Question about Bosch Washing Machines
When I use the spin only cycle on my Bosch WAE20260AU front loader it runs the pump for most of the cycle time. It only spins briefly mid cycle and the clothes are still very wet at the end. I do a lot of hand washing and this spin cycle is basically useless.
  • mbutler2575 May 11, 2010
    I had a simular problem and it could be the outlet hose is too high ans the pump may not be able to pump out all the water.I re routed the hose and all is well now.
    Mark
I have the same problem on a Miele W418 washing machine.
Just will not spin at all although the Pump out motor and the rest of the washing cycle all appear to be working.
Posted on Jun 15, 2008
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Jan 13, 2014 | Bosch Washing Machines
Bosch nexxt essence won't spin
Either a blocked filter or worn carbon brushes
Oct 11, 2017 | Bosch Nexxt Premium WFMC6400UC Front Load...
WHY DOES MY WATER PUMP, ON MY BOSCH NEXXT 100 SERIES, RUN LITERALLY ALL THE TIME DURING SPIN. THE PUMP REMOVES WATER AS IT SHOULD, BUT JUST KEEPS CAVITATING AS IT KEEPS RUNNING. I CAN TELL IT KEEPS...
Welcome to FixYa.
Completely normal. The pump will indeed run through the entirety of the spin cycle, it is by design.
As the items spin, more and more water is extracted and if the pump should fail to operate during this time it would cause increased vibration and inadequate extraction to achieve it's superior spin cycles.
Hope that helps quell your concern. Let me know if I can assist you further.
Thanks for choosing FixYa. Please take a moment to rate the info provided here today.
Regards,
Macmarkus :)
Sep 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Stopped working mid cycle. The timer still counts down but does not fill, agitate, spin, drain. And before it stopped, the water that was draining out smelled really bad.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 30, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
My bosch wfk2401 front loader is stuck on spin
Hi
There is a door bottom right of the system which has a screw out (by hand) plug.
Remove this and ensure there are no foreign objects such as coins, bobby pins etc stuck.
I have found this to be a problem with the Bosch systems and cost me $150 the first time.
Ensure you have some towels as when you open the plug, water will escape
Mark
Mar 04, 2009 | Bosch WFK 2401
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Beeping on spin cycle
It is most likely out of balance, could be for many reasons.
1 could be too many heavy items such as jeans, towels, etc in one load.
2 could be the machine or floor is unlevel.
3 Could be a balance sensor needs replacing.
Mar 09, 2008 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
309 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
