Question about Verbatim (96532) 50 GB USB 20 Hard Drive
Hey i have this verbatim thing...i plugged it in but the lights just blink on and of...nice and slow like...also you kno that usb symbol with the green arrow shows up at the bottom right wen you plug in something..well that doesnt show up either...i have a dell pc...not a mac...just you kno regualr comp...not the newest but it gets the job done....now i tink this hdd is for mac computers only...but i hope not..i just wanna get this hdd to work so i can start using it...i dont kno wat to do...help me please
    New Friend:
    Problem Solver:
  • 10 Answers
First thing you should know, hard drive is unbiased when it comes to OS.
Now there can be multiple problems in your case,
1. May be you don't have drivers installed in your windows PC.
2. May be your hardrive format is not compatible with the windows.
3. Or it may have internal hardware problem.
Posted on May 20, 2017
fire sine
  • 382 Answers
SOURCE: verbatim usb issue
Depending on whether youre on a mac or pc, you should go to DISK UTILITY or HARDWARE PROFILER or MY COMPUTER. You may need to format it to your computer's legible format type.
MS-DOS being universal
Posted on Oct 22, 2007
SOURCE: external hard drive doesn't respond
Shut your computer down. Disconnect you external hardrive. Power up your computer again. Power up the Verbatim and then connect to a USB port. You should hear a very quiet 'ping'.
Go to My Computer, and the Verbatim should be showing as one of your drives (probably Drive D). You should be able to open it from there.
Make sure that you have a Desk Top Icon for opening the hardrive, it makes it so much easier. Hope this helps
Posted on Apr 10, 2009
Chinthakaj
  • 416 Answers
SOURCE: verbatim external hardrive not showing up on computer?
A Hard disk making noise, does not sound too good. if it was waorking before on both PC's & not having issues then it has to be with the unit. try on a nother computer. if its the same thing i suggest you look for that warranty card of yours.
Posted on Jun 10, 2009
  • 12 Answers
SOURCE: I hve a Verbatim USB Portable Hard Drive with
usualy it means that it has an error,try checking that the cables to the drive are connected properly if there all fine try shutting the usb drive off and turing it back on after 3 min.
you should turn your PC off also and restart it.
if that does not work you need to post more information about your PC and periferal devices.
Posted on Jul 19, 2009
lock123
  • 6831 Answers
SOURCE: Verbatim 160 USB external hard drive does not show
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
USB port is not recognized in any of my computers or in any port.
It seems that the issue is related with the flash drive itself, I have came across with such problems many times. I guess now it's time you should go and ask for a replacement.Most of the flash drives comes with 5 years warranty. You may want to call verbatim customer support for warranty. Contact details
http://www.verbatim.com.sg/en_SG/contact-us
Feb 07, 2014 | Verbatim ® Store `n` Go USB Flash Drive,...
Verbatim usb250
You will need to remove the drive from the case to check that the drive has not failed. The usual cause of this symptom is a failed interface.
Jul 09, 2013 | Computers & Internet
Hey there not sure if both usbs on this dual cable are to be plugged into my PC. The drive keeps flashing a blue light but my computer is not recognising it.
In most case's only one USB needs to be connected, but you need to load the driver for it from the disks which you would have received for it.
Hope this helps.
Thanks
Jason
Oct 14, 2010 | Verbatim 160GB USB FireLite: The "drive...
Verbatim 160GB Hard Drive won't boot.
Try it on another PC or on a powered USB hub: maybe it's not getting enough power to run.
If it still doesn't work, and you don't hear the drive's spin-up noise, the electronics may be damaged, the internal disk disconnected or the internal power connection faulty.
If you hear the spin-up whirring and then a series of repeated whirrs and clacks, ending after about 30 seconds - one minute, the disk might be damaged. It still might be recoverable if extracted from the case and connected directly to an appropriate hard disk port (a 3.5 to 2.5 adapter might be necessary), but when things go this far, the chances aren't too good.
Oct 27, 2009 | Verbatim Computers & Internet
Verbatim drive not recognized
Hello
I brosed the internet for a conclusive sollution and there is none.
But i fount some tweaks of my own that works me.
If you usually plug in your flash drive into the front USB panel of your case and it does not recognize the drive, unplug it and plug it in the back panel of your case.
An other thing you can try is to restart your system with the device already pluged in. The secnd one is not very practical, but it does work.
Please rate this
Best regards
Sep 25, 2009 | Verbatim STORE-N-GO (95312) 8 GB Hard...
I just got a Verbatim 320 GB/Go, USB 2.0. I have a MacBook running OSX (10.4.11). When I plug it in, there's a flashing blue light, no sounds or anything. According to the website, this only happens in...
First let me let out a LMAO to there website. Although the Windows and Mac operating systems are still somewhat different in how they work, the computer you're running OSX on IS a standard "IBM-Clone" or PC and therefore and potential hardware issues are identical regardless of wether it is running Mac or Windows.
The Blue light blinking generally means one of only two things, one the hard drive is active and currently reading or writing files, or two, it has a hardware problem. The fact the light is on usually means you have a good power supply but there are numerous other problems that could cause this.
If you just bought the drive and haven't got any data that is only on this drive, take it back to the store you bought it at and ask to have it replaced as a faulty drive. If you do have any crucial data on the drive already, respond back and I will be happy to offer advice on how to retrieve it.
Chris
Aug 15, 2009 | Verbatim 160GB USB FireLite: The "drive...
I hve a Verbatim USB Portable Hard Drive with 160gb/go. Suddenly I notice the blue light on the unit is blinking, and my K drive (Verbatim) is no longer showing on my computer. What does this mean?...
Jul 18, 2009 | Verbatim 160GB USB FireLite: The "drive...
USB device not recognized
try another usb port also try booting without it plugged in when booted plug in it may recognize it as new hardware
Jul 31, 2008 | Verbatim 95208 Mouse
Verbatim (96532) 50 GB USB 20 Hard Drive Logo
83 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
