I need to log into my router to open up a UPnP port for a game, but when I type the router number 192.168.0.1 into the url, it just takes me to Plixa and a bunch of ads by google. I've searched the internet and it all tells me the same thing. My router is a Linksys E2000 wire-less. It told me I might need to plug the cable into my laptop though and later change the administration settings to wire-less. I don't know where to find my router settings or administration settings. Please help.
sandrew
  • 2961 Answers
SOURCE: exactly ASUS WL-500g, no internet connection
My advice and personal experiences with both wired and wireless connectivity, is if you wish to share files and internet connection, purchase a combined Modem/Router and not a seperate router to work along side your original modem. Your modem will send your router an ip address in turn your pc is sent one from your router and can get complicated; keep it simple! These are much easier to set up and control as one unit and if there are ever any connection problems you will know it's either a setting or a modem/router problem and not have to wonder ; is it the modem?; Router? settings? etc. As there are frequent loss of connections both internet and LAN it makes sense have one peice of equipment to maintain.
Posted on Dec 22, 2006
SOURCE: Administrator log in problem
Log in using the account name "Administrator".
If you do not have the password, reset it and try again.
Another option is to use " runas /USER: admnistrator install.exe " in a cmd window.
to launch the install program under admin account.
Posted on Nov 09, 2007
  • 4 Answers
SOURCE: Problem in opening the links !
Do you use a router, or are you connecting the modem straight to the laptop?
Does the modem have multiple plugs for computers to plug into (if so, it is functioning as a router as well.?
Do you have any firewall/internet security software installed?
My guess without the above information would be that it is a problem with your DNS setting. Open "Network Connections" and right click on your "Local area connection" and go to properties. Click on the "Internet Protocol (TCP/IP" entry and click properties. Be sure that it is set up to "Obtain DNS server address automatically"
Posted on Nov 13, 2007
SOURCE: BEFSR81 admin problem when enabled uPNP
I actually FOUND the solution at the linksys community forum site. It's weird, and I quote [kiefmoon], "I beat my head against this issue for the past few months, for the same reason as you: I'd built out a Windows Home Server, which can configure a home router automatically via UPnP, so I happily enabled it on the router, only to be locked out of the web-based configuration page.
Good news though! I just figured out the cause of the issue -- and it's really dumb:
You turn on UPnP on the Passwords tab, right? Well, if you look around on that page, you'll notice that, along with the option to enable UPnP, there are two password fields filled with asterisks. I think most people would assume that if they don't change anything in those fields, then click Apply, that the password has not been changed. And they'd be wrong. I don't know what the password gets changed to at that point, but it's not "admin".
...So the fix is: when you enable UPnP, do yourself a favor and enter a password in those fields (ideally something sronger than "admin" ). That way, you'll actually know what the password is when you get prompted for it."
Posted on Jun 16, 2008
  • 7 Answers
SOURCE: cant log into accout, Im the administrator ,it tells me wrong password
turn on pc...hold down f8...boot to safe mode...login using 'ADMINISTRATOR' account...open control panel...change ur old account password...then restart pc...n login to old account using new password...
Posted on Sep 14, 2008
Needs nat type open
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Regards
Tom
Jan 27, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
I have strict nat type and would like to change the nat type to open for my ps3 gaming online experience to be better. myfriends have trouble connecting to me and i have the same vise versa.
You need to access your router and set uPnP to enabled.
to do this you have yo use your browser to access the router - the address for the router will be an Internet Protocol (IP) address.
Log into the router and select uPnP (usually on the security or advanced option)
if you let me know the make and model of your router I can give you more specific instructions.
If your router does not have a uPnP option (and this is very unlikely) again let me know and I can give you detail on port forwarding and how to do it.
Jan 07, 2011 | Belkin (F5D8231-4) Wireless Router...
How do i change NAt type to a lower type
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 06, 2011 | Netopia 2247NWG-VGx Wireless Router...
Want to set nat type to open
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 05, 2011 | NetGear DGN2000 Wireless Router
I have a Linksys WRT160N wireless broadband router. When I get on Xbox Live it says that I have a strict NAT type and I want an open NAT type. I have already enabled the DMZ, UPnP, and put in the proper...
try this :
1. Log into the router using 192.168.01. or 192.168.1.1
this is done using a browser window such as Internet Explorer or Firefox.
