Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
We have a front load Maytag dryer, model number MED5740TQ (very basic model). My wife pulled the timer dial out to start the dryer and the dial came off. We've tried putting the dial back on and the same thing happens every time. We are, howeer, able to turn the dial to change settings, time, ect... I tried pulling the metal arm (which is underneath the timer dial) out with a pair of pliers, however the arm won't budge. I'm not sure whether to glue the knob back on - or if the arm is somehow stuck. Any advice? Rgs, Greg M. (gregm13@yahoo.com)
  • 3 Answers
SOURCE: Flashing "touchup" and dryer won't start
What I did was unplug it for 1 min., plug it back in. Push the "off" button once, then push the off button again and hold it for 10 seconds. This is supposed to reset the computer. It worked for me.
Posted on Nov 14, 2007
  • 1003 Answers
SOURCE: Timer on maytag Atlantis
replace water inlet solenoid first if this doesnt work replace timer
Posted on Feb 02, 2008
  • 958 Answers
SOURCE: maytag washer model mav5057awq
could be a bad timer. there is a switch there that would initiate the sequence.
Posted on Feb 17, 2008
  • 1028 Answers
SOURCE: maytag washer: knob
bad contacts in timer ..replace timer
Posted on Jun 02, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag alantis MAV 9600
hi thanks for the question re set the water level control to see if it will add more water if it doesn,t it could be a bad water valve check that thanks the appliancedoc
Posted on Sep 13, 2008
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Maytag top load washing machine model LAT9306AGE.. the timer doesn't spring back out when needed to during cycles
the timer on all maytag's ( top load turn clock wise/ push in to stop/ pull to start . the spring back ??? the timer shaft may be sticking and is hard to turn . remove face cap and clip pull dial and lube with a light oil or spray lube / reinstall and this moy help .. mm
Dec 02, 2009 | Washing Machines
Maytag Dryer model number PYE2300AYW will not start.
check your fuses in the dryer their is only one fuse that could shut down the whole dryer like that. Open back panel and get a volt meter and check for continuity on the fuses. HOW? first un plug it then open back then you will see the heating element their are 2 fuses on the heating element take off wires and check those.Then if those are ok look down thier is another fuses its long white with 2 wires comming out of it with a black center that should be your problem check it repair it run it . GOOD LUCK
Oct 12, 2009 | Maytag Dryers
Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
Jan 13, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
I have a maytag top load washer model number MAV7757AWQ. It will not spin out ( water just sits ), until I manually move the timer to the spin cycle and restart. Is my timer bad ?
based on your description..the motor for the timer sounds like it is bad or one of the wires powering it came free of the motor terminal.. Does the dial spin after you start any wash setting? If not then I'd say your timer needs replacing.. Hope that helps
Aug 30, 2008 | Maytag MAV7600 Top Load Washer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Hard to start dryer, control know loose/misaligned
your saying that pulling the timer knob out, which normally starts dryer, does nothing. however if you pull out and apply pressure upwards on knob and touch nothing else, the dryer will start??? if the thats the case sounds like a short in the timer mechanism , youll need to replace the timer assy
Mar 18, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Removing Timer Knob on Maytag MDE7400AYW dryer
Can anyone help me? I have a Maytag Atlantis that my parents just gave me and my wife. Unfortunately, they accidently removed the model number sticker in the door area. I need to buy a new timer but no one can find which timer to get without the model number. Via the internet, I think I narrowed it down to either the MDE7400AYQ or the MDE7400AYW....but they both look identical to me. Can anyone tell me what the difference between the two is so I can go get the part?
Mar 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
80 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
