Question about Kenmore 19233 Computerized Sewing Machine
E1 error I was freehand sewing with lightweight invisable thread and it shuddered to a stop and won't restart. I turned off the power and back on and display shows E1 Error.
  • 3 more comments
  • ms nasty Jun 21, 2008
    E1 problem - I have the same issue. Anyone know what to do?
  • growinsew Nov 30, 2008
    My machine is saying E1 error a well and the solution posted did not work for me
  • liveeachday Dec 03, 2008
    I was sewing and missed a pin that was hidden under the material. The machine (Kenmore 19233) said it was doing a safety stop. I pushed clear to try and reset the machine, but now all I get is an E1 Error message. Can I fix this or do I need to take it to a shop?
  • steff3940 Dec 21, 2008
    I have the same problem and discovered that there's a connection between the needle, handwheel, and error message. I can clear the error message but only if the needle is down. I do this by turning off the machine and holding the Memory button while turning it back on. The language options appear. i choose1 for Eng. and push mem....as long as the needle is down, the screen is in the correct menu, but if i turn the hand wheel and raise the needle, the error message reappears.
  • little willy Jan 11, 2009
    Machine won't run E 1 error message. Frist had a saftey message.
    Problem Solver:
  • 16 Answers
The E1 error code indicates that a fuse is blown on the control board. The image below shows the fuse location. http://www.sewingmachineryrepair.com/forums/index.phpE1 error - 3036358.gif
Posted on Feb 28, 2010
Well this happen to me today and let me say that I called the customer service numbers on my manual and let me say dealt with really rude people They told me a number to call which was my local store and talk to repair center there and when I called it directed me back to the same people who game me the number and was not very nice to me when I told them their number didn't help me. So after being so upset at my machine and the company I bought this machine from Found out the only troubleshooting you can get is take it to the store to send off for repair just shipping alone I was told was 80.00 plus parts and labor to fix it. My husband said when he got home he'd take a look at it. So I waited for him. He took the whole thing apart searching for a reset button found none. However he did find behind the button panel you know the buttons that you select your stitches and such. Well behind that is a electronic panel that has 2 fuses in it. I only recommend doing this if you are electronically capable. Or find a good friend that you trust that is. Check those 2 fuses see if they are good if you have no way to test them like my husband has then just replace those two fuses with the exact same fuse amps and such take them to Radio Shack or someplace that can help you make sure you get the right fuses place them back in the machine put it back together turn it on and presto you have 80.00 plus parts and labor that you'd be charged at an inflated rate in your pocket and your sewing machine will work. Mine did the same as the person who said that when you lower and raise the needles one way gave the error one way gave a normal screen... Except mine if the needle was in one direction it gave Error E1 and the other direction Error E2 and in a certain position it gave me the normal screen. However when turning it one the needed didn't move and adjust like it does when you turn it on. Ok I hope that this solves your problems and hope you all will call and complain to the company who provides no over the phone service. All I wanted was to know what the code stood for. They couldn't even tell you that. My old machine would tell you what the error codes meant in the manual this company doesn't cause they want to rob us of money by sending it in. Still have to pay shipping I was told if you even have the warranty... Oh and in my case only one of my fuses was bad. It was the one that is white and not clear the Ceramic fuse not the glass. Good luck hope this saves you all a lot of money like it did me...And had my machine the same day instead of being without it for weeks
Posted on Dec 24, 2008
I was getting the E1 error message. I was told that the fuse had to be switched from the 2.5 amp that is has to a 3.5 amp. they did not recall the machine because of the low cost $2.99. I just received my fuse in the mail. I'm going to try to change it out myself.
Posted on Jan 23, 2009
Try turning sewing machine off and while turning it back on press the memory button simultaneously with the on switch. That got rid of the E1 Error for me just now and I'm back sewing. May take a few try's.
Posted on Jun 21, 2008
Hi i keep getting the E1 error message flash up on the sewing machine, it still sews but it keeps stopping and the E1 error message comes up, what exactly is wrong with it? can you he;lp? Thanks
E1 means that your machine thinks the thread has broken.
There's nothing you can do to fix this: it has to go to an authorised Singer Service Centre for diagnosis and repair. Usually it's a faulty thread sensor.
Sep 10, 2010 | Singer CE-200 Quantum Futura Computerized...
My brother CE 4000 sewing machine freezes. After some tinkering I can sew a little then in happens again. It makes a shuddering noise then freezes and shows an E6 error message?
Turn off the power and remove the needle and presser foot.
Remove the needle plate, bobbin and bobbin case.
Clean the shuttle and surrounding area.
Replace everything.
Make sure the flat side of the needle faces to the back of the machine.
Raise the presser foot and re-thread the machine.
Mar 06, 2010 | Brother Sewing Machines
E1 error keeps coming up everytime I press the foot controller or start/stop button. Before this happened, the bobbin thread wasn't working. Only bunching lots of threads from top underneath cloth.
E1 means that the main motor is working to hard so the machine is keeping you from burning it up, make sure the handwheel feels smooth when turning if it doesnt clean your hook area and take the side cover off and make sure no thread is caught in the take-up lever
Jul 11, 2009 | Brother CS6000i Computerized Sewing...
Error 1 message will not leave
Hi - first, check your manual to see if the error is described somewhere. Follow the instructions. If the manual tells you to take the machine in for repair, try a couple things first.
Often when your needle starts to shudder, the thread is caught on something somewhere along the sewing path. Turn off your machine, change your needle, take all of the thread out of the machine and rethread it. Then remove your bobbin to make sure that there is nothing stuck in the bobbin case, or in the area where you insert your bobbin into the machine. Look around the sewing area to see if something looks out of place.
After you insert a new needle and rethreaded your machine, and before you turn the machine back one, try using the wheel to make a few stitches manually. Watch your sewing thread to make sure it is feeding evenly. If the needle does not move up and down correctly, or if you hear a grinding or bumping sound, you probably need to take the machine to be repaired. Otherwise, turn your machine back on. If the error message is gone, try sewing slowly for several inches - if all seems well, increase the speed a little at a time. If anything seems off to you while you sew - stop sewing immediately and look very carefully to see if you can find a problem.
Dec 20, 2008 | Kenmore 19365 Computerized Sewing Machine
Threading and thread breaks
The shudder bothers me!!
Would suggest take it back before you start messing with it or letting a sewing machine tech near it. Last thing you want to do is run the risk of voiding the warranty.
Best of luck
Rob
Mar 26, 2008 | Brother CS6000i Computerized Sewing...
Kenmore 19233 Computerized Sewing Machine Logo
504 people viewed this question
Top Kenmore Sewing Machines Experts
SewTechWayne
SewTechWayne
Page Gettman
Level 1 Expert
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
