Question about Panasonic KX-FP121 Plain Paper Thermal Fax
How to clear fax memory? - Panasonic KX-FP121 Plain Paper Thermal Fax
Remove AC power from the unit for 10 seconds. You can simply pull the cord from the back of the machine. This will clear the fax memory buffer. When the unit restarts, it will want to print a one page "power down report" and will show that the buffer has been cleared.
Posted on Dec 15, 2010
HOW TO CLEAR MEMORY ON FAX MACHINE
Most likely the memory is full because your fax machine either can't print what is in the memory (check paper, ink, etc), or it can't send out faxes you've already scanned into it. (check phone line and ability to dial).
To clear the memory, unplug fax from phone and wall, wait 30 seconds, and plug back in.
Jun 15, 2015 | Panasonic Office Equipment & Supplies
Cant send fax out. getting a message exceeded job memory. How do I clear this
Dear
As the model is not mentioned its difficult to right solution. But in general when a document sent from memory some times this happen. This is frequent if memory recieved is more and not printed.
Its cleared on printing all memory recieved or memory cleared(all received fax will deleted).
Also sending fax manually may be done.I.e.Dial the fax no.get the fax tone load the document press start or send. Also in setting the scanning resolution may be minimised up to150/200dpi for less memory.
Thanks.
Feb 04, 2015 | Office Equipment & Supplies
How to clear Memory?
If the memory is filled up when a fax is received ... when there's no paper, or it is jammed (so that it can't print) ... you can print the fax (in Memory, after putting in new paper, or fixing the jam) by pressing the START/MEMORY button. After it prints, the memory is cleared.
If the memory is filled up when you're scanning and storing a document into memory (to be fax out), press the START/MEMORY key to transmit the pages that's already in memory. After transmitting the content in memory, the memory will be cleared/emptied. You'll need to scan the remaining pages to transmit (as a separate fax)
Jan 18, 2014 | Office Equipment & Supplies
How do I clear the fax memory of the MFC 7860DW
Hello there, you can try the following: 1. On the Touchscreen press the MENU.
2. Press FAX.
3. Press SETUP RECEIVE.
4. Press the UP OR DOWN ARROW to choose MEMORY RECEIVE.
5. Press FAX STORAGE.
Then if you want to clear fax memory find clear or reset memory if you are not able to see it then turn the fax storage off then restart the printer then check.
Then again turn on the fax storage if you want to store fax in memory.
Thank you.
Sep 01, 2011 | Office Equipment & Supplies
I cannot FAX anything because I keep getting "memory low press enter" when I try to FAX. How can I fix this?
Deleting faxes from memory
Use this procedure only if you are concerned someone else has access
to your product and will try to reprint faxes from the reprint memory.
CAUTION In addition to clearing the reprint memory, this procedure clears any fax
currently being sent, unsent faxes pending redial, faxes scheduled to be
sent at a future time, and faxes not printed or forwarded.
To delete faxes from memory
1 Press menu/enter.
2 Press > once to display Fax Functions and press menu/enter.
3 Use the button to select Clear Saved Faxs, and press
menu/enter.
4 Press menu/enter to confirm the deletion.
Sep 13, 2010 | HP LaserJet 3330 All-In-One Printer
OUR FAX SAYS 98% MEMORY FULL SOMETIMES WHEN THEY TRY TO FAX SOMETHING. HOW DO I CLEAR THE MEMORY? NATALIE
Press Menu, 2, 5, 2. The screen prompts you to choose a fax setting. Press <-- or --> to select OFF then press SET. If there are faxes in memory when you turn Fax Storage to OFF, the LCD prompts you to erase faxes in memory. If you press 1, all fax data is erased and Fax Storage is turned OFF.
You may want to enable Real Time TX so you can send fax without using memory. (Under FAX-SETUP SEND-REAL TIME TX)
You may also disable Fax Storage if you don't want to store incoming faxes in memory for remote retrieval (Under FAX- REMOTE FAX OPT-FAX STORAGE)
For effective use of the memory, you may also clear the caller IDs stored in the memory. Press MENU, 2, 0, 2 Press the arrow keys to display # then press CLEAR.
Hope this helps!
Jul 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Need to clear memory
This means that you have 99% free memory.
Apr 17, 2009 | Brother IntelliFax-2820 Laser Fax
FO 5700 Won't print from memory
You have memory lock up. to ram clear the machine we need to clear out all memory. ( like it came out if the box )
1. have machine turned on
2. press 8,*,9,#.7 ( this will git you in to the programing of the fax )
3. press start
4. press the # key till memory clear
5. press start !( will clear out all memory )
it should print out a memory clear report
6 press stop key 2 times now lets se how it worked
let me know
good luck
Jan 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Brother fax 560
Try this: Press MENU, select FAX, then scroll down to REMAINING JOBS. If any jobs are displayed , you can choose to print them. To print from the fax memory, first exit out of the MENU functions totally. Then, press MENU,2,5,4. Next, press START. After all faxes in memory have printed, press STOP/EXIT button. Check REMAINING JOBS again, if it is clear, fax memory should be clear, Also.If the fax machine has a PRINTER function, press the JOB CANCEL button to clear the print Queue.
Apr 15, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Panasonic KX-FP121 Plain Paper Thermal Fax Logo
269 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
