
There a button on the right side of the disc tray said open/close press this button ur disc tray will open manually.Press it again it will close.
Apr 27, 2010 | Televison & Video
Onkyo C-707chx cd tray jammed won't open won't play
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Jun 07, 2009 | Onkyo DX-C390 6-Disc CD Changer
Door to load cd's wont open or close without help.
hello i have had the same problem with my 5 cd changer,i way i solved this was to turn the player top slide down then do this care fully ,shake it gently and see if a cd came out of it, groove sit in the player.if you hear a rattle than there is a stray cd in the device. you have got to shake the cd to the front of the cd dawer to take it out with a thin ruler or a butter knife but be care ful with the knife preess on the open button wale trying to slide the butter knife between the stuck cd and the inside of the cd sit cation be care.
Apr 25, 2009 | Audio Players & Recorders
DVD tray will not open.
The disc is dislodged and jamming the drawer. You have to remove the cover, about three, maybe four screws, and then take the disc out to resolve the problem.
Regards,
Worldvet
Jun 15, 2008 | Zenith XBV442 DVD Player/VCR
Hi All
I had a similar problem with my fathers XBV342, my problem was that the DVD tray would open but when a disc was inserted it would close then open again time after time.
I took the top off of the unit and the front cover fascia panel off then checked the tray movement, I found that the belt for the tray motor located near the front of the tray was loose, which meant that the motor did not raise the drive motor to its correct location, which in turn didn't allow the motor to turn the disc, this causes the tray to open again, I guess it thinks it has a misaligned disc and ejects the tray, I hope this helps someone.
Jun 03, 2007 | Zenith XBV342 DVD Player/VCR
RCA RS2041 Neo-5 CD Changer Audio System Shelf System Logo
478 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
