Question about Reddy Heater-70,000 BTU Kerosene w/T'stat
Have a reddy 55ooo fan runs when plugged in also element gets redhot but no light,, could it be ignition?
    Problem Solver:
  • 16 Answers
Is the gas valve "on", pepcock open?
Posted on Nov 06, 2010
Fan runs but no fire on igniter plug
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 10, 2011 | Dayton E51 Oil Filled Utility Heater
Will the fan on the reddy heater not run if the ignighter is bad? When i plug it in the fan doesn't run.Do i need to replace the motor?
The fan motor runs regardless of the igniter as it is also the fuel pump. Possibly you may need to replace the motor but try this first. Remove the top section of the heater this exposes the fan motor, try spinning the motor by hand,it should spin freely if it does not try some light oil in the front and rear bearings of the motor and turn it by hand until it frees up. You may need to do this several times!! Now that it is spinning free put the heater back together and try it out. If it does not work a new motor is in your future. Hope this works out for you.
Dec 26, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddi heater 155 owners manual?
If this has a hot surface igniter, can you see it glowing? If not the igniter could be bad or the control
board for the igniter is baed.
If you are able, remover the igniter and hook it up to a 110 outlet, if it glows the problem is in the board.
If it has a board, follow the incoming power to line 1
and line 2. You will either have to splice the two leads
from the igniter into L1 and L2 or get a special spade
connector that can hold two leads on each terminal.
Plug unit in, glow coil should glow and unit should run
thats assuming you have that style of unit. Do not
attempt to do this unless you can safely perform this.
If you know of an electrician he can do this.
Jan 18, 2010 | Heating & Cooling
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
55ooo heater
The flow to the nozzle needs to be adjusted! this should fix it!
Dec 11, 2008 | Reddy Heater-40,000 BTU Kerosene w/T'stat
Reddy R55 Wont Ignite
Fuel not a problem. Wrong pressure definitely a problem. Click here for instructions on setting the pressure.
Nov 20, 2008 | Reddy R70ET Utility Heater
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Please HELP
www dot desatech dot com is a parts distributor for reddy heat products. on their main page they have a short troubleshooting guide. the motor needs to provide 3.5 psi of air across the fuel nozzle to suck the fuel out of the reservoir. check your ignition source (spark plug, hot surface igniter) if the hot surface igniter is broken get a new one, if the spark plug don't spark, check the gap might be too big. see if the spark plug is grounded. poor grounds will cause intermittent sparking. check the high voltage wire for breaks in the insulation, might be shorting out to ground BEFORE the plug. gap should be 75 thousandths.
Dec 04, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-70,000 BTU Kerosene w/T'stat Logo
15 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
