Question about Dryers
Whirlpool dryer: the drum is not turning. - Dryers
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101 .
Posted on Nov 07, 2010
My dryer made a loud bang and wont spin
Bridgette, Most common problem is a broken belt when dryer drum dose not turn. Look through the attached links to help diagnose and repair your dryer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dryer Drum Not Turning
Whirlpool Dryer Drum Not Turning
Appliance Repair Forums
Duet Dryer Drum Belt part 661570 How To Replace
Jul 17, 2016 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Model # LER6620PQO Whirlpool dryer where do U check to see if drum has come off rollers
Try to see if you can turn the drum by hand freely or turn the dryer on and listen for the motor sound and the drum doesn't turn
Mar 01, 2015 | Whirlpool Dryers
Whirlpool dryer drum not turning
If you can hear the motor running, but the dryer is not spinning the drum belt is broken. Replace the belt.
Aug 08, 2014 | Whirlpool Dryers
Whirlpool dryer was making loud squeaking noise. Now it is not turning at all. Makes a noise when you turn it on, but stops completely.
Check the drum belt. Check the drum rollers on the back & glides on the front that the drum rides on also check the idler pully. Check the felt the drum rides on in case it came loose and won't let the drum turn. Did it hum when you started it if so could be the motor. Good luck
Apr 06, 2014 | Whirlpool GGW9200L Gas Dryer
My whirlpool electric dryer makes a loud grinding noise
Is there anything caught between the dryer drum and any housing. Can you hear it when the drum is turned by hand.
Jan 26, 2014 | Whirlpool Dryers
Whirlpool Electric dryer type-DWJR-ELE-2406028-FM54. model LER7646JQO the heating element get very hot. the dryer does not turn on. the drum does not turn either.
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Mar 17, 2010 | Whirlpool Dryers
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Dryers Logo
26 people viewed this question
Top Dryers Experts
