I had the same problem...after trying everything suggested on the forum. I had enough and decided to disassemble the printer. I removed the CAD and disconnected the wires and it solved the problem. No more paper jam error code on the screen. This probably includes that the CAD won't work anymore but I never used this anyway. So now I can print and scan like I used to.
Try to blow air into the printer; dust may have clogged paper sensor
good luck
This is happening to me too, it just started this week. I've blown air all through it, pushed card-stock through paper paths where paper or dust chunks might have been getting stuck up, still nothing. Any other suggestions? Where are the sensors, can I clean them directly? Can I disable the paper jam sensor?
Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
Check the paper feed tray on the front end of the Canon MX700 to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
Check the paper feed tray on the front end of the Canon to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