2. go to Application & Gaming
3. In the box on the right column us wan to enter the device ( example: Xbox)
4. you need to enter the start and end port next ( example: 88 and 80
5. then your protocol ( example: tcp ,UDP, or both
6.the IP address if next
7.check enable
8. then save
9. here is the site with an example page to configure your router.http://homecommunity.cisco.com/t5/Wireless-Routers/Xbox-360-NAT-issues-solved-WRT160N-v3/m-p/310658?comm_cc=HSus&comm_lang=en#M163159
Aug 21, 2010 | Linksys WRT160N Wireless Router
How to configure the UPNP in panasonic camera?If we need access from the internet should we register in viewnet.com?
To access your camera from the Internet you will need to configure uPnP (or configure port forwarding manually) and register with some kind of dns service like viewnetcam (or know your home's external IP address assigned by your Internet Service Provider).
1. To configure uPnP on your camera, look in the network settings for an automatic network configuration option - this will trigger the camera to talk to your router using uPnP to set up port forwarding. The default for one camera is to use port 80 for the outside port and something like 192.168.1.253 for the internal network address (internal to your home only). uPnP will try to configure the second and third cameras to external ports 50000 or 50001. My router failed to configure the 3rd camera so I had to manually add a port forwarding option from my router's admin pages. To note, you can configure all port forwarding manually from within the router admin pages. Just list the internal network address to your camera (like 192.168.2.253) and specify a different port for each camera (like 50000 to 50000). You can then access your camera by typing in 192.168.2.253:5000
2. Then, you should register with viewnetcam.com. Adding your cameras on viewnetcam will give you access to them from outside your house without you having to know the IP address to your home network. You will simply type in your viewnetcam url with ":" and the port number (like username.viewnetcam.com:50000).
Note: When trying to access your camera from outside your home (or even pinging your router from outside your home), you need to know the IP address of your home. This is assigned by your Internet Service Provided and can change every time you reboot your modem. Services like viewnetcam keep track of the IP address to your home and update it automatically when it changes (your camera will communicate with Viewnetcam servers occasionally to update the IP address). All you have to remember is one constant URL (the viewnetcam url) and you can get to your cameras!
Aug 14, 2010 | Panasonic BL-C131 Network Camera
L can get into xboxlive but it come up your nat type is strict peopleon network with this nat type may not be able to join certain games or hear other people while playing online for the best online...
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
Apr 08, 2010 | Microsoft Xbox 360 Elite Console - Black
How do i change my nat type from strict to open on a linksys befsr41 router i've tried all the solutions xbox live and bungie has told me to try except for buying a different router or changing service...
Under applications and gaming, you will want to select upnp forwarding and then you can enter whatever custom application you want to be allowed in or out.Upnp can also be set automatically from the Administration menu.
You will need to know which ports to use, usually you can get these from the software developer, such as bungie. You can also use the application name, but I find the numbers easier to work with.
Jun 29, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Cant open ports in elephant with router thomson TG585v7
You need to log on to the router using the default gateway.
Go to Start menu -> Accessories -> Command Prompt
type ipconfig
Note the default gateway
open your browser, in the address bar type in the default gateway ip address - like 192.168.1.254 --- or whatever the IP is.
That should open your router config pages... if it asks you for a user name and password... default usernames depend on your ISP usually, but try for the username Admin, admin, Administrator, administrator and for the password try the same as the username or leave blank... If you have no luck contact your ISP for logging on details.
A web page will open - go to
Toolbox
Game And Application Sharing
At top right click configure
Make sure UPnP and Extended Security are selected if you have those options
Then at the bottom
Create a New Game or Application
from there you just need to select which protocols you need to work with or select ANY
Enter the port you want opened
and add the same port number to the destination / trigger port.
That should be you. If not you need to telnet into you router
Telnet <default gateway IP>
and type Menu
The follow the previous instructions.
Aug 31, 2008 | Computers & Internet
Change NAT to open
I have this router and have just enabled the NAT settings from Strict to Open:-
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again. Worked for me!
Oct 08, 2007 | Zyxel P660HW-D1 Router
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
