Question about Nintendo GameCube Console
I turn it on with the disk in the gamecube and it goes to the cube screen. Then i look at the disk part of it and it says that there is no disk but there actually is a disk.
  • Nintendo Master
  • 424 Answers
No Game Disc:
This error can occur when the Game Disc has been removed while the system is on and then the Disc Cover is closed. Follow these troubleshooting steps:
Ensure the game is inserted correctly. With the power turned off on the system, replace the Game Disc in the system, printed side up. Press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
Determine if this happens with more than one game by inserting a different game into the system.
If the error occurs with all games, follow the Multiple Game Disc troubleshooting.
If the error occurs with only one game, follow the individual game disc troubleshooting.
Posted on Nov 02, 2012
4 Suggested Answers
  • 16 Answers
SOURCE: My game cube doesnt read any disks
Your lasers are shot. Get a new system.
Posted on Feb 05, 2008
nnce
  • 25 Answers
SOURCE: Wii Gamecube controler shuts down Wii!
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
156
Posted on Mar 22, 2009
NES Gamer
  • 19 Answers
SOURCE: connecting intec gamecube screen
The Intec Gamecube screen requires both a 12 volt DC input and the AV input. The larger connection is the AV cable which plugs into the back of the Gamecube console. The smaller round cable is the 12 volt DC input cable that goes to the power source for your screen. The solution is to either get the original splitter cable that splits the DC power to the screen and the Gamecube, or use separate 12 v DC inputs for each device. These original Intec splitter cables are rare and are not cheap, and the only place I have found them for sale is at the NES Repair Shop:
http://nesrepairshop.com/online_shopping/index.php?productID=645
The only other solution is having separate 12 v input cables for the screen and the Gamecube. And finding the right size (very small) is also a task.
Posted on Sep 19, 2009
My game cube is telling me to turn off power and refer to the nintendo gamecube instruction booklet
Either a problem with your disk (Scratched up, damaged) or you Laser Lens is dirty or failing. You could check your disks and get them buffed if it is just one or 2. You could clean your laser lens with you alcohol. But if this does not work you may have to replace the laser unit in you Gamecube.
Aug 19, 2013 | Nintendo GameCube Console
How do you get the nitendo game cube to play on the wii
The Nintendo Wii already comes with everything needed to play GameCube. GameCube disks are loaded and unloaded from the system in the same way that Wii game disks are used. To play the games you are going to need a GameCube controller and a GameCube memory card to save progress. On the top of the system (if the system is vertical) or on the side (if it is laying down) are two flaps, one which opens to reveal the controller ports and the other reveals the slots for the memory cards. To play GameCube, simply select the top left square from the main menu (like you would for any Wii game), select start, and then use the GameCube controller to play the game.
Jul 16, 2011 | Nintendo Wii Console
Disk is clean and all, but when I turn it on, its starts fine until the little box finish making the Game Cube Icon and then start turning and goes straight to my memory card. I can hear the cd running but...
Your Gamecube's laser may be dirty. Try this:
Grab a cotton swab (A Q-Tip), and some rubbing alcohol. Lightly wet one end of the cotton swab with the rubbing alcohol and open up your Gamecube's disk tray. LIGHTYLY rub the wet end of the cotton swab on the disks laser in a circular motion. The laser is the shiny part pointed to by red arrows in this picture: http://i.imgur.com/MAXRQ.png
Now leave it for a minute or two to dry and attempt to play a game again. If this doesn't work your problem may be an underlying hardware error that can't be solved without opening up and gutting your gamecube. Let's hope for the best though!
-Risonhighmer
Feb 27, 2011 | Nintendo GameCube Console
Wii memory card for gamecube
You need a Game Cube memory card to save Game Cube Data, it goes in on the left side of the Wii near the back by where controller 1 plugs in.
Mar 17, 2009 | Nintendo Wii Console
My gamecube wont read my game disc
Its either the game disc or the lens of the gamecube. Try cleaning the disk or try another disc. If the cube still doesn't read the disk your lens is probably scratched in which case you would need a new gamecube.
Mar 07, 2009 | Nintendo Mario Kart: Double Dash for...
Dosent read the game !!!!
The disc is probably toast. But if there is a local Play N Trade store in the area they may be able to fix it
Jan 26, 2009 | EA - Electronic Arts The Sims for GameCube
Games arent starting
Possibility #1:
The disk reader of the game cube is damaged
Possibility #2:
The disks are damaged
Dec 07, 2008 | Nintendo GameCube Console
Game cube not reading disk
I have a game cube that does the same thing. I open it while it's turned off and put my finger on the eye and slide it back and forth a few time. It works after a few tries. I think the gears that move the eye are wore out.
Sep 20, 2008 | Video Game Consoles & Games
Disc wont read and game won't spin
I Had The Same Problem! And I Have A Solution. Unscrew the top off and look inside.
there is the off and on switch on the opposite side to the right of it are 2 little switches, they have probably been displaced, they must be held back, the problem is they are running the disks around and it they aren't in the back they wont do anything.The Laser Should Be Cleaned using a Q-tip and Peroxide. Don't Use Too Much Just Clean Off The Laser, If That Doesn't Work, Its A Problem Inside The Machine, And is Extremely Hard To Fix, If Thats Your Problem, I Would Just Buy A New One For 99$ Rather Then Paying 80$ For Some Guy To Look At It And Say You Cant Fix It, If He Can Fix It, You Were Lucky, But If I Were You, I Wouldn't Take That Chance, Try What I Said, It Worked For Me, Now My Cube Is As Good As New. XD
I Really Hope This Has Helped You.
-XoX-Alyy-XoX-
Nov 03, 2007 | Nintendo GameCube Console
Nintendo GameCube Console Logo
53 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
