Question about Kenmore 64882 Electric Dryer
Won't turn on when I push the button? Dryer has been working it won't due anything when I push the button
  • Kenmore Master
  • 1,344 Answers
Chances are you have a bad motor control fuse has gone bad. This is located in the back of the dryer. Standing from behind it, take the back off and once that is done look to your lower left side and you'll see a white piece a plastic thats long and thin and has wires going to it,. On some models this may be located in the front bottom of the machine, but only in models where the front is not all one piece, but has two sections. When you located this fuse, take a ohm meter and check for continuity. If you have none the fuse is bad. Another way to check this is by unplugging the wires and connecting them together (with the machine unplugged of course) then plug the machine in, and press start. If the machine starts the fuse was bad. Before any of this be sure to check the breaker by cycling it. Just because it doesn't look tripped doesnt mean it isn't.
Posted on Nov 06, 2010
Model lde8414ace maytag dryer
There is something causing the drive motor to bog down. This means the fan isnt spinning fast enough and the whole unit is overheating. Check for anything around the edges of the drum, coins keys etc. The squeal is the belt from the drum being stuck. See how hard it is to turn by hand.
Jul 08, 2013 | Dryers
Dryer won't come on
I would first look around the dryer for reasons it died. I would remove and inspect the vent pipe to outside for blockage. I would check the door switch for an audible click and springy movement. I would look into the filter housing for signs of lint buildup. All dryers pretty much work the same. MORE HERE
Dec 07, 2012 | Dryers
Dryer won't turn over/start. When push start switch makes noise but won't turn. If hold door closed switch and turn manually while pushing start button it would work for awhile, but that has...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Amana Dryers
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My maytag dryer got to hot heating a blanket and now it won't work at all. When u push the power button I feel it wanting to kick in but it won't do anything!! I know nothing about dryers Help...
heatman101
Jul 04, 2011 | Maytag Dryers
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
My Kenmore dryer won't stay on when you push the start button it starts and turns off real quick. I have gotten new fuses and replaced them and it still won't work.
heatman101
Jun 01, 2011 | Dryers
When we push the button to start dryer it buzzes, it won't go and won't dry clothes. maytag admiral dryer ADG7005AWW
heatman101
May 19, 2011 | Maytag ADG7005AWW Gas Dryer
My dryer won,t start. When you set the timer and turned the starter on you hear a sound that seems it will run but when you let go the starter it just won/t run
You have a bad motor. There should be a button you can press to make your dryer go while the door is open. Hold that and push the button in and then turn the drum. if that doesn't make it go then it is your motor
Apr 18, 2011 | Frigidaire Dryers
Kenmore 64882 Electric Dryer Logo
70 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
