I wana increase the sounds of my toshiba labtop
When i play any kind of music the volum of the sounds is not laud i check everything is ok.is there any program can make my labtop sounds more
  • richieo Dec 02, 2008
    Does the mini stereo plug insert into the headphone jack on the right side or do I need to get a sound card or USB audio interface?
  • 560 Answers
This is a very common problem with Windows 7 OS, it doesn't matter which laptop you are using..Get the help below..
http://microsoft-support-squad.blogspot.com/2012/06/fix-windows-7-low-volume-problem.html
Posted on Sep 26, 2012
  • 13,433 Answers
Most music / video playback tools have a equalizer integraded where you can increase the output.
Posted on Jun 15, 2008
  • 2,794 Answers
The only way you can get it to go louder is to add amplified speakers to it. They usually aren't designed with a lot of wattage to them to save on battery life.
If you really want it loud, you can get a Y audio cable with a mini stereo plug in one end and rca jacks on the other end and find a stereo receiver to plug it into.
No volume when playing movies
The Problem> Sound: Placing the mouse pointer over the ICON to the lower right of your screen should indicate the percentage of Volume your speakers are adjusted for. Right click and you get the Open Volume Mixer section. The playback devices can be your computer speakers or a separate headset with microphone. Here you can make adjustments accordingly. At the bottom are Volume Control Options that allow you to increase or decrease the audio reception. Generally, when you insert an external Headphone with Microphone into the sound port in; an automatic disconnect may occur preventing computer speakers from working. This is common with Laptops. If you lack sound, you may need to update the sound drivers, change cables, and/or check to see if the speakers work on another device.
Dec 27, 2013 | Toshiba satellite c660
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
Toshiba laptop weak powerpoint volume
Check below link for info how to increase the volume in Powerpoint.
http://presentationsoft.about.com/od/powerpoint-2010-sound-music/ss/120509-sound-music-audio-options-in-powerpoint_5.htm
Feb 14, 2013 | Toshiba Satellite Computers & Internet
How do i turn my sound up
The Windows operating system on your Toshiba laptop contains a functionality that allows you to increase the volume.
Your laptop's volume is a measure of the decibel levels of sound that your Toshiba laptop will put out.
If you are having trouble hearing music of video files, you may need to boost the sound volume, which can be accomplished by following several steps.
Press the "Start" button on your desktop.
Click on the "Control Panel" icon then double-click on the icon labeled "Sounds and Audio Devices."
Click on the "Volume" tab then move the device volume slider to increase the volume.
Close the "Control Panel" when you have completed the operation, and your volume should be louder.
Hope this helps.
Nov 20, 2012 | Toshiba Computers & Internet
No sound on toshiba 36 tube TV
Check its speaker/s. If it is OK, the audio output IC should be checked.
Jul 14, 2012 | Toshiba 36A43 36" TV
Why isn't my volume working?
there are numerous volumes - in-call (which you can only increase/decrease while sspeaking to someone) media -volume (which a game or music has to be playing to change) and the phone volume (which all other programs must not be running through the volume.
Also check your settings - sounds - and make sure your phone is NOT on silent..
May 09, 2012 | Cell Phones
I have a galexy s, i have no ring on incoming calls
may be your ringing volume is set to zero. to check, go to profiles. select personalize option for the activated profile(general) increase the ringing volume.
Nov 17, 2011 | Cell Phones
How to increase the sound
To increase the sound of your motorola MOTOZINE ZN5 cell phone.
You can increase the sound of your phone in three categories.
1. music volume,
2. ringer volume,
3. keypad tone volume.
To increase the music volume, you go to the multimedia, select sounds, once the song is playing then you click on the up button that is by the side of the phone. You can increase it to the volume that pleases you.
Further means to increase the volume of your phone is that you go to the 'menu', click on the 'settings', select the 'profile', select 'personalize', a page will show up with a list of data that can be changed on the profile, select the ringer volume, keypad tone or whatever sound you want to increase and increase it with the direction button pointing upward that is by the side of the phone.
To increase the keypad tone, from the home page, click on the up button that is by the right side of the phone, the volume of the phone will increase.
Take care
Jun 25, 2010 | Motorola Mobility MOTOZINE ZN5 Cell Phone
Hi I lost the volume in my toshiba and even using "help and support" it does not work. How can i re-install it?
Ok now you need to call up ether the sound card application or preferably the windows volume control from the bottom toolbar.
Click Open Volume Control.
A box with sliders in should appear. make sure that volume control, wave, sw synth, aux, cd player, line in
are all about half way and that none of them have ticks in the box at the bottom.
If any of those are missing click options then properties from the top left and put a tick besides any that were missing (nothing else)
Now close the slider box.
Put a normal music cd in your cd/dvd player on the computer and set it to play with windows media player.
You should now have sound out of the speakers.
Double check that EVERYTHING is ok.
If there is still no sound check the control panle for any hardware issues and rectify those with the correct drivers
Oct 28, 2009 | Toshiba Satellite A100-S8111TD Notebook
I want my music back!
Have you tried to raise the volume by double clicking on the speaker icon on your taskbar. This will open the play control panel where you can raise the volume.
If you do not see the speaker icon, go into your control panel and chose sounds and audio devices and raise the volume from that screen.
Mar 31, 2008 | Gateway 2520915 Keyboard
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
