Question about Daewoo DTQ-13P2FC 13" TV
How to reset my sharp 21V1-L unlock code - Daewoo DTQ-13P2FC 13" TV
How to reset sharp 21V1-L eeprom
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Aug 20, 2016 | Sharp Televison & Video
How do i find password of my 21V1-L Sharp tv?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 13, 2015 | Sharp Televison & Video
HOW DO I USE RCA REMOTE TO PROGRAM MY SHARP TV 21V1-L MODEL
Read the directions that came with the set/remote. If unavailable go to manufacturers web site for support and download copy of manual.
Mar 10, 2015 | Sharp 21" Multi System Stereo TV
Sharp tv code for 2010 tv model# 21v1-l
0286,0288,0281,0285. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Nov 21, 2014 | Sharp Televison & Video
To make it a system reset, you have to enter its service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 13, 2014 | Sharp Televison & Video
Sharp model 21V1-L 19 tv
The TV has been locked. Refer its user manual to get details about the default passcode.
Jul 25, 2013 | Televison & Video
Sharp 21v1-l unlock code
sharp tv 21v1 l codenumber
Mar 09, 2013 | Daewoo DTQ-13P2FC 13" TV
How to remove sharp tv password 21V1-N
These are the general proceedings to unlock a locked TV. If you can't unlock by any of the following stated methods, you must enter its 'service mode' option to unlock it. If you wish to know how to enter the service mode, check this link. Before visiting this site, try these.
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Feb 07, 2013 | Televison & Video
Daewoo DTQ-13P2FC 13" TV Logo
559 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
