Question about Lectrix 0301 Cow Vac Handheld Vacuum
Where can I purchase replacement batteries? The original are BYD Model D SC1500Px3 NiCd. 3.6v, 1500mah. They are a solder connected 3 pack with connecting tabs.
Need battery for fhv1200
Black and Decker, does not provide a replacement battery for your model. It is supposed to last 4 years. I have been scouring the web in order to find a suitable replacement but can not find anything. Is there a model number on your battery pack that you can provide for further research?
Sep 03, 2013 | Black & Decker Black Decker FHV1200...
My phv1800 18 volt hand vac's battery seems to be running down. is there any way to revive it? if not; can i purchase a new battery to replace it? thank you!
If you are handy with a soldering iron, and don't mind spending a few hours building a new battery pack using 1.2 volt "sub c" cells, you can disassemble the PHV1800, and rebuild the pack yourself. I just did it tonight, and the vacuum works like new.
However, I'm not going to do this again. The PHV1800 doesn't use a single battery pack, but 2 packs that have to be assembled with very little room for error. You can purchase a combination battery pack/motor assembly for $75 (US currency, price currect as of 10/2011), unscrew the screws that hold the vacuum together, and replace the battery/motor unit as one.
Jan 24, 2011 | Black & Decker PHV1800 Bagless Handheld...
Batteries are not recharging. Where can I get replacements for Model EL1000 Pronto Vac?
Let me say this; The battery replacement for the Electrolux is not a owner level replacement procedure. However, you can replace the 4 original EMX1600sS batteries . The battery model is Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web. Anything under those specs should work. These types of battery's will cost about $15.00 on the web. The battery's are in the hand held unit bottom or back side area, you access them by taking out all the screws in the back side of the hand unit.
Jan 15, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I Need A dyson hand held battModel DC16 12097 model 282-US-A35458 21.6 1080 MAH All I can find is the 1500 Mah
I didn't understand what you need exactly, but anyway, you can find both of them on amazon (the entire vacum, or just a battery 1500Mah). take a look on following links:
1. entire vacum: Dyson DC16 Root 6 Handheld Vacuum Cleaner
2. just battery: Pwr 1500mAh Extended Capacity Battery for Dyson Dc16 Root 6 Vacuum Cleaner...
Dec 09, 2010 | Dyson DC16 Root 6 Bagless Handheld...
How to replace battery for PHV1800 type 1 18vdc
Nov 29, 2010 | Black & Decker PHV1800 Bagless Handheld...
Norelco razor 6867xl - am planning to replace battery pack. Would be easier to solder if I could remove the whole circuit board system from the hard plastic case. How do you release the metal clips?
The whole circuit board is removable, and I would recommend removing it from the whole external case to work on so nothing is damaged by your soldering iron.
Battery : 2x NiCd AA
Battery capacity : approx. 700 mAh
May 20, 2010 | Vacuums
My roomba was not used for a month. Now it does
Hello
You can revive the dead nicd batteries in your tools.
There is a simple guide that can fix all nicd batteries in few minutes, available here.
Thanks
Nov 29, 2009 | iRobot Roomba 560 Robotic Vacuum
Can you take the Swivel Sweeper battery pack apart to replace the batteries with new rechargeable batteries? Batteries look like AA or AAA, but it appears that the battery pack is sealed. Is there any way...
Yes you can if you have a way to cut through the plastic outer case,(I used a Dremel rotary tool). Inside you will find six double A Ni-mh batteries. I found eight of these for sale on ebay for around ten bucks,then all you do is solder some wire to the batteries like the original battery pack and tape up the case and charge.
Nov 20, 2009 | Hoover H3030 FloorMate SpinScrub 500...
My Dirt Devil kurv no longer recharges. I think I need to replace the battery. Called the manufacturer and they can't help me.
Obtaining a battery will be difficult; I had a similar problem with my Kone model. Check that the plug you have has a fresh new fuse though as it may be the connection lead.
Sadly because the batteries are built into the machine its difficult to find a replacement - ALL cordless hand dust busters suffer from difficult to find batteries because at cost they are reasonably cheap and not really designed to have batteries that can be found easily.
Well not until someone brings out a model that has batteries that are available...
Jul 23, 2009 | Dirt Devil Kurv Bagless Cordless Hand Vac...
Battery Pack for the Eureka Boss Model 93B
tHE 96 F IS ALMOST THE EXACT SAME AS THE MODEL YOU HAVE. THEY HAVE THE SAME POWER TO THEM THE BATTERIES WERE JUST DIFFERENT
Jul 18, 2009 | Vacuums
Lectrix 0301 Cow Vac Handheld Vacuum Logo
210 people viewed this question
Top Lectrix Vacuums Experts
Are you a Lectrix Vacuum Expert? Answer questions, earn points and help others
