Question about Dryers
The drum does not rotate. I just want a suggestion about the problem
Bosch Axxis Washer WFL2060 UC Fills won't rotate.Replaced Belt,started but stopped mid cycle. Replaced door switch, no rotation.
The motor probably isn't working - I suggest you begin by checking the brushes, which wear out and need replacing periodically.
Oct 14, 2018 | Bosch Dryers
Washing machine drum is not rotating
There may be a blockage. My washing machine had done this before. If your washing machine has the rubber outline around the drum I suggest running a finger around to make sure there isn't anything preventing it. Otherwise I would suggest phoning the store you purchased it from and asking if it is still warranted
Jun 01, 2013 | Washing Machines
Drum is hard to turn
Good Morning Gary - Try rotating the drum manually when the unit is turned off. If you notice that the drum is not balanced and cannot rotate freely, then you could possibly have a problem with the belt, front (and/or rear) bearing, or a loose connection with the motor/drum. Regrettably, this is not a simple DIY job. Generally, qualified technicians often perform these complicated part replacements. If I was in your position, I would personally suggest contacting a professional to accurately assist with the repair or installation of the part.
May 13, 2013 | Frigidaire Affinity FAFW3511K Washer
How to balance a frigidaire washer?
Hello - Are you speaking about being balance without the leveling legs? Is the unit located on complete level ground? Or is the washer tub loose and unable to move? If you are referring to the drum, try rotating it manually when it is turned. If you notice that the drum is not balanced and cannot rotate freely, I would suggest contacting a professional so they can move forward accurately. Washer may possibly have a faulty bearing, unbalance drum or pulley issue.
Dec 06, 2012 | Frigidaire Washing Machines
Tub is loose
Hello Rob - Try rotating the drum manually when it is turned. If you notice that the drum is not balanced and cannot rotate freely, I would suggest contacting a professional so they can move forward accurately. Washer may possibly have a faulty bearing, unbalance drum or pulley issue.
Oct 06, 2012 | Frigidaire ATF6000ES Front Load Washer
Drum not rotating on washing machine
change the carbons in the motor
Jun 28, 2010 | Washing Machines
Bosch WFMC 3200UC can't rotate the drum
that test indicates a faulty speed sensor or wiring harness.
Jan 23, 2010 | Bosch WFMC 3200 Front Load Washer
Dryer won't run
power pack, or condensur is faulty that stats the motor fit new one .close says!
Nov 30, 2008 | Frigidaire Dryers
ASKO t700 dryer thumping sound
usually whin you get one thump (or a quick double thump) you have a dent in the roller surface of the drum itself. Easiest way to check this is to unplug the unit and take the top off by removing the 3 torx screws in the rear, then lifting the top off. Once the top is off look at the very front edge of the drum as you rotate the whole thing by hand. If you see any irregularities on the surface, thats your problem. If you see nothing it could be a bad motor or roller, but its unlikely if its happening in the same place on the rotation evry time. What has usually happened with dents in the surface of the drum is that the unit was set down too hard (or dropped) and the wheels it rests on dented the metal they ride on. If thats the case the only solution is to replace the drum or live with it .Good Luck!
Feb 10, 2007 | Asko T700 Electric Commercial Dryer
Dryers Logo
13 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
