Question about Rinnai Heating & Cooling
Cannot get pilot light to remain lit. have blown out heater with can dust. it will light, but then go out when you let go of button.
    Problem Solver:
  • 16 Answers
Hold down the pilot light button for about a minute and a half to generate the milivolts needed to prove a flame, or try sanding down the flame sensor, it could be dirty
Posted on Nov 06, 2010
Heater pilot light will not stay lit after knob is released
99% of the time it is just dirt and dust in the pilot light. NOT a bad thermocouple! These units generate their own power through the pilot light and it has to burn perfectly. Turn off gas supply, remove the cover and the pilot light assembly, including disconnecting the tiny gas line from the gas valve. Blow compressed air in, around and through it to get dust out. Replace everything, use soap bubbles at gas fittings to leak test and light the pilot. I bet it stays lit.
Feb 08, 2014 | Dyna Glo Heating & Cooling
ODS will not stay lit
The pilot generator (aka thermocouple) has gone out. This is the little peg that is mounted close to the front of the burner. The flame heats the thermocouple and it puts out a millivolt current that holds the gas valve open after you release the button. The TC is no longer putting out enough current to hold the valve open.
I beleive the part # is TT15c-11, (about $15)
Dec 14, 2013 | Dyna Glo 18,000 - 30,000-BTU Liquid...
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
I accidently turned the pilot off and I can't get it to turn on Williams Model# 2001622
Turn the control valve to the PILOT position and push down and hold it in. Press the Ignitor Button and continue to hold the Control knob down, once the pilot lights. Wait one minute, release the Control Knob and if the pilot remains burning, turn the Control Knob counterclockwise to the ON Position. If after the burners light and burn for a few minutes, you can turn the Control Knob back (Clockwise) to the Pilot position (if you don't want the heater to come on automatically) and the pilot should remain lit.
Hope this helped to get you back up and burning.
Mar 30, 2011 | Williams Heating & Cooling
Wall mounted 3 grate gas space heater: VIN # 41201. ser. # 1410915. Piolet light won't remain lit to be able to light grates. Also need control knob (if avail) for same model.
your pilot has dust in it. Use a drinking straw and blow air across (not into) the pilot opening. this will remove the small particles of dust that are stopping up the membrane inside the opening. THis will make your pilot flame bluer and hotter and keep the thermocouple hot enought to produce enought magnetism to hold the gas valve open.
Jan 27, 2011 | Desa International Heating & Cooling
Pilot flame will not remain lit.
u sound like u have a bad regulator
Feb 18, 2010 | Dyna-Glo RMC-8001SS Heater
Water heater will not stay lit even after replacing thermal coupl
The pilot must encompass the thermocouple "bulb" in order for the thermocouple to generate enough current to keep the pilot valve on. You must also hold the red button down for a long enough period to get the thermocouple hot. If the pilot is not large enough, it could be due to a clog in the pilot orifice at the pilot itself. Sometimes a couple of passes over the end of it with fine steel wool is all it takes to clear it.
Hope this helps. Feel free to share what you found. Thanks.
Jul 16, 2009 | Kenmore Dryers
GWN10T pilot blows itself out
You must clean the pilot regularly to ensure it burns properly. Use a small can of air for cleaning computers and blow air through the pilot to remove dust and small particles that accumulate in the pilot barrel. Use several burst being that it is 2 years old and has not been blown out. THe manual references cleaning the pilot in the maintenance section.
Mar 29, 2009 | Desa International GWN10T Wall Mounted...
Pilot Light will not remain lit
Try this, turn the black gas ****, on top of the control box, to the Pilot position. Set the temp. control on the front of the box to the desired temp. Then, hold a match or whatever else you use to light it, next to the end of the pilot, then, while holding the match to the pilot, press the reset button on top. When the pilot lights, continue to hold the reset button down for about 1 minute. Then, after a minute, turn the gas **** to the ON position, then it should remain on.
Jan 20, 2009 | Water Heaters
Pilot light won't stay lit
Look for dust and lint. Look for them in places where gas should be freely flowing. I had a similar problem with an Empire Corcho wall-mounted propane ceramic catalyst heater. First it was the pilot light, then the #2 ceramic mantle. After horsing around with the gas lines and pressure regulators and trying to re-aim the pilot, it all turned out to be dust and lint in the gas passages. A little dust bunny in the brass pilot tube gave me a pilot light the shape and color of a banana. One puff of compressed air, and I got back my razor-sharp pilot. And some dust in the chimney of the #2 burner kept it burning blue/yellow and blistering paint off the upper surfaces of the heater. A bit of cleaning with a shop-vac put that right. "Passive" heaters are very much prone to this sort of problem because they rely on convection currents (i.e. LOW velocity) to get the job done. Convection currents are notorious dust collectors, as in COBWEB CITY.
Aug 23, 2008 | Heating & Cooling
Heating & Cooling Logo
65 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Hjalmer Lamminen
Hjalmer Lamminen
Craig Butler
Craig Butler
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
