Question about Sony Ericsson W600i Cellular Phone
Black camera screen w850i
My screen is black when my phone is in camera mode. u can hear the shutter sound when u have taken the picture but there is no image. PLEASE HELP!
    New Friend:
CAMERA BLACK WHY
Posted on Nov 15, 2012
I've just opened my box and had the same problem until i removed the plastic protection for the back panel. Remove all plastic film as i suspect that it's interfering with the flash sensor.
Posted on Jul 16, 2008
My screen is black and will not display images to shoot. Also when picture is taken it plays back as black image. Previously taken pictures will display.
Michele, a stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 19, 2011 | Canon PowerShot SD960 IS Digital Camera
The screen unexpectedly went blank and black....apart from camera info symbols..all pictures taken now are black..... pictures taken before can be seen on screen,....lens moves in and out ok
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 04, 2011 | Nikon COOLPIX S220 Digital Camera
The view finder or screen are black. The lens moves out when the camera is powered on, I can hear the shutter click when pushed; the telephoto is moving; I have all the settings show on the screen when...
I know it may sound like the shutter is moving, but you're going to have to actually look down the lens barrel to confirm it's actually moving, and not just producing a sound effect from the camera. Also keep in mind Canon's SX IS series cameras are notorious for the following problem (fantastic cameras otherwise).
Oct 31, 2010 | Canon PowerShot S3 IS Digital Camera
The display is black through the viewfinder and the screen. The menu displays and pictures taken previously on the memory card can be viewed, but in camera mode, the screen is black and pictures taken are...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Sep 05, 2010 | Canon PowerShot S2 IS Digital Camera
The camera takes pictures with flash, but then as you hit display the screen stays black and the picture was never taken. How can this get fixed?
Do you mean that no picture file was actually recorded, or do you really mean that the resulting picture file recorded a black picture?
If you mean that you're camera is taking black pictures, this sounds like a stuck shutter. A stuck shutter is a common failure mode for digital cameras, and it seems to be especially so for any of the Canon A6XX series (although these cameras are awesome otherwise). The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 28, 2010 | Canon PowerShot A620 Digital Camera
Black screen when put it into camera mode
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
But if you do notice shutter movement, then this would then likely be a CCD imager failure. It would in that case require Canon service to repair (1-800-OK-CANON). Unfortunately if this is the case, believe that you may find that the estimated cost of repair may exceed the current value of the camera.
Dec 06, 2009 | Canon PowerShot A610 Digital Camera
Black screen
Oct 06, 2009 | Canon PowerShot A510 Digital Camera
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Black Screen and takes blank pictures
It sounds like a stuck shutter. As the camera is less than a year old, Nikon should fix this for you for free under warranty. Contact them.
For others that experience this with cameras that are out of warranty:
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Jun 27, 2009 | Nikon Coolpix S210 Digital Camera
Black LCD screen and viewfinder in photo take mode
Sony (who bought KM) will fix this for free. http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131
Sep 05, 2006 | Konica Minolta DiMAGE A1 Digital Camera
Sony Ericsson W600i Cellular Phone Logo
56 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
