Question about ASUS P4P800-E Deluxe Motherboard
My p4p800e Deluxe has started having issues with the secondary IDE port, which I have a dvd rom and a dvd-writer on it. The dvd-writer can write a disc but it looks at the disc as blank. I have tested out the Dvd-writer on an external unit and tested it and even used a new writer in its place and the same thing happens. I am suspecting that there could be a failing component on the mother board. It is six years old. Do you think that is possible as I have tried everything to eliminate what it is not.
4 Suggested Answers
the terrier
  • 94 Answers
SOURCE: IDE controller not working properly
having done these things get in touch and we will go from there
Posted on Nov 01, 2008
rasengan79
  • 138 Answers
SOURCE: Dead ASUS P4P800e-deluxe motherboard.
Try cleaning up the motherboard, remove and clean the heatsink, CPU fan, RAM, etc. Might be caused by dust that have build up inside. Hope this helps.
Posted on Oct 04, 2009
  • 468 Answers
SOURCE: primary IDE port does not work. My main hard disk
It is Biostar http://www.biostar-usa.com
Posted on Oct 12, 2009
How DO i Fix DVD Writer Works As CD ROM Only. Not Detecting any DVD.
There are 2 assemblies inside it.
One works to read/write CD media.
One works to read/write DVD media.
So, your device is "half-broken".
Replace it.
Apr 02, 2015 | Computers & Internet
I have a an INTEL Motherboard Model DH55HC. I am installing a basic Internal DVD writer (DVR-A18M) Interface ATA/ATAPi-7. I have the power cable from the POWER SUPPLY in the correct plug. I attach the...
That motherboard doesnt support ATA it supports upto 6 SATA devices which is actually better and faster. You will need to take your DVD/RW back and ask to swap for a SATA and also make sure you buy a SATA cable and good thing is these are actually cheaper and faster. Its actually a very nice motherboard dont be disappointed. Cheers from Scott and plz vote
Jan 24, 2011 | Intel DH55HC Motherboard
My Gigabyte GA-945GZM-S2 motherboard is not detecting any CD/DVDROM attached to the ide port. it is also not detecting the rom in bios. cable and rom ate both working fine there have been tested on other...
IF THERE IS ANOTHER IDE PORT FOR A SECONDARY DRIVE i WOULD TRY TO SWITCH OVER TO IT . IF NOT THE MOBO MAY HAVE A PROBLEM WITH THE IDE PORT. VEIRFIED THAT THE DRIVES ARE CORRECT AND TRY TO CHANGE THE BOOT ORDER IN BIOS .
May 15, 2010 | Gigabyte GA-945GZM-S2 Motherboard
I have sata dvd writer.when i connect it my computer does not boot.does intel D102ggc2 supports sata dvd writer?
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports.
The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports.
You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so;
First boot device: [Floppy disk] drive; if one is connected.
Second Boot device: [Primary Hard Disk] drive.
(The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information).
Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart.
You're windows operating system should load correctly after the auto re-start.
The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose.
Here is the link to Intel for you're motherboard;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D102GGC2+%22
Mike
May 12, 2010 | Intel D102GGC2 Motherboard
Primary IDE port does not work on intel d865GVHZ motherboard
we are repiar the mother board and 100% warrnty contect for more detetil : www.compudesk.in E-mail: support@compudesk.in
Oct 12, 2009 | Intel D865GVHZ Motherboard
Primary IDE port does not work. My main hard disk drive and DVD writer drive are connected to the Secondary IDE port. If I move them to the the Primary IDE port, both the drives do not get detected at all....
Good day sir, there are several way to connect an extra IDE if the motherboard is full:
  1. Buy a PCI to IDE/SATA card. Check your local computer dealer if there is available.
  2. Buy an external USB to IDE Hard disk enclosure.
Of course, these are things to buy, but check first the CMOS setup if the Primary IDE is enabled on your PC.
Nov 01, 2008 | Intel D101GGC Motherboard
CD ROM DETECTION PROBLEM
LEAVE YOU hard drive on primary master port on your main board set as master or single drive ( IF YOU HAVE A STATA HARD DRIVE THEN DONT WORRY ABOUT THAT PART)
SET YOUR FIRST DRIVE AS MASTER
SET THE SECOND AS SECONDARY
use the jumber in the back of the drive to set them the propper setting is labeled on the drive it self
Connect them to the secondary port on your motherboard
so you should have
HARD DRIVE - MASTER OR SINGLE *jumper settiing* connected to the primary port on your main board
DRIVE 1 = MASTER *jumper settiing*
DRIVE 2 = SLAVE *jumpersetting*
connected to the secondary port on your mother board
IF YOU HAVE A SATA HARD DRIVE FORGET THE PARTS ABOUT HARD DRIVES ABOVE
i assumed you had a IDE hard drive
JUST USE THE SETTINGS FOR THE DRIVES and it should work :)
Dec 25, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Dvd-rom icon missing
Check: 1. if on pressing the eject button on the drive, the DVD loading arm comes out. 2. if yes, replug your IDE cable. 3. If it does not work try using another IDE cable. 4. If still the same problem, connect it to anothet IDE port. 5. If the problem is still there get your DVD drive checked. I assume you have not fiddled with the jumper settings.
Sep 30, 2007 | Computers & Internet
ASUS P4P800-E Deluxe Motherboard Logo
23 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
