Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
Need a diagram of fuel gas lines on a 131 poulan
    President:
  • Poulan Master
  • 1,545 Answers
Lots of research has shown a lack of diagrams on fuel line routing. Your carburetor has the purge/primer bulb on top of it. Just to help you understand how it works....the bulb uses a vacuum effect to pull fuel from the tank directly into the carburetor and the check valves in the plate under the bulb (known as the primer base assembly) push any air and old fuel inside the carb back into the fuel tank. On your model, the line inside the tank with the fuel filter on it will come out and go to the carburetor body BELOW the base assembly. The other line coming out of the tank (fuel return line) will go TO the nipple on the base assembly. The lines should be nice and soft and so should the bulb. They all have to be replaced periodically as alcohol, heat and age deteriorate them. Please post back if needed.
Posted on Nov 06, 2010
Testimonial: "somewhat usful. would have liked a diagram. Bob"
Diagram of fuel lines poulan pro blower
Put your model number into goggle and search for a fuel line diagram and you should be able to find what you are looking for. Hope this helps.
Oct 03, 2014 | Poulan Pro 25CC 2Cycle Gas Blower
I need a diagram for the fuel system on the Poulan chainsaw
4ceb173.jpgI have attached a diagram, I hope this helps.
Aug 07, 2014 | Poulan Garden
Fuel line diagram poulan wild thing 40cc
I can't give you an actual diagram but a I can try to explain how it should go. There is a line with the filter in the tank that goes to the bottom of the carb, there is another line from the carb that goes to the in port of the primer bulb, the out side of the primer bulb will go back down into the fuel tank. The primer will pull gas from the tank through the carb into the bulb then return the gas from the bulb to the tank
Feb 01, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Fuel line diagram model 2450
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly (a "2450 Gas Saw Type 7" example IPL follows. may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2450-Gas-Saw-Type-7/75.2450-Gas-Saw-Type-7.1.59.1.html
Poulan.com (All models)
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
The Poulan print is deceptive, my schematic (below) is correct.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Apr 27, 2010 | Garden
I need to replace the gas lines The lines fell apart unsure were the parts go were can I find a diagram of the gas lines
What little fuel system system detail there is can be found here:
Poulan.com
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Oct 24, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Gas line
What little fuel system detail ther is can be found here:
Poulan.com
Find a model number that matches your saw.
Fuel lines run from the tank to the carburetor to the purge pump and back to the tank. Take extensive notes and a few digital photos as you go are a good idea.
SmallEng.com
HTH
Lou
Oct 04, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need a diagram of the fuel lines on a poulan 2150. what lines go where?
You can View a Diagram of the Chainsaw here http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP⟨=EN&TF=Mainfram...
Select the Catalog Poulan/Weed Eater. Then Select Poulan. Then Select Gas. Then Select Saw. Then Scroll Down to your Model Saw i.e 2150.
Regards
Marc
Apr 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
1,388 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
