Question about Clarion DXZ665MP CD Player
Lost puller, how do i get unit out to attach auxillary cables
    Sniper:
  • 58 Answers
I'm guessing you mean the keys that slide between the radio and the dash, ask around to see if maybe one of your friends has an extra set you could borrow.... If thats not possible try using two butter knifes (one for each side) and usually that will move the locks out of the way so you can pull the stereo out.
Posted on Nov 08, 2010
My jensen vm9214 will play my music from my ipod but it will not show a display of the song or anything and when I click pause or play or fast forward on the screen it doea not do it so I have to play and...
First off, is the unit equiped as ipod ready or are you using an auxillary input. If your unit is ipod ready, this means it has the ipod cable to the unit. If you are using an auxillary input, it won't show the name and yes you will have to control your music from the ipod itself. Just some things to think about. If your unit is malfunctioning, I recommend visiting the local stereo shop.
Aug 14, 2011 | Jensen Car Audio & Video
Why is it that my goodmans x-pro hi-fi component system turns off when i plug a cable into the auxillary opening.The word "protected" shows in the window
That may depend on what electrical or ground potential that cable and its attached device are introducing to the poor thing.
If just plugging a cable with nothing attached to the other end has the same result, something may be flexing at the aux connector or inside. Wiggle it lightly and see if that has an effect.
If a loose cable connects ok, try attaching the other end. If it fails evaluate what's going on at that end. Isolate ITS power, for example.
Jun 14, 2011 | Goodmans Audio Players & Recorders
Can you hook up and play xbox through this combo zenith xbv343
Yes you will need component cable and you can attach your xbox to the front left of this combo. You will have to select the correct auxillary input once the xbox is connected so you are able to view on your tv.
Mar 03, 2011 | Zenith XBV343 DVD Player/VCR
I want to be able to hook up my wife's new version 4 Ipod but there is no little ipod hole in the Alpine in front to lug it into. Is there an aux hole in the back of the unit or? Dean
To use an auxillary input on this radio - you need the correct cabling to "trick" the radio into thinking there is a CD changer attached.
CLICK HERE to see the adapter required.
Then you will need a different adapter that converts your 3.5mm jack to component RCAs.
THIS ONE is the second plug you need.
Then you can use your 3.5mm male to 3.5mm male cable.
Or you can eliminate this cable and get a 3.5mm MALE to Male RCA cable like this one...
CLICK HERE
Thanks!!
Jan 21, 2011 | Alpine CDA-9827 CD Player
Need to replace the auxillary transmission cooler
The auxillary IS the second cooler. Theres only one radiator. Some have a engine oil cooler. If you see the cooler thats leaking, I dont see why you cant find where it connects?
Jul 23, 2010 | 1996 GMC Jimmy
Need a diagram to replace the crank pulley on a 1990 Oldsmobile regency 98 3.8 liter
This is what I found on the 98 Regency instructions: Crankshaft Damper REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Remove the belts from the crankshaft pulley.
  3. Remove the crankshaft damper attaching bolt.
  4. Attach a suitable puller to the damper and remove the damper from the crankshaft. NOTE: On certain models, removal of the cooling fan, fan shroud or radiator may be necessary for clearance. WARNING
    DO NOT pry on the damper assembly to remove it from the vehicle or component damage will result. Remove the damper using a puller only.
  5. Installation is the reverse of removal. Torque the damper bolt to specification. Fig. 1: One example of a crankshaft damper puller tool 85843074.gif
    Fig. 2: Removing the crankshaft damper bolt 85843193.jpg Fig. 3: Do not attempt to pry on the damper to remove it from the crankshaft, use a puller only 85843194.jpg Fig. 4: Removing the damper from the crankshaft 85843195.jpg Fig. 5: When installing the damper, thread the bolt by hand first to prevent cross-threading 85843196.jpg prev.gif next.gif
Jul 04, 2010 | 1990 Oldsmobile Ninety Eight
Unable to connect ipod
Reset the radio (it has a processor) by just unplugging the power cord for about 30+ seconds and plugging it back in. If this doesn't solve the problem, try replacing the remote battery (CR2032- can be found almost everywhere batteries are sold) If all else fails, call Bose tech support. The cable you connected has nothing to do with this.
May 09, 2009 | Bose Wave Radio II
Connect to auxillary dvd player
to connect a DVD player to your TV/VCR combo is :
DVD A/V output to TV/VCR Combo A/V INPUT In the back of TV , if TV doesnt have an auxilliary A/V input , then
the other solution is to get a RF Converter box that connects to where you connect the CABLE service .
thats it . hope this helps , please rate this solution , thanks AJ
Apr 30, 2008 | Toshiba MV13M3 / MV13M3W 13 in. TV/VCR...
Auxillary option not available in menu
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Jul 01, 2007 | Kenwood KDC-MP628 CD Player
Clarion DXZ665MP CD Player Logo
43 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
