MY SAMSUNG MODEL HLS 5086 W WILL ONLY RUN FOR A FEW SECONDS THE LAMP SHUTS DOWN FIRST FOLLOWED BY THE REST OF THE TV. THE LAMP LOOKS OK ON VISUAL INSPECTION
  • 4234 Answers
SOURCE: Samsung HLS 5679W LED DLP TV Horizontal white lines jagged across screen.
What you are sseing is a convergence problem within the light engine of the set. This is not repairable in teh field other than replacing the light engine part. Since this unit is less than one year old, it should be covered under warranty. From the looks of it, one of the LCD panels has shifted internally. Call for warranty service and indicate that the light engine has a problem. With luck, the service company will show up with the part in hand. Replacement should not take more than an hour or so.
Dan
Posted on Aug 28, 2008
ZaneD
  • 41 Answers
SOURCE: Magnavox model 50ML8105D/17 shuts down
inside the back panel behind the lamp case there is a thermal fuse. replaced the thermal fuse and you will be good.
Posted on Apr 19, 2009
SOURCE: Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Posted on May 03, 2010
  • 8457 Answers
SOURCE: Samsung TV: lamp out
Yes,tries websites like Tvrepairworld.com,Partstore.com,Ebay.com to buy a projection lamp for the replacement.Tv have "LAMP"indication LED light is flashing or staying on.If the projection lamp on the tv now,been in used 4 or 5 hours a day watching the tv.The projection lamp has not been replace the last 1 1/2 or 2 years on the tv.The projection lamp life is over,require changing.The tv also making clicking noises,the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
Posted on Aug 02, 2010
SOURCE: samsung tv turns off on its own model hls4266wx
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Posted on Aug 31, 2010
    Samsung HLS-6167W shuts off every few minutes. I replaced the lamp 3x and recently the lamp ballast and #2 fan. Problem continues, so should I look at the power supply board or the color wheel?
    if the sounds a high pitch squeal !! I had an ole tv that did that when u watched it , finally one day the dang power supply up and gave out !! so that must be what the noise was coming from all that time !!!
    Dec 20, 2016 | Samsung Televison & Video
    I have a Samsung DLP HLS 5086 W that is shutting down after a couple of minutes. The color wheel and lamp were both replaced a little over a year ago. The lamp is a Phillips, and the color wheel is OEM. I...
    Hope this helps:
    Resetting the counter Once you have installed your OEM replacement lamp, resetting the counter is a very simple procedure:
    • Begin with the TV powered off.
    • Point your remote towards your TV.
    • Press:
    • Menu + 1 + 8 + 2 + Power.
    • Your TV set should now say "Loading Factory".
    • Browse down to "Option" then press Enter (or the right cursor button).
    To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterward!).
    NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you're having difficulty with the ENTER button.
    Resetting Your Samsung DLP Lamp Hour Meter Counter or Lamp Timer DLP Lamp...
    Jan 14, 2015 | Samsung Televison & Video
    Had check fan no 2 on tv. I replaced. The bulb is about 6 months old as well. I power on both fans are working the bulb comes on but the tv shuts off after a few seconds before the picture even comes on....
    U recheck the tv projection lamp connections,the door latch and the lamp door closed properly and tightly.Yes,if the tv projection lamp LED light indication "LAMP" word it is still flashing or staying on the tv projection lamp some how dying again.The tv projection lamp should be replacing it again.
    Sep 02, 2011 | Samsung HL-S6188W 61" HDTV
    Now the power shuts off consistently. Says on for a few seconds and the picture looks Ok but it powers down and powers up again on its own.
    Tv "LAMP" LED light is flashing?Yes.Projection lamp might have to be replacing?LAMP been iside the tv like 1 1/2 or 2 years,tv used daily like 4 or 5 hours a day?Yes,replaced the projection lamp,will solved the problems.
    Feb 14, 2011 | Samsung HL-T5676S Television
    Samsung dlp hls6186w, picture has darkened, could it be the lamp or is it the colour wheel??... tv is making sounds...I thought it was the fan, the fan looks okay??? It also shuts down once and a while...
    The lamp is the only thing that will cause the picture to go darker. According to the model you have the lamp part number is BP96-01472A. The noise you hear could possibly be the color wheel itself. The way to tell is when you turn off the TV the lamp stays on for about 10 seconds longer. Once the lamp shuts off if that noise goes away then it is a bad color wheel. Any noises past that would be a fan. Please take a moment to rate my answer. Thanks...
    Dec 02, 2009 | Samsung HLS6186W 61 in. Plasma HDTV
    MY SAMSUNG HLR5067WAXXAA PROJECTION TV JUST
    replace the lamp only takes few min make sure you get right one for model of tv the LAMP MODEL number will be on OLD LAMP the tv will work and sound will come back hope this helps
    Oct 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
    When turned on, my Mitsubishi TV shuts off after a few seconds.
    the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
    lamp part #
    915P028010
    Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
    Green flashes then tv turns off
    or a new lamp. you could first replace the lamp.
    the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
    Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
    Very noisy when turned on, then shuts down, Samsung 61 inch
    Color wheel defective. Replace it with the new designed color wheel. The lamp is ok.
    Dec 10, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
    Right 2 inches on edge of screen are darker than the rest of the screen
    What is the model of the TV? Samsung DLP TV's start with HLS,HLP,HLW.....
    Feb 06, 2007 | Samsung TX-R3080WH 30" TV
    Televison & Video Logo
    149 people viewed this question
    Top Televison & Video Experts
    Marvin
    Marvin
