Question about Dryers
Was fixing the bearings in the front off the dryer and i have two wires red and orange they come out the same hole as the door and Wirers. they are hooked together buy a plastick conector one is a ground the other looks like it go's up to the start switch. the problem is i do not see any place to hook the wirers up the dryer is a GE DRYER DDSR475ET2WW
  • Dryers Master
  • 8,220 Answers
Looks like your dryer features electronic dryness control. Look for the moisture sensing strips inside below the filter on the front panel, one of them wires connects there. The other wire goes to heater pan I imagine. On them style GE dryers the heat typically will have a lone terminal on one side the pan opposite the rest of the connections. The control thermostat is mounted under the filter housing on most GE dryers. I can't remember which one is which though. Don't want to steer you wrong. Their ought to be a diagram somewhere on the dryer that will tell which wire goes where.
Posted on Nov 06, 2010
Testimonial: "You where right but both wire's went just below the filter. thanks for the help"
I already sent this once but not certain it went throughSears Electric Whirlpool dryer LEB6000PO1 ( or P01) high thermostat.
If that is an OEM part you SHOULD NOT have to cut or change anything!! What is the model of the machine? What is the part number of the new and old parts. IF YOU CAN EDIT YOUR POST, remove the personal information
Jul 21, 2013 | Dryers
Dryer is getting "red hot"
Yes it can be fixed, go to this web site http://www.appliancepartspros.com and look at the wiring diagram locate the thermal control switch and purchase it then replace it, the contacts has stuck shut, replace the unit do not play with it as it will cause a fire.
Nov 22, 2009 | Computers & Internet
Need colour codes for radio
this is what I show for Passat.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Ignition Switched 12V+ Wire: Orange
Car Radio Ground Wire: Brown
Car Stereo Illumination Wire: Gray/Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Black
Left Front Speaker Wire (-): Orange/Black
Right Front Speaker Wire (+): Red/White
Right Front Speaker Wire (-): Orange/White
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Door
Left Rear Speaker Wire (+): Red/Light Green
Left Rear Speaker Wire (-): Orange/Black
Right Rear Speaker Wire (+): Blue/Light Green
Right Rear Speaker Wire (-): Orange/Red
Aug 13, 2009 | 1993 Volkswagen Passat
Clothes getting caught between drum and front of dryer
Hello Friend, This problem is real common in Hotpoint/GE dryers. Your solution is simple. You need to replace the front drum bearing and glider pads. It's actually pretty simple to do. Just remove front of dryer cabinet. After removal just look at backside of dryer front around the inner door. You will see where the dryer drum has turned and wore a hole in the plastic piece above the dryer door. This piece is called the front drum bearing. Just unsnap this piece and snap in a new one. Be sure to replace the little plastic glide pads onto the top of the drum bearing before re-installing the dryer cabinet front. The front drum bearing and glider pads are sold seperately so make sure you have everything you need before you begin. This should solve your problem. Happy to help, Tim. Thanks.
Jun 29, 2009 | Hotpoint NVL333EY Electric Dryer
My dryer catches a piece of clothes in the drum edge and has ruined quite a few clothes, leaving them with black-brown marks. When I look at the drum seating using a mirror I can see that it's not...
Hello Friend, This problem is real common in GE dryers. Your solution is simple. You need to replace the front drum bearing and glider pads. It's actually pretty simple to do. Just remove front of dryer cabinet. After removal just look at backside of dryer front around the inner door. You will see where the dryer drum has turned and wore a hole in the plastic piece above the dryer door. This piece is called the front drum bearing. Just unsnap this piece and snap in a new one. Be sure to replace the little plastic glide pads onto the top of the drum bearing before re-installing the dryer cabinet front. The front drum bearing and glider pads are sold seperately so make sure you have everything you need before you begin. This should solve your problem. Happy to help, Tim. Thanks.
Jun 29, 2009 | GE DBSR453EBWW Electric Dryer
Iam hearing scraping sounds from my dryer.
Hello Friend, Your solution is simple. You need to replace the front drum bearing and glider pads. It's actually pretty simple to do. Just remove front of dryer cabinet. After removal just look at backside of dryer front around the inner door. You will see where the dryer drum has turned and wore a hole in the plastic piece above the dryer door. This piece is called the front drum bearing. Just unsnap this piece and snap in a new one. Be sure to replace the little plastic glide pads onto the top of the drum bearing before re-installing the dryer cabinet front. The front drum bearing and glider pads are sold seperately so make sure you have everything you need before you begin. This should solve your problem. Happy to help, Tim.
Jun 25, 2009 | GE DBSR453EBWW Electric Dryer
Need to know how to hook up a sony cd player
see if this helps bro.
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
May 09, 2009 | Sony ATRAC MPS/CD/AM/FM Personal CD Player
My front loading dryer Whirlpool Duet GEW9250PLO will not come on even after resetting.
check for electrical power if you have 220+ then check the door switch, jump the wirers if necessary. If switch ok, then move timer to 20 minutes and press start--if timer ok then you must have a broken wire in the wiring harness. Good luck.
Sep 04, 2008 | Whirlpool GEQ9800L Electric Dryer
1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Feb 22, 2008 | Car Audio & Video
Dryer marks clothes
it could be the adhesive that holds the felt bearings on the front housing. you see the back of the dryer drum has a bearing in its center, the front of the drum rotates on two or more felt pads or bearings in/on the front cover where your door is. you'll need to remove the front cover to replace these felt bearings. there should be two screws, maybe more holding the front cabinet to the rest of the dryer. the bearings will be mounted to the front cabinet right around the hole for the door.
Aug 09, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Dryers Logo
116 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
