Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Almost fixed! Comment by Indy456, posted on Jun 15, 2008 installed the new STK392-120 and that fixed the color problem. I still have a slight concave picture. The top corners are ok, but the middle sags a little, and the bottom is up a little. Like an hour glass laying on it's side. Also, I've tried to adjust the Aspect because words at the edge of the screen get cut off. Example: "News Channel 13" at the bottom left of the screen would read "ews Channel 13". There has to be an ajustment to this other than the Aspect function on the remote. Any ideas?
  • 4 Answers
Sounds like your unit may be suffering from the 4:3, 16:9 picture glitch.....if so it is easily fixed.
http://oreilly.com/catalog/htheaterhks/chapter/hack12.pdf
Posted on Jun 29, 2008
  • Panasonic Master
  • 8,617 Answers
See my last post to you regarding the converegence resistors
Posted on Jun 15, 2008
By admpeek on Jun 25, 2008 When I turn it on the picture is concaved, the color is shifted slightly to one side, and there are 3 skinny lines across the top. I went to convergence menu and clicked it...
You have a blown fuse on the Deflection board FL231 it will be on the righthand side of the flyback Transfomer there are 3 of them in a row they will look like small brown retrangler caps, it will be the one in the middle. I had this problem myself just several months ago, replacing this fuse fixed the problem. That fuse controls the convergance of the 3 CRT's, without it the tv can't converge so you don't get the option in the menu.
Sep 17, 2010 | RCA HD52W66 Projection Television
Colors are off and the picture is concaved. Tried to flash focus with no change. Picture is narrower in the middle and the colors are seperated.
Your symptoms sounds like a damaged convergence IC’s.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
Most of the time you can just correct the convergence through the television menu. All that needs to be done is line up the blue and red to the green. If the colors do not move then there may be faulty components in the convergence circuit.
You may want to consult a Television Repair Technician, or repair this yourself. If you want to tackle this yourself, let me know, I can give you some direction for the repair
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 02, 2009 | Sony Televison & Video
RCA REAR PROJECTION 60 INCH PURCHASED 1/2000
This is a problem with the convergence circuit. If you can solder, you should be able to fix this yourself. Please post the model number as a comment to this and I'll provide you with additional details and instructions.
Thanks,
Dan
Dec 24, 2008 | RCA Televison & Video
Rca picture concave 52 in rear projection
sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
Oct 21, 2008 | RCA P52939 52" Rear Projection Television
My HD52W67 has concaved picture
This is a convergence problem and can be repaired relatively easily. If you can solder, you can fix this yourself. First try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heat sink and should be marked STKxxx.
Keep us posted.
Dan
Jun 25, 2008 | RCA HD52W66 Projection Television
Water dispenser keeps flowing when water source is turned on
HI,
I have a little experience on your problem.S i suggest you to ask another experts advice.
Jun 13, 2008 | Refrigerators
Bad picture
Try changeing the image quality, is this a cheap around 30usd model?
Comment by Ekse, posted on Jun 12, 2008 Still image: 640 x 480 (high-resolution setting), or 320 x 240 (low-resolution); movie clips: 320 x 240
the thing is this a very cheap camera and the quality doesn't get any better than that. Comment by Ekse, posted on Jun 12, 2008 I can find this camera for even 20 dollars, you have a cheap knock off. You can't get a quality camera for this cheap. Comment by Ekse, posted on Jun 12, 2008 but if you change the setting to high resolution 640x480 which by the way still is very bad. it should look a little better.
Jun 08, 2008 | Vivitar MAGNACAM Binocular
2003 Phillips rear projection 60%: Without any known circumstances, double images (one is red, other yellow), margins at top and bottom are concave. Tried aligning convergence with slight improvement,...
you need to replace the convergence ics. Please post the model number and I will post a link where you can get new replacement ICs along with free instalation instructions with pics so you can do the repair yourself.
May 15, 2008 | Philips Televison & Video
Mitsubishi VS 45501A Projection TV
Model VS-45501A  probably not worth fixing at around 400.00
for a convergence circuit overhaul......T.
Oct 20, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
100 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
