Question about Fishman Audio Players & Recorders
I have a Fishman pre-amp mod MKAB Acoustic Base Optimized in a Michael Kelly Dragonfly 5FL TBK.. as soon as the plug is pushed in the jack, the battery lite on the amp flashes for an instant , then goes off, I'm not sure if it should stay on all the time OR if it acts like a warning light when the battery voltage goes low. Either way, there is no audio output. Would appreciate any assistance befor eI trouble shoot further. I am a tech so its always wise to ask an expert....... thanks, jerry
Most acoustic/electric pre-amp's red light comes on when the battery is low & ready to die. The red light flashes when you put the jack in because the battery light takes a fraction of a second to proccess. If the red light flashes off & on when you push on the pre-amp, it is probably because you are causing the battery connector to short or disconnect giving the pre-amp low voltage so the red light comnes on.
Posted on Feb 21, 2012
Crackling through amp occasionally
There are only a few things that could be responsible for your problem. Dirty volume knob on guitar or amp. Faulty ground on all affected parts; including cables. I suggest you plug into a different amp with a new chord, and see if the problem still exists. This way you can quickly eliminate compnents & focus on the actua lproblematic one. If it still exists..you can assume it'sin the pick-up.
Dec 06, 2012 | Fishman Rare Earth Single Coil Acoustic...
What's your problem?I have two Fishman amps.The older Loudbox 100 single channel and a Loudbox mini. I am trying to find the service manual for the older fishman as I have a fault with it and the
Fishman iis you best bet http://www.fishman.com
You can download the user manuals, they do have a block diagram, but the scan is pretty bad.
It may end up the person looking at it is going to need to rely upon their general knowledge.
My own suggestion is to pull the chassis out so you can work on it while powering it. And then work your way through the amp with either a signal source plugged in at the input, and with high impedance headphones with test lead ends, go through each audio stage carefully. until the fault is isolated. If it is not caps or the rectifiers in the power supply, faulty ground connections to chassis or faceplate, a faulty 4558 is most probable. The headphone approach is the fastest way to address this last one. If a different series of preamp chip is used, a good source for the IC datasheets in general is Digikey http://www.digikey.com and parts too.
Feb 05, 2012 | Fishman Loudbox 100 Acoustic Guitar...
Low volume from Fishman Loudbox Mini mic input, using brand new XLR cable and dynamic mic. Mic works just fine on instrument input using a Hi-Z cable so problem is not mik
I have seen defective XLR cables so check it with an ohmmeter. It is possible the mic input preamp has been damaged. If that is the case, the unit will have to be repaired.
Aug 31, 2011 | Fishman Loudbox Mini Acoustic Amplifier...
I bought a second hand Fishman LoudBox Performer. The problem is that the Aux-in for the headphone doesn't work. So sick... What can I do? tnx
I don't understand your question. The "Aux in" is just that an input that goes to the power amp. Please note that the Fishman Loudbox does NOT have a headphone jack so don't be disappointed as there plain isn't a headphone jack on this unit. I would recommend that you get a small headphone amplifier for the purpose... or even go to a thrift store and get an old stereo system that has a headphone jack and use that.
Aug 01, 2011 | Fishman Loudbox Performer Amp Acoustic
When I plug it into my amp there is a staticy
yes there probably is a dry jopint on the wiring or the jack input isnt tight enough also the battery connector could have a dry solder or looose connection I would go for it if the price is low and just spend a few bob to solder it or check the connections.Good Luck
Sep 29, 2009 | Fishman PRO EQ Platinum Bass Preamp...
541 people viewed this question
Top Fishman Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Fishman Audio Player and Recorder Expert? Answer questions, earn points and help others
