Question about GE Dryers
How do i get a new belt around the drum of a GE dde5200 dryer?
yalmer
  • 549 Answers
SOURCE: How to replace drum belt.
Opening the cabinet and removing the drum of GE dryer models
Note:
Disconnect the power source to your dryer before you begin to remove the drum. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Pull your dryer out from the wall. Behind it, on the bottom, you will find a lower panel that will give you access to the unit's belt tensioner (also known as an idler pulley arm). Remove the screws holding this panel in place, and then remove the panel itself. Reach inside and release the belt tension by removing the belt from the motor pinion.
Older GE dryer models have a small drum bearing inspection plate in the center of the back of the dryer. This drum bearing inspection plate provides access to the dryer's circlip (also known as an e-ring). This clip holds the rear drum shaft in place. Newer models do not have this circlip or the drum bearing inspection plate.
If yours is an older GE model with an inspection plate, remove the plate now. It will be held in place with a single screw. With the plate removed, you will be able to see the drum support shaft and the e-ring (circlip) holding the shaft in place. Use a small screwdriver to remove the e-ring. You may also want to use a magnet to keep the circlip from falling into the dryer. You will also find several metal and nylon shims between the bearing and the e-ring, inside the bearing, and between the bearing and the drum. Take careful note of how they come off so that you will be able to put them back on again in the right order.
Now remove the front panel of the dryer. There are a couple of different ways this is accomplished. Whichever method you use is dependent upon your model. Some older models have two spring catch clips under the cabinet top, one on the left side, and one on the right side of the front. Use a putty knife, or some other flat and thin object to wedge in under the cabinet top. Release both spring catches and lift the cabinet top off the dryer. In some newer models, there will be screws joining the cabinet front panel to the cabinet top. You will have to open the door in order to find these screws. Once they are found, remove them and then slide the cabinet top forward and lift it off the unit.
Next, there are two screws located in the bottom of the front panel, one in each corner. Loosen these, but do not remove them just yet. Locate and remove the two screws at the top inside of the dryer's front panel. Again, there is one screw in each corner. Proceed to remove the other two screws you have just loosened. Disconnect the door switch wires and then lift the front panel off your dryer. With the front panel removed, lift the drum and slide it out of the dryer.
NOTE: In some models, you will have to remove the dryer drum glides before you can remove the drum. Also, now that the interior of your dryer is completely exposed, it might be a good time to vacuum out all of the dust and lint that has built up in there.
Posted on Feb 05, 2008
  • 619 Answers
SOURCE: broken belt
Hi , in replacing belt try to trace where belt way to go outside remove some bolts be sure unplug power , in putting back belt is the same way go in to install belt.
Posted on Feb 21, 2008
mikedurland
  • 481 Answers
SOURCE: Fitting new drum belt to Simpson Dryer
it all depends on the brand of the dryer. go here for diagrams for a bunch of brands.
http://www.repairclinic.com/0079.asp
Posted on Jul 06, 2008
Illeagle
  • 525 Answers
SOURCE: GE Dryer makes an intermittent noise when drum is turning with clothes
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided. Here are some things to look for:
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
  • 417 Answers
SOURCE: Zanussi Tumble dryer belt replacement
Yes, that sounds about right.
Posted on Oct 11, 2008
Replace Belt on DPVH890GJMV
You will need to pop open the top where you see the belt that turns the drum. The belt is removed from the spring loaded tensioner pulley at the base of the dryer. Then you can lift the drum out to put on the new belt, position around the tensioner pulley and drum and then button up.
Oct 27, 2013 | GE Dryers
Step by step instructions on how to install clothes dryer belt
First you take the top off by opening the door. There are two screws in the top part. Second there are two screws that hold the front on, on both sides. You take them out. Finally, this is a important step, remember how the belt goes back on. The Idler controls the tension on the belt. Next after the tension is remove the drum out. Put the new belt around the drum and then around the motor pulley. Then move the idler to the right I think and the move the belt past the idler and that will gain your tension.
Nov 28, 2009 | GE Dryers
HOW TO INSTALL BELT FOR GE DRYER OR WHAT THE DIAGRAM FOR BELT FOR GE DRYER
Take the top off. There will be 2 screws on each side where the front is hooked to the body. Unscrew them. The whole front comes loose along with the drum. Put the belt around the roller and under the roller support, then around the drum. Was easier then you thought huh.
Oct 10, 2009 | GE DVLR223 Dryers
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
I have a GE Dryer Serial #GL228541G Model DD25310 BAC WH. I am trying to replace the belt around the drum. I tried hooking the belt around the hooks to tighten the belt, but the drum is not turning.
Does the motor run? The path of the belt is a little tricky. You have to push a loop of the belt around the belt tightener and then over the motor pulley. The top of the belt loop will ride against either a rolling wheel, or a plastic guide made out of low friction plastic. The bottom of the loop of belt should only go over to the drum. The tensioner is held in place by a tab that fits into the bottom pan of the dryer.
Jun 24, 2009 | Dryers
Need a btlt route so i can put the new drum back in my ge profile
route the belt around the drum, pull the spring loaded idler pulley to the postion that requires you to hold it there..
put the belt : 1 through the motor pulley and around the idler pulley, or 2. around the idler pulley which ever works to keep the tensioner tight. (Idler pulley, tensioner same thing its the pulley not on the motor.
Once you put the belt on the durm, pull the idler pull so there is tension on it it should be clear how it goes.
Doc
Feb 08, 2009 | GE Profile Harmony DPGT750EC Electric...
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Belt broke on GE Dryer model #DDE7500BALWH
You will need a WE12X82P belt, or just a WE12x82 (the P stands for packaged)
  • Disconnect power
  • Remove screws under the front edge of the dryer top
  • Swing top up and remove one screw from each side panel holding the dryer front, near the top of the dryer.
  • Pull dryer front forward a bit and lift off bottom pegs. Swing to the side. (no need to disconnect wires if you don't want to)
  • Put belt around drum, lifting drum a bit to get belt past drum support slides on the bottom side.
  • Check to make sure drum slides are not worn through, especially the one on the left side.
  • The grooved side of the belt touches the drum
  • Belt runs from drum directly to motor pulley on the left side, then around belt tensioning wheel and back to the drum.
  • Turn the drum a revolution or two (counter clockwise) before reassembly.
Oct 04, 2008 | Dryers
Dryers Logo
63 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
