Question about Alpine CDA-9884 Car CD/ MP3 Player
Hi . . my alpine stereo wont work unless the yellow and red wires are put in the same terminal . . due to this the memory wipes every time i turn it off . . what am i doing wrong . . i`m at my wits end help
    Genius:
  • 1,066 Answers
The red wire needs to be connected directly to the battery postive/red lead. you may have to run a wire from the battery, through a hole drilled in the firewall, into the red lead on the back of the stereo. it is suggested that you use a fuse, but is not necessary, as close to the battery as possible.
Posted on Nov 07, 2010
I put a new stereo in my 2000 model n16 but I
on after market fit radio's the yellow wire is to go to permanent power via a fuse , and the red is to go to ignition live via a fuse and ofcourse the black for the earth no fuse unless connected directly to battery neg terminal
Sep 28, 2014 | Cars & Trucks
What color wire is the power alpine
Almost all car stereos have standard color codes for power, there are Yellow, Red and Black, where Yellow is the direct current from the battery of the car (this always have power on it so don't let it near anything metallic or will cause a short), the Red if for accesory power (this only have current when the key on the car is on accesory mode) and the black is Ground.
Red and Yellow cables need to have power at the same time to power the stereo on, so if you want to test your stereo put the yellow and red cables together on the positive terminal of your car battery and the black on the negative, this should turn on your stereo.
Nov 16, 2013 | Car Audio & Video
Car stereo wired to battery and fuse box what wires go where
If this is an aftermarket stereo, The red wire needs to go to a power source that turns on and off when you turn your key on and off ( a fuse in the fuse box ). The yellow wire needs to have power all the time like its connected to the positive battery terminal or a fuse in the fuse box that always has power and the black wire is the ground and needs to be grounded to the negative battery terminal.
Oct 22, 2012 | Alpine TDA-7563 Cassette Player
I have put the alpine cde126bt stereo into my car, correctly. the only problem now is how to get it to switch off when my ignition turns off, i have swapped the red and yellow wires, which should work, but...
you need to use a test light and find a wire that turns off when the key is off and a wire that is constant. the colors don't matter. but i would suggest using a wiring harnes from www.metra.com you can get them from best buy or any car stereo shop. this will save you time and make the install go a lot easier. all you do is wire it to the harness from the radio and then plug it in to the factory harness in the vehicle. piece of cake. might run you 15$
Mar 07, 2011 | Alpine Car Audio & Video
I am hooking up the stereo and I know I have power coming to the wires cause the black and yellow ones spark but when I hook them to the stereo I don't get any power
The yellow wire is the constant wire, you need to find the battery + wire which will be red and hooked that to your deck, the red wire is the main 12v wire and the yellow wire is there just to use a little bit of power to keep the memory i yur deck, i.e. the time, cd position stuff like that
May 19, 2010 | Alpine CDA-9825 CD Player
Hi hope you can help i have just bought an Alpine CDA-9835R
What kind of car are you trying to put it in? There are many different cars out there that require the use of an antenna adaptor to make it fit the standard "motorola end" of the aftermarket stereo. The Alpine needs to "see" 12 volts constant power on the yellow wire and 12 volt switch (key on) on the red. Good luck
Mar 01, 2010 | Alpine CDA-9835R CD Player
Is there a fuse inside this stereo? i cant get it to work with the right wiring
no it is in the power lead (in line fuse) of the units wiring harness at back, should be 2 fuses one in a red wire and one in a yellow wire, red is power from ignition yellow or other is keep alive memory and laways hot...
Aug 09, 2009 | Alpine CDA-9827 CD Player
Stereo wont work with engine on
best thing is to pull the radio out and check the red and yellow wires red wire is the egnition switch and your yellow is the always on for your memory if you like you can connect the red and yellow wires to the yellow one that will work with engine on or off but every time you get out the car you will need to turn the radio off manually i sugest pulling the radio out and checking the 2 leeds as far as you can it could also be a fuse gone but it wouldnt work when enging is off so not sure except check the wires your engition switch doesnt play up does it like your dash clocks go off and on while driving headlights etc? need more information please
Dec 19, 2008 | JVC AM FM CD DET FACE CAR STEREO
Radio Station Presets wont hold
hi girlygirl 1
the problem is your ignition and your permanant battery live wires are the wrong way round all you have to do is remove the stereo and you will usually see a red wire plug into another red wire and a yellow wire into another yellow wire all you have to do is change the red to the yellow and the yellow to the red and it will hold the memories fine hope that helps !
Nov 19, 2008 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Wont turn on
Could be. you should test the voltage on the yellow wire and red wire. Both should be 12 volts with the car on.
Sep 03, 2007 | Alpine CDA-9883 CD Player
Alpine CDA-9884 Car CD/ MP3 Player Logo
124 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
